Question about American Standard Kitchen Faucet 6310 020 White Easy Touch Pull-Out Kitchen...
I have an american standard kitchen faucet, when the handle is half open I get a leak, at home depot where I bought it two years ago, they told me I need to take it apart to see which kit will repair it. for a $70 faucet is there more than one repair kit? where do I find a number so that I can buy the correct kit?
  • 710 Answers
The single handled faucets have a valve cartridge which needs to be replaced when it leaks. Disassemble the handle to find the valve inside. Take the valve to the hardware store to be sure you get the right one and reassemble. To disassemble, pop the cap off the lever, unscrew the single screw, then use slip-joint pliers to loosen the retainer nut. lift the cartridge out with pliers taking note of the direction of the notch at the top of the stem. Be sure to reassemble with the notch facing in the same direction. You should replace and lubricate the O-rings when you change the valve cartridge.
Since you have the numbers for that particular faucet, you might want to call around to find the cartridge first. Different models have different valves, so be sure yours is correct.
Posted on Feb 25, 2011
Base of faucet leaks- cannot remove set screw at handle American Standard Elite kitchen faucet series 4453
if you are having trouble removing the set screw make sure you are using the correct size allen wrench and confirm that it is a allen screw and not a trox screw. After doing this try tighten the screw slightly before loosening it. This should break it loose.
Feb 25, 2011 | American Standard Kitchen Faucet 6310 020...
When dishwasher is running, water leaks under base of our American Standard Colony model soft two-handle kitchen faucet into cabinet beneath sink
Is there an air gap next to the faucet that is leaking. If so, it is probably clogged. Pull the cap off of it and clean it out. This is what it may look like before you take the cap off.
b7ookdehz3uf293omx2ye0fveemyn-clsycdlpsjpi2zdtnzgmj_hhepw5uyprhfsmyzy7tnfmt6uzrk1edu-duydxm839afzrsaplofdfdjymmjvj8xncabtrcoevtu5jguw1elsvyttyypguy-89xi_btsfhkvzgvdbfbda26sii9hwd8sgq
Jan 16, 2011 | American Standard 4275.550.002 ColonySoft...
We purchased an American Standard kitchen faucet model 4040 an couple of years ago. Worked great after installation, but not long after water just started coming out, both hot and cold, at a trickle. We...
I had the same problem. You need a "diverter" (044264-0070A). It's available directly from American Standard at no charge. Lifetime guarantee! Phone: 1-800-442-1902.
Aug 15, 2010 | American Standard Kitchen Faucet 6310 020...
Kitchen faucet single handle pull-out. The base of
I have the same problem with an American Standard Reliant Kitchen Faucet that wont swivel anymore. I called American Standard and they are sending me the replacement parts to fix it free of charge, I have had mine 6-7 years and they said it was under warranty. Call 800-442-1902. Good Luck
Jan 09, 2010 | American Standard Kitchen Faucet 6310 020...
American Standard Easy Touch 6310 kitchen faucet leaks at base
you must remove the faucet form the sink. under the plate in the middle is 2 screws. remove the screws to remove the body.
Jul 15, 2009 | American Standard Kitchen Faucet 6310 020...
American standard kitchen faucet leaking
soak down with WD40 and try again use a bigger wrench they all come off i have not found any that i have not been able remove!
Jul 04, 2009 | American Standard Kitchen Faucet 6310 020...
How to replace sprout seal kit in american standard faucet ?
just pull straight up,wiggle back and forth,the o-rings are holding it on .
Jun 05, 2009 | American Standard 4275.550.002 ColonySoft...
Mine leaks handle and cap (housing cartridge)
there should be a little cap covering a allen srew in the front or back of the handle it sometimes looks like the hot or cold sign or chrome pop that off and loosen the screw and pull off the handle there should be a nut loosen that and pull up the cartridge you might be able to find one at home depot be sure to turn the water supply off
May 20, 2009 | American Standard 2175.502.002 Colony Soft...
Kitchen spout leaks
Hi buffy9,
I'm Harvet the Master Plumber.
Your question is: You have an American Standard two faucet in my kitchen and the base of the spout leaks at the base. How do you remove it and replace the washers?
Are we talking about an American Standard two HANDLE faucet or one of the single handle models?
Thank you,
Harvey your Master Plumber
Oct 16, 2008 | Plumbing
American Standard Kitchen Faucet 6310 020 White Easy Touch Pull-Out Kitchen... Logo
465 people viewed this question
Top American Standard Plumbing Experts
Donni Steen
john h
TED
Level 1 Expert
Are you an American Standard Plumbing Expert? Answer questions, earn points and help others
