Question about Wolfgang Puck BFPR0015 Food Processor
Light comes on. does not process
I have my food processor locked and the lid tightly closed and it does not work. when I press a button, the light comes on, but nothing happens.i haven't used it for a few weeks but it's only a month old.
  • 2 more comments
  • Anonymous Jul 01, 2008
    I am experiencing the exact same problem.
  • Anonymous Jul 22, 2008
    same here, everything is plugged in and the power light is on. However nothing happens when the pulse button is pressed. My machine has hardly been used but worked before.
  • jdmitchell1 Jul 23, 2008
    I am having the exact same problem??
    Can you send the machine off somewhere to be repaired??
  • sienna_98 Aug 06, 2008
    Ditto. Worked 2 days ago and now, even though it's in the locked position, the blades won't turn. (light does come on)
I borrowed one of these and it didn't work. I had the exact same problem you all are having. The problem? I had the handle pointing to the back instead of the front. Turned the handle around to the front. Presto!! It works..
Posted on Jun 25, 2010
My wife just bought one. When I set it up I put the lid on 180 degrees rotated from the proper position. It lock and looked fine but would not work. Is it possible you are doing the same thing?
Posted on Oct 18, 2008
Same prob...took prior advice and moved the handle to the front and presto! It works...thank you
Posted on Jul 31, 2010
The correct answer. I tried it and it worked.
Posted on Dec 18, 2008
New magimix won't start
It is most likely the way the bowl and lid are set.
Facing the machine:
the bowl locks in, with the handle to your right directly above the switches. The lid has a double tab...see underside of the top of the lid. Place the lid on tightly with both tabs locked into bowls handle. It really clicks in.
Feb 01, 2013 | Magimix 4100 Cuisine Systeme 1268 Cups...
The motor on our B&D PowerPro II food processer runs but does not spin anymore. Can this be repaired?
If the lid is not locked in place it will not work. It's a safety feature. Verify that you've got it latched in tightly under the handle.
Oct 03, 2010 | Black & Decker FP1510 Food Processor
I have a small Cuisinart food processor and I cannot figure out how to turn it on. It has two levers low and high. I have it plugged in and the lid on? Please help. Fiona Slattery 858-752-8591
Your PowerBlend Duet™ comes with a food processor button. This button is the perfect speed for all your food processing tasks. Always use this speed when using the food processor. You may also use the Pulse button with this function for pulse-chopping.
To use your food processor, make sure that the bowl is assembled properly and the blade or slicing/shredding disc and the cover are locked into place.
When you use the control panel, the LED will light next to each button you press.
Press the On button. For continuous operation, press the Food Processor button. Motor will start if you have followed assembly instructions.
To turn motor off, press the Food Processor button again or the Off button.
For on/off operation, called pulse-chopping or pulsing, press the On button, press the Pulse button, and then press and release the
Food Processor button the desired number of times. Motor runs as long as you hold the Food Processor button down. The motor stops when you release control switch. Try it a few times.
You control the duration and frequency of pulses by the length of time you hold the Food Processor button down and the rate at which you press it. Pulses should be short bursts. Allow enough time between pulses to let food in work bowl fall to bottom.
Always use the Food Processor button for pulse/chopping. Never turn cover back and forth to start and stop processor.
You can download manual from the below link
http://www.cuisinart.com/share/pdf/manuals/bfp-10ch.pdf
ENJOY! RATE THIS SOLUTION
RNJ VINOD KUMAR
Sep 12, 2009 | Cuisinart Food Processors
Light comes on but won't pulse or turn "on."
The Kitchenaid food processors have a few safety features implimented. If the unit is not assembled properly, this may prevent the unit from turning on. I am thinking this is an issue of assembly because the light is on, so the unit is definitely getting power.
Proper assembly is below:
If it isn't all ready, please disassemble the entire unit. This means removing the blade and/or disc, blade, removing work bowl, work bowl lid, and blade.
Start by placing the work bowl onto the motor base. The work bowl handle should be facing at 9 o'clock, which is out to your left. Rotate the handle downward until it locks in at the 6 o'clock position, which will lock over the center of the button panel.
Repeat the process with the work bowl lid. The blade does not need to be present for the motor to engage, if this is an assembly issue.
Aug 03, 2009 | KitchenAid Food Processors
My kitchenaid processor is not working
Jul 29, 2009 | KitchenAid KFP715 7 Cups Food Processor
Tried to use my powerprep pluss cuisinart food processor and nothing happens. The on button lights up but nothing happens when i press the pulse button.
Remove the work bowl from the base of the food processor, and separate the bowl, lid, and pusher sleeve.
Plug the base into the wall outlet, turn the food processor ON, and then use a pen to press in the dark grey or black button on top of the base of the food processor - if you hear some kind of noise, then your motor is still good.
Put the work bowl on first, with the handle facing the front of the food processor.
Put the lid on, with the lid lined up with the handle of the work bowl.
Put the pusher sleeve in the lid, with the metal piece facing the front of the processor.
Your processor should now turn on.
If it doesn't call Cuisinart and see if you are still in-warranty (3-year warranty).
-Tha Mp3 Doctor (also loves Cuisinart)
Mar 23, 2009 | Cuisinart DLC-2014 PowerPrep Plus Food...
None of the buttons work on my Power Prep Pulse 11-CUP
Put the lid on, with the hollow feed tube facing the back of the processor.
Put the pusher sleeve in the lid, with the sliding lock switch facing the front of the processor.
If your food processor still does not turn on, call Cuisinart and see if you are eligible for an in-warranty repair - it has a 3-year warranty.
Mar 23, 2009 | Cuisinart DLC-8S Pro Custom Food Processor
I can't get my food processor (DLC-2007N) to start. It looks like everything is locked in place, and the light goes on, but the motor won't start.
Aug 31, 2008 | Cuisinart DLC-2007 7 Cups Food Processor
It won't start
The power lights go on put the machine does not run.
Nov 22, 2007 | Cuisinart DLC-5 Food Processor
My food processer does not work
I had the exact same problem. The red light came on when I hit the "On" button, but nothing happened. Then I noticed that when the lid is locked into place, a small pin in the handle goes into a small hole in the base. I took a wooden chopstick and poked it in this hole in the base, and the unit started running. I put the bowl and lid back on the unit and locked them into place, and this time the unit ran just fine. Yeah! I will remember this the next time my unit won't run even though I know that I've properly locked down the bowl and lid. Good luck!
Oct 11, 2007 | KitchenAid KFP750 Food Processor
Wolfgang Puck BFPR0015 Food Processor Logo
444 people viewed this question
Top Wolfgang Puck Food Processors Experts
EugenesDIYDen
EugenesDIYDen
L Pfaff
L Pfaff
Are you a Wolfgang Puck Food Processor Expert? Answer questions, earn points and help others
