Question about Sony Grand WEGA KDF-60XS955 60" Rear Projection HDTV
Has a blue ring around the outter edges of the screen
    Sergeant:
  • 171 Answers
Hey there it sounds like your LCD chips are burning out and the problem will just get worst if you don't replace the OPTICAL BLOCK is your TV under warranty check this out Sony got a lawsuit for there bad OPTICAL BLOCKS
http://www0.epinions.com/msg/show_~threads/cat_id_~13/id_~9877/forum_id_~127
PLEASE RATE THIS SOLUTION AS I DO THIS FOR FREE !!!
Posted on Oct 08, 2010
Laptop screen replacement
If you've removed the screws that is on the plastic that is around the outter edges of the screen then use a little force with your fingers to pry the plastic bezel apart from around the screen. Normally this is snuggly snapped into place around the screen. Surely some knucklehead did not apply glue to it.
Mar 10, 2012 | Computers & Internet
I have a Sanyo PLV-Z3 HD projector in my basement and I'am have dust problems with it. I have gone through the steps outlined in the owners manual to remove the dust. Right now it looks like a...
DONT use your compressor.
Most have oil lubrication and will give out oil droplets.
Use canned compressed air to blow the dust away.
Please dont forget to vote this answer was helpful.
Many thanks
Feb 28, 2011 | Optoma HD70 DLP Projector
MY BELLOW RING came off....How does it go back on? Secondly and where?
If you are referring to the outer bellow clamp that consists of a wire hoop with a small spring, it is installed in a groove along the outer lip of the door bellow after it is seated around the perimeter of the door opening. To reinstall, follow these steps:
1. Install the door boot back over the frame of the door opening. Ensure you fit it snugly all the way around the door.
2. Beginning at the top of the door, start inserting the wire hoop back into the groove. Make sure to wire spring points towards the bottom.
3. As you work your way around the door to the 4 and 8 o'clock positions, you will need to maintain some constant downward pressure while pulling the spring apart in order to snap it back into place.
NOTE: To make it easier, you may want to use a second set of hands to hold the wire hoop in place while doing this as it has the tendency to want to come out of the groove.
If you have any questions, please let me know. I hope this helps you.
Oct 10, 2009 | Kenmore HE2 Plus Front Load Washer
How do I get the light cover off to replace bulbs? I have a sidewinder
While applying light upward pressure evenly around the outter edge of the lens turn counter clockwise about an eighth of a turn. then lens should come straight down. if lens is siezed some light tapping around the edge of the lens should free it up.
Aug 18, 2009 | Hampton Bay Sidewinder 04890 Ceiling Fan
How to clean inside of screen?
Your tv has two screens on it. The outter screen and the inner screen. The outter screen has a frame around it held on by clips. You can remove this outter screen by gently prying it from the tv. There is a small gape between the outter screen and the tv casing. When prying the outter screen be carefull not to dsanage the tv case or the outter screen frame. Take note of the location of each clips because you will need thses to put the outter screen back on. Clean with a good gentle screen cleaner, (Do Not Use Windex). Philips screen cleaning gel for plasma & LCD works very good. Install the outter screen back on the tv by making sure the clips line up and use light pressure to snap it back in place. Do Not Hit Outter Screen To Force Clips Into Place.. I do this on my tv about once every 6 months or so.
Jan 04, 2009 | RCA P61960 61" Rear Projection Television
2005 Chevrolet Silverado 1500 2WD Repair
i'm not certain, but i'll give it a shot. (I have removed panels from several other autos and they were all the same)
to remove the inner panel,
remove all screws- there should be around 8 or so- there should be one in the plastic shield around the door open handle, and one in the arm rest, and the rest should be around the outter panel. after the screws are removed, you should be able to pop the clips out, use a flat head screw driver and put light pressure to pry it off- careful to not break them.
to remove the outter panel
open door- obvously- remove the outter door handle and mirror. remove the seal on top of the panel (black, protects window) you will need a flat screw driver, carefull not to chip paint- it pops right off. now, from the inside, look around the outter edge, there are hex head screws holding the panel on, it is much easier to start on the side closer to the chasis of the truck. After all screws are removed, slide the panel- easily- toward the truck, (there is a small clip by the mirror mount that has to be dislodged when you slide it)
hope this helps! :)
Nov 25, 2008 | 2005 Chevrolet Silverado 1500 2WD
Dell latitude D600 battery charge light flashing
my suggestion is that you allow the batteries to fully recharge(which only happens when the computer is fully off, when the battery is deep discharged.
that will take around 6 to 10 hours each..
Mar 10, 2008 | Dell Inspiron E1505 Notebook
Colored Circles
sounds like the degausing coil isnt working or you have a speaker close by.
Dec 04, 2007 | Panasonic CT-36D32 36" TV
Colored Circles
check the degassing circuit and replace the degassing relay, then use a degausing ring to bring the colors back to normal you should be ok. good possiblity a bad solder connection at the degausing circuit themister.
Mar 17, 2007 | Panasonic CT-27HL14 27" TV
Sony Grand WEGA KDF-60XS955 60" Rear Projection HDTV Logo
367 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
