Hard disk:s.m.a.r.t. command failed can't boot
    President:
  • 2,992 Answers
Your computer's BIOS setup screens should allow you disable SMART monitoring, which would let the computer boot up normally. Check the screen when your computer first starts for a message about entering setup. Depending on the make and model, you might have to press DEL or ESC or some other key sequence. Then look for SMART monitoring in the setup pages and shut it off.
SMART monitoring keeps an eye on several drive parameters and lets you know when one of them is out of bounds. This doesn't necessarily mean the drive is bad, but it's a sign that more serious trouble may be ahead. Of course, there's also a chance that the drive is no longer working correctly.
This would be a good time to get a replacement hard drive for the computer and transfer everything over to it. If you can disable SMART monitoring and the system starts up and Windows is working, get yourself a new drive and transfer the old drive's contents using a program like Norton Ghost while you still can. Better to be safe than sorry!
Good luck, and thanks for using Fixya!
Posted on Oct 08, 2010
Blank screen on aspire 4330 model jal90
This normaly happens due to a failing Hard disk. By this i mean the booting files, responsible for normal start up of your computer have been modified or deleted. Or it can also be a result of a dropped hard disk. For you to fix this, boot your computer using Error Rescue Disk(ERD). You can get it from the Microsoft website. Its an image, burn it to a cd and boot the computer with that cd. When your computer is booted up, go to start, then Administrative Tools, then Explorer. Make a back up by copying your data to a removable media.(external Hard drive or flash drive). Then go to Erase Disk/ Disk wipe. This will let you clean up your hard drive. Restart your computer with an Operating system disk in it and boot from it to install a new operating system. NOTE: Make sure you download ERD commander 2007 if you are using Xp, and ERD Commander 2010 if you are using Vista or Windows 7
Dec 14, 2011 | Acer Aspire Computers & Internet
When i boot it always says "hard Disk: S.M.A.R.T. command failed press f1 to resume"
this means the hard disks start up self check has failed. press F1 then backup all data from your pc to another drive.
You will then have to replace the drive.
Feb 28, 2011 | Samsung (SP0411N) 40 GB Hard Drive
Pri master hard disk: S.M.A.R.T. command failed
there is problem with hard drive kindly replace it.
have a nice day dont forget to rate pls.
May 11, 2010 | Samsung (SP0411N) 40 GB Hard Drive
My hard drive burnt out. The hard drive test says failed and the operating system won't boot. I placed a leftover hard drive from my Playstation 3 into the laptop and now it says no operating system found....
Try the recovery console from a windows xp recovery/install disk:
To run the Recovery Console from the Windows XP startup disks or the Windows XP CD-ROM, follow these steps:
1.Insert the Windows XP startup disk into the floppy disk drive, or insert the Windows XP CD-ROM into the CD-ROM drive, and then restart the computer.
Click to select any options that are required to start the computer from the CD-ROM drive if you are prompted.
2.When the "Welcome to Setup" screen appears, press R to start the Recovery Console.
3.Select the operating system you want to repair (you may have only one option).
4.When you are prompted, type the Administrator password. If the administrator password is blank, just press ENTER.
5.At the command prompt, type the appropriate commands to diagnose and repair your Windows XP installation. From here I would try "chkdsk /r" and "fixboot"
For a list of commands that are available in Recovery Console, type recovery console commands or help at the command prompt, and then press ENTER.
For information about a specific command, type help commandname at the command prompt, and then press ENTER.
6.To exit the Recovery Console and restart the computer, type exit at the command prompt, and then press ENTER.
Once you've done this restart the computer and see if it boots up.
Apr 08, 2010 | HP Compaq Presario V6000T PC Notebook
XP wont boot and i cant boot from the restore disk. I get error code 1000-0146 when i run the DST Short test
That error code sounds like the Hard Drive is failing or has failed. Can you boot into Safe Mode? Hit F8 as you power up and choose Safe Mode with Command Prompt. If you can, enter chkdsk /r at a command prompt (the black window you'll see). You say you can't boot from the restore disk - why not? Are you booting to the green Dell Windows XP disc that shipped with the computer? Check the boot order in Setup (the BIOS) and make sure it looks to the CD drive first before trying to boot to the hard drive. SpinRite is a good utility for fixing these things, but not free, and involves booting to CD. http://www.grc.com/cs/prepurch.htm
Hope this helps!
Mar 08, 2010 | Dell Latitude D610 Laptop Computer -...
Computer says disk boot fail
If you have not changed any settings in the bios, then you may have a bad hard drive.
Did you just install a new hard drive? If so, you will need to install the OS, which means you will need a Microsoft Windows Install CD. If you have not, and the computer has previously been running fine, with no hardware changes or bios changes, then your hard drive probably failed. You can run a windows boot disk, and at a command prompt type:
chkdsk c: /f /r
You may want to try booting form the windows XP (assuming thats what your running) install cd, and try to run a repair. If that fails, you may want to run the above command.
If all else fails, you will need a new hard driver, and then try to recover data off of your old hard drive.
Oct 25, 2009 | HP Computers & Internet
Need to find the NTLDR on my emachine I tried the recovery disk option to reset the reboot option - and was still unable to correct the problem. Are you aware of another solution? Thank You
A couple of things.
If the system has a floppy diskette drive, ensure that no diskette is in the drive. (I know it sounds simple but ...)
If no floppy drive issue, then run diagnostics on the hard drive. The drive may be failing.
Last you can try booting to the XP CD enter recovery console, and run the command: CHKDSK /R, then reboot.
My impression, if no floppy drive issue, then failing hdd
Jul 02, 2009 | E-Machines eMachines Desktop PC
S.m.a.r.t. command failed
http://www.tech-forums.net/pc/f77/startup-pri-master-hard-disk-s-m-r-t-command-failed-114514/
sounds like your hdd is failing, backup data by using external enclosure and get a new hdd.
try the solution in the link, it may get your computer to boot up.
Dec 20, 2008 | Averatec 3200 Notebook
I have a laptop Toshiba satellite A30. I have a black screen and some text on it like: PXE-E61 MediaTest Failure PXE-M0F Exiting PXE ROM and it goes continiously, I can't go any further. When I was loaded...
media test failure means that your boot drive has failed ie your hard drive has failed to boot....could be one of a number of reasons
1 hard drive connection could be loose - try taking out the hard drive and reinstalling it
2 the boot sector on the hard drive is corrupt or damaged - try booting off a windows disk and running chkdsk or fixboot command
3 partition table is corrupt - try booting off windows cd and running chkdsk /p from command prompt
4 Hard drive has failed - if machine is still under warranty return for repair if not install new hard drive and reload op system from recovery disks
Dec 05, 2008 | Toshiba Satellite A1O A15 A20 A25 A30 A35...
Computers & Internet Logo
70 people viewed this question
David Payne
David Payne
