Question about Campbell Hausfeld 1,350 Psi Electric Pressure Washer With Auto Detail Kit #PW1350
Campbell hausfeld standard duty electric pressuse washer serial 15930 water wizard .. I cannot locate the reset button and after a short while it wont turn on at all it powers off automatically. and after checking cords and plugs it wont turn on at all..
5 Suggested Answers
comax
  • 154 Answers
SOURCE: Does anyone know what the spark plug gap setting
Most gas engines will work fine at .030 to .035 sparkplug gap
Posted on Apr 16, 2009
  • 384 Answers
SOURCE: PW1345 Campbell Hausfeld Won't run
Got gas?
Posted on Jul 22, 2009
  • 251 Answers
SOURCE: pulsing Campbell Hausfeld 1300 psi 1.6 gallon electric
the unloader valve is deffective , this has a small metal rod which activates a microswitch to turn the machine off , replace the unloader valve
Posted on Nov 19, 2009
SOURCE: Campbell Hausfeld PW1380 Pump won't run when water hose is connec
http://www.ppe-pressure-washer-parts.com/campbell-hausfeld-pw138000-pressure-washer-parts
Hope this helps. I have the same problem. It's not the switch but the mechanism that slides inside the switch, which activates the switch to go on and off. I fnally found it so hopefully they have the part in stock. It's not a clogged wand trust me I have torn it completley apart and found out it is the mechanism in the switch is plastic and breaks.
Posted on Aug 09, 2010
How to hook up a pressure washer by Campbell hausfeld
Hook up the water hose and plug it in I assume it is electric.
Oct 11, 2016 | Campbell Hausfeld Garden
Campbell Hausfield Electric Pressure Washer 1350 handle leaks
You are probably missing the washer or O-ring. Loosen and separate then check. It may also be a broken O-ring.
Oct 17, 2014 | Campbell Hausfeld PW135000AV 1350 PSI...
No power or pressure when switched on
as per your manual the pressure washer should only be used for a maximum number of minutes to keep from overloading the motor and causing it to seize. There should be a "RESET" switch or button due to a protection circuit built in to keep from damaging the unit. Please refer to manual for location of reset switch/button
Apr 20, 2014 | Campbell Hausfeld 1800 PSI Electric...
Hookup
For the Campbell Hausfeld 1800 PSI model (PW182500AV), the garden hose connects to the pump inlet on the lower back of the pressure washer. The high pressure hose connects to the high pressure outlet on the lower front of the pressure washer. Here is the operator's manual that will show both connections. http://www.mowersatjacks.com/images/campbell-hausfeld/manuals/pw1825.pdf
May 18, 2013 | Campbell Hausfeld 1800 PSI Electric...
Gun
Replace the wand (Gun) The valve is not repairable.
Jun 16, 2010 | Campbell Hausfeld PW1750 Electric Pressure...
My electric pressure washer's motor will not start. the 110 plug has a test/reset fuse on it. when i plug it in the light comes on. i push test- it turns off but motor does not run. i push reset and...
With the water faucet turned fully on and the power switch on squeeze and hold the trigger for at least 10 seconds to let the water flow push the air out and then it should start up.
Apr 15, 2010 | Campbell Hausfeld PW1750 Electric Pressure...
Pulsing Campbell Hausfeld 1300 psi 1.6 gallon electric
Nov 18, 2009 | Campbell Hausfeld 1,350 Psi Electric...
Campbell Hausfeld 1,350 Psi Electric Pressure Washer With Auto Detail Kit #PW1350 Logo
52 people viewed this question
Top Campbell Hausfeld Garden Experts
John Trevino
Tim Venetis
Are you a Campbell Hausfeld Garden Expert? Answer questions, earn points and help others
