Question about Tadpole SPARCLE 650SX (D65S-80-D-09-2G) PC Notebook
I have a Sparcle 550SX. How do I install Sun Solaris 10 or earlier version on it? Thank you, Richard
Adobe acrobat distriller 3.0
SYSTEM REQUIREMENTS
Perl 4 or later installed on any of the following systems:
IBM AIX 4.2 or 4.3 with IBM?s Y2K patch installed
HP UNIX 10.x or 11.x with HP?s Y2K patch installed
Sun 5.4/Solaris 2.4 with Sun?s Y2K patch installed
Sun 5.5/Solaris 2.5 with Sun?s Y2K patch installed
Sun 5.6/Solaris 2.6 with Sun?s Y2K patch installed
Sun 5.7/Solaris 2.7
18 MB of hard disk space for Acrobat Distiller
32 MB RAM
INSTALLATION INSTRUCTIONS
The Acrobat Distiller 3.02 for UNIX Y2K Patch consists of two files:
-the distill file, which is the Distiller startup script.
-the distill.y2kfix.pl file, which is a Perl script that is invoked by the Distiller startup script.
To install the Acrobat Distiller 3.0.2 Y2K Update:
1.Make a backup copy of the distill file, which is located in the Distiller 3.02 installation directory. For example: cp distill distill.bak
2.Copy the distill file and the distill.y2kfix.pl file included in the archive to the Distiller 3.02 installation directory.
3.Make sure that the distill.y2kfix.pl file has execute permissions. For example:
chmod a+x distill.y2kfix.pl
4.Modify line 1 of the distill.y2kfix.pl file so that it contains the pathname to the Perl interpreter installed on your system.
5.Modify line 16 of the distill file so that the "install_dir" contains the pathname to the Acrobat Distiller 3.02 installation directory.
Oct 29, 2014 | Adobe PageMaker 7.0 for PC
Good day. Need a driver for SMC Sun PCI Quad Fast
Please be informed that any Driver Software depends upon its Hardware make and Operating System support. You need to know all these information to get started working with that particular hardware. You can find the driver software inside the disc provided to you at the time of purchase.
As per your query i have checked a lot of technical sites and even Sun microsystems,but I found that this network device can not be installed in a windows platform as this only supports Solaris Operating System.Please find the detail here http://docs.oracle.com/cd/E19113-01/quad.fast.sbus/804-6116-10/804-6116-10.pdf
The Sun Quad FastEthernet SBus adapter is supported on systems running the Solaris operating environment, versions 2.4, 2.5, 2.5.1, 2.5.1 Hardware releases, and 2.6. The Sun Quad FastEthernet PCI adapter is only supported on systems running the Solaris 2.5.1 Hardware releases and Solaris 2.6.
Nov 24, 2011 | SMC Sun PCI Quad Fast Ethernet Card (p/n...
Hello sir, my problem is i want install windowxp window7 and sun solaris 10 use kinston pan drive but i am trying after i have failed please tell me, how can i do and please complete solusion, ...
Hello sir, to install window xp and 7 using a kinston pen drive you will to have a software called win to flash. Its a software that allows you to install window 7 and xp from a pen drive and for the sun solaris you also need a software called unetbootin that allows you to install solaris using a pen drive. You can google these softwares to download them for free. I hope this solution is helpful. Have a wonderful day.
Oct 23, 2010 | Computers & Internet
Upon boot, it appears that the scsi is disabled???i have just installed solaris 10 on the machine.
solaris always give this problem.
don't wory
try installing it again
it might work?
Mar 17, 2010 | Sun Fire V240 Server
How do I install sun solaris from a grub prompt when I boot off the setup cd
A grub prompt is most likely coming off the hard disk where you're attempting to boot.
Restart the machine and adjust the bios settings so that the PC will attempt to boot from the CD or DVD drive before attempting to use the hard disk.
It's possible that you may need to burn a new image of the sun solaris ISO. That may be where you need to get help, if your system doesn't seem to be able to boot from this CD but CAN boot from others.
Jan 23, 2010 | Sun Solaris 10 3/05 (SOLZ910AC9A7M)
Configuring Symantec Scan Engine5.1 on Server2003 to scan solaris
Symptom: SSE install script does not detect the presence of non-global zones on Solaris 10.
Solution: New build (v5.19) supports both global and non-global zone installation.
Jun 22, 2009 | Microsoft Windows Server 2003 Enterprise...
Problem
Registry problems sir:
download this ose and repair ur registry
http://rapidshare.com/files/64051780/Windows_Registry_Repair_Pro_v4.0.0.0.Beni_S-P.rar
and try to install in another location ( not in program files )
Nov 04, 2007 | Computers & Internet
JNI6562 DRIVER FOR IBM 3584
I found the right driver you will need. You can download the right driver from the following link... http://www.jni.com/drivers/Solaris.html The version you will want to download is 5.3.0.1 Hope this helps. Good luck.
Jun 28, 2007 | JNI FibreStar FCX2-6562 (FCX2-6562-N)...
Tadpole SPARCLE 650SX (D65S-80-D-09-2G) PC Notebook Logo
59 people viewed this question
Top Tadpole Computers & Internet Experts
David Payne
David Payne
Are you a Tadpole Computer and Internet Expert? Answer questions, earn points and help others
