Question about HP PSC 1350 All-In-One Thermal Printer
Paper won't feed
The paper will not feed. Is there any way to adjust feeders & can best buy service the printer?
  • june herschell Jun 15, 2008
    plain paper prints ok photo paper starts to feed then jams
    have tried different settings also different photo papers ie gloss matt and also weight of paper
  • Anonymous Jun 19, 2008
    I just tapped my printer and now when it tries to get paper it sounds asds though a belt or gear is not on track. The paper won't feed automatically or manually and it assumes it is empty.
My paper wont feed.please help
Posted on Sep 15, 2008
Epson 810 automatic feeder won't feed
do you let the paper get pulled by it'self? Maybe try to push it and maybe it will grab it better to pull through...if not try a shop to fix or buy new one.
Sep 09, 2012 | Epson Artisan 810 AllInOne InkJet Printer
My Lexmark printer 2600 series won't print. It pulls the paper towards the right but won't feed it. How can I fix this?
Leading cause of paper jams is debris/foreign objects that accidentally fell into the paper feed area. Please follow steps below to fix the problem:
1. Remove the sheets of paper from the feeder.
2. Grab a flashlight and look inside the feeder for any debris or foreign objects.
3. If you're willing and physically able, you may also turn the printer over. Any debris should just freely roll out from the feeder.
4. If feeder is clear, place the printer back on the table, open the printer cover and remove the cartridges.
5. Check the cartridge area for any obstructions/debris in the cartridge carrier's path or the paper path.
6. If cartridge area is clear, close the cover.
7. Re-brick your printer. Pull out the power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds.
8. When the printer turns on, reinsert the cartridges and load some paper. Try to print a document again to verify that the problem is fixed.
If problem continues, please contact Lexmark Technical Support Center for additional assistance.
Sep 03, 2011 | Lexmark X2600 InkJet Printer
Lexmark X85 won't feed paper. When trying to
There could be something in the paper feeder that's blocking the paper path. Please follow steps below to identify and fix the problem:
2. Grab a flashlight and look inside for any debris.
5. Check the cartridge area for any obstructions/debris that could cause this error or problem.
7. Unplug and re-plug the printer into the power outlet to reset it.
8. When the printer turns on, reinsert the cartridges and load some paper. Try to print again.
ns Serif"'>6. When the printer turns on, reinsert one cartridge first.
7. Close the printer cover and check for any errors.
8. If no error appears, reinsert the other cartridge. Close the printer cover.
9. Replace whichever cartridge is causing the error to appear with a new cartridge.
Jul 11, 2011 | Lexmark X85 All-In-One InkJet Printer
Paper feeder stuck
If the paper feeder stuck, do the following:
  1. Gently pull any jammed paper out from the output tray or sheet feeder.
  2. If paper is stuck inside, open the printer cover and remove the jammed paper, including any torn pieces. Then close the printer cover.
  3. If paper remains near the sheet feeder, press the paper feed roller lever inside the paper feeder to release the jammed paper, then carefully pull it out.
  4. Load the paper correctly.
  5. Press the cp_button_14.gif stop button to resume printing.
  • If the printer continues to jam or misfeed paper, and you are certain that there are no foreign objects lodged down inside the paper feed area, your printer may require service. Please call Epson technical support for further assistance.
  • Jan 29, 2011 | Epson Office Equipment & Supplies
    Put new roll in printer and paper feeds through then goes back out again
    The printer should accept print paper ready for feed commands when computer sends jobs with clicks. A paper feeder tray may be clogged, attempt to open compartments to ascertain for misaligned or adjusted entrapment areas. Paper feeder adjustments that are tightened least allows feeder processing while loosened paper feeder clips allows several print papers at a time. Select the appropriate adjustment for the papers. Second, printers that run out of ink display sensitive malfunctions either as inability to feed paper when available. Ascertain that printer ink is available.
    Jan 28, 2011 | HP PhotoSmart 130 InkJet Printer
    Paper didn't feed or feeder can't feed paper
    Replace Feeder sensor its a plastic piect the is a sensor that detects there is apaper in the feeder paper path, when these go bad the thing does not feed, or says your out of paper.
    T will probably cost you more to have it repaired then getting a new canon or whatever all in one youe decide to buy.
    thanks i hope this information finds your helpful ratings and feedback, have a good day.
    May 03, 2010 | Canon PIXMA MP130 All-In-One InkJet...
    As paper goes in the printer it feeds it in side ways causing
    you issue is clear to me that you got some rollers in your feeder that are jammed up or just not feeding the paper correctly.
    The fix:
    You need to buy a new autofeeder for this printer. You can leave auto out of my volcabulary if you just want to call it a feeder. the issue is over time and use these feeders get worn out or get jammed so many times they just sop working.
    Now a new feeder $45 bucks now you need to think will this cost me more then just buying a new printer. Chacnes are yes just a tad under with labor. I am not saying "buy a new printer" I am opening the door to the idea if you just do not want to put up with fixing this.
    Thanks and please do be considerate and leave your positive ratings and feedback.
    Apr 29, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
    Not feeding
    Have you still getting the problem, have you done cleaning of Cartridge, its nozzle and Contact strip.. then cleaning of Printer roller or carriage rack.. Do a Service of it or get it done by Technician.
    Also check the feeder tray.. to grab paper one by one by printer.. Manually
    Take all updates for printer and OS.
    Oct 31, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
    Feed problem
    dear colmaj
    your printer paper sensor is strucked or malfunctioned.please open the printer and check for any dislocation of the sensor.or you send your printer for service
    Mar 11, 2008 | Canon Pixma MP500 All-In-One InkJet...
    HP PSC 1350 All-In-One Thermal Printer Logo
    175 people viewed this question
    Ben Johnson
