Question about Olevia LT27HVX 27 in. LCD Television
Tv turning its self up?
If i let the tv sit on for a few mins the volume will start to turn its self up about 4 or 5 clicks every few mins...anyone know how to fix this?
  • 1 more comment
  • Jakecwells May 29, 2008
    the actual bar stays the same, but somehow the tv keeps getting louder and louder....i have even tried taking the batteries out of both my remotes and it still happenes
  • Christophe Thompson
    Christophe Thompson Dec 01, 2013
    2 things it can be one a neighbor is using a frequency that is rf signaled you wont see bars go up or your tv has volume auto adjust from when it comes from commercial or a frame switch
    digital is real flauxy in sound some channels are very low in volume some arehigh in volume
    Genius:
  • 1,224 Answers
Is it showing it turn its self up on the tv by the bars or is the sound just getting louder by itself
is your remote a learning remote and does your tv have a preset volume that when turned on its to goto
if showing by bars one of the buttons on your remote is stuck or needs cleaning and
quite possibly getting an outside frequency thats interfering with your remote frequency
but if no bars are showing the service provider company i noticed my self there tv programs are flauxing in sound for some reason this to me gets annoying
Posted on May 29, 2008
  • William Connor
    William Connor Dec 01, 2013
    my tv does this too its not the remote cus took batteries out and i didnt hae it hooked up to anything and it still did it
My panasonic tv model TC32LX85 N has self check and wont go away?
To Exit Self-check Screen
  • Press and Hold Power button on the TV for 5 seconds [or] disconnect the AC cord from wall socket.
TV volume down and OK on the remote only does a basic IC self check. It do not rest the TV. It do not clear channel programmed settings, picture settings, channel labels, lock settings or password. Using this method, it shows the units' firmware version [Peaks 1.050 and GenX 1.00] and it checks the IC communications only. This is more useful to identify the firmware version, without having to decode the info in the setup menu about version/screen.
TO RESET THE UNIT
  • To make a reset to TV, turn it ON while pressing the [Volume-ve] button on the main unit, and press the 'Menu' button on the remote control for more than 3 seconds. The self check menu appear on the screen. Then disconnect the AC cord from the wall outlet. [ALL PROGRAMMED PARAMETERS WILL BE ERASED]
Jul 30, 2014 | Panasonic TC-32LX85 LCD TV
I have a Mitsubishi 73"
i would suspect your control buttons on your front panel on the set have become shorted. specifically the volume buttom down. This is freezing you control functions. like someone is holding the volume down button all the time. or intermitantly. this cuircit board is on front of the set. I have seen this problem a few times at the shop. The common repair is to replace that button assembly cuircit board. I believe the last time it cost the customer around 85 dollars, but like all things depends on the part and the technician that puts it in.
Apr 21, 2011 | Mitsubishi WD-73827 73" HDTV DLP TV
I have a 67 DLP samsung TV that recently started turning it self off after just a few minutes of being on. When it turns off about ten seconds go by then you hear a click and the two green LEDs on the...
It could be the temp sensor going bad. This sensor sits on top of the metal housing which the bulb assembly slides into. The bulb assembly will have a hole on top and this is where the sensor is above. There is a small blue and white wire that plugs into it. If you pull the wire out and put a paper clip or wire in the coupling you will basically bypass the sensor connecting the blue and white wire. If your tv turns on then that is your problem. Its cheap too. Here were my symptoms..1] Turn tv on 2] Bulb would light up..(which eliminates the ballast) regular picture would show up (which eliminates the bulb and color wheel) 3] 30 seconds later tv would shut down with 3 flashing lights. After bypass the tv turned on as always and hasnt shut down yet. Always un plug tv first. Get the replacement part to avoid overheating and possible fire
Jan 07, 2011 | Samsung HL-67A510 67" DLP HDTV
Turn tv on - no sound?
have u check the menu??? where u can move the audio optons, panasonic has 3 options:
speakers on
speaker off variable pre out (u can connect and amplifier and when u up the volume in ur tv then u turn up the volume in the amplifier)
speaker off continues out (u turn on and down the volumen directly on the amplifier)
try to connect an amplifier to the tv an see if u have sound.
i u dont have sound neither the amplifier the audio in the tv must be damaged.
good luck
Jan 12, 2009 | Televison & Video
My Tv is turning off by itself
unplug and let sit for a min then plug back in
Jan 01, 2009 | Televison & Video
Volume decreases by itself
maybe defective speaker or audio output ic or shorted capacitor within audio circuit
Nov 09, 2008 | RCA F32648 32" TV
Mitsubishi TV 52'
Mitsubishi gives this error , when it does not detect a video signal.....Check your wiring.
Dec 24, 2007 | Mitsubishi WD-52525 52" Rear Projection...
No picture, stuck on Video 1, volume self-adjust to maximum
the tacticle (micro switches)on the front of the main chassis have most likely gotten wet at some time,I suggest replacing them all.
Apr 02, 2007 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Olevia LT27HVX 27 in. LCD Television Logo
225 people viewed this question
Top Olevia Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
