Question about JVC Everio GZ-MG21 Camcorder
How can i buy LYB10058-001A rear pwb assy - JVC Everio GZ-MG21 Camcorder
    President:
  • 4,070 Answers
Hi! May I ask for clarification regards the rear assembly? Thanks
Posted on Oct 09, 2010
  • 10,594 Answers
Required board can only be available with JVC Parts Store
LYB 10058-001A part number sounds its only circuit board where as below is correct part number for Rear PWB Assy for MG-MG20U camcorder.
Part Number: LYA10058-01D
Description: REAR PWB ASSY
Unit Price: $58.15
ETA: In Stock
Click on JVC Support link then look at left of page, click on "Model Parts Look-Up" link, put your camcorder model number GZ-MG20US to have complete available part list, then look at bottom of list for Rear PWB Assy price info. Place online order for required board/ part.
Hope these info will help you.
Thanks.
Posted on Oct 08, 2010
  • Shahid Electronics
    Shahid Electronics Oct 09, 2010
    You can accept solution to close question thread,
    Thanks.
Part number 610 332 8126 ASSY,PWB,MAIN KE3A
You can try to find this part at MGM electronics on the internet.
Jun 20, 2012 | Sanyo Office Equipment & Supplies
Tip
DISSEMBLING AND POWER SUPPLY CIRCUIT
1. REMOVING OF REAR CABINET
1. Remove the 11 screws [1], 3 screws [2] and detach the Rear Cabinet.
2. REMOVING OF CONNECTORS, SPEAKERS, STAND COVER ASSEMBLY AND STAND ASSEMBLY
1. Remove all the connectors from all the PWBs.
2. Remove 2 screws [1] and detach the Speaker-L and Speaker-R.
3. Remove the 2 screws [2], 4 screws [3] and detach the Stand Cover assembly.
4. Remove the 4 screws [4] and detach the Stand assembly
3. REMOVING OF PWB UNITS
1. Remove the 1 screw [1] and detach the R/C, LED PWB Unit.
2. Remove the 6 screws [2] and detach the MAIN PWB Unit.
3. Remove the 4 screws [3] and detach the POWER PWB Unit.
4. Remove the 4 screws [4] and detach the INVERTER PWB Unit.
5. Remove the 1 screw [5] and detach the KEY PWB Unit..............CHECK THE LINK FOR MORE INFORMATION
Electronics Equipment Repair Center
on Feb 14, 2015 | Sanyo Televison & Video
Sir, I have Cannon IR 6570 Error Code E0000013 appear tonight, Please guide me how to solve
You have problem with waste toner assembly. You should remove rear covers, and pwb`s from backs, and then remove waste toner assy.
then check is auger damaged. It is possible to repair auger.
Sep 07, 2011 | Canon IMAGERUNNER 6570 Copier
The thumb wheel doesn't in fuji s5600 seem to change any of the modes i newed a scheme of msw pwb assy part assemble
Open the camera and repair the switch, you will find the spigot has broken and it is easily repaired with glue etc. Where would you buy the part if you had a schematic?
You can buy a manual here:
http://www.tradebit.com/filedetail.php/93892042-fuji-finepix-s5200-5600-service-repair-manual
I hope I have been of help but please do not hesitate to ask if you have any further questions.
I appreciate your vote if you appreciate my reply.
Feb 26, 2011 | Fuji FinePix S9500 Zoom Digital Camera
Both rear shock's are bad need a picture ofhow they are disassembled any help with be good
this car does not have rear shocks, it has struts, you will need a strut compressor to replace them, also this model has a problem with the upper bearing mount they go bad a lot and make a knocking noise when you hit a bump. try this see if you can by the strut as a complete assy. they are offered that way but not by all parts stores. if you buy them as an assy. them all you have to do is jack up the rear of the car and put jack stands under it, remove the rear wheels, open the trunk and get in remove the carpet/cardboard covers over the wheel wells, and remove the 3 nut that hold the top of the strut assy. then remove the lower mount bolts. and swap out the hole-assy......HAVE FUN
Nov 18, 2010 | 1994 Pontiac Grand Prix
EPSON C1100 E 510 EROR
E510 idicate the ROS motor faulty... PWBA MCU could not receive signals output from SOS Sensor in ROS within the specified time.
Possible cause ROS assy, PWB MCU, Harness PWB, or LVPS..
but before you change any.. make sure all your cover are close properly..normally the fuser cover interlock switch can cause this error as well.. check the switch at the right side of the fuser cover...make sure it's not deform .
May 21, 2010 | Epson Aculaser C1100 Printer
Westinghouse LF708C fault code SE. not spinning. what needs to be fixed?
SE refers to a sensor error, remedies include checking all connections plugs: § The connector (5pin, male, white) in the Wire Harness is not connected to the connector (5 pin, female) of Hall Sensor in the MOTOR. ?_? reconnect or repair the contact in the connector The electric contact between the connectors (5 pin, male in the Wire Harness and 5 pin female in the Hall Sensor) is bad or unstable. ?_ Reconnect or repair the contact in the connector ? The connector (6 pin, male, natural) in the Wire Harness is not connected to the connector (6 pin, female, natural) of PWB ASSY(Main) or the electric contact of connectors is bad/unstable. ?_ Reconnect or repair the contact in the connector ? The electric contact between the connectors ¡a6 pin, male in the Wire Harness and 6 pin female in the controller(Main)¡bis bad or unstable. ?_ Reconnect or repair the contact in the connector ? The Wire Harness between Hall Sensor in the MOTOR and PWB ASSY(Main) is cut(open circuited). ?_ Repair/replace the damaged WIRE HARNESS ? The Hall Sensor is out of order/defective. ?_ Replace the Motor ? The controller(Main) is out of order/defective. ?_ Replace the PWB ASSY(Main)
Jan 22, 2010 | Westinghouse Washing Machines
Error 9-363
Try to clean the dev rotary sensor. open the upper right hand cover then there are two assy's to be removed also for you to access the rotary sensor located inboard side. this sensor senses the home position of rotary developer. to removed this sensor, you have to open the rear cover, then rotary pwb. some 9-363 code is due to busted fuse in the rotary pwb. Thanks for using Fixya !
Feb 07, 2009 | Xerox Document Centre ColorSeries 50 Laser...
Printer fault (phaser 7700)
Here is the Diagnostics.
04-361 DRUM MOTOR DRIVE FAIL
EXPLANATION
Poor Drum Motor rotation.
Refer to BSD: CH9.1 CH9.1
Procedure
Remove the Drum ASSY (Y/M/C/K), execute DC330 [004-003].
Does the Drum Motor rotate?
Yes No
Between Drum Motor J210-4 (+) GND (-)
Is the voltage +5VDC?
Yes No
Using the wire network from Chapter 7, check the +5VDC circuits up to Drum Motor J210-4. (WN7.3.6 +5VDC-2)
Between Drum Motor J210-6 (+)GND (-)
Is the voltage +24VDC?
Yes No
Using the wire network from Chapter 7, check the +24VDC circuits up to Drum Motor J210-6. (WN7.3.13
+24VDC-3)
Execute DC330 [004-003].
Between Drum Motor J210-1 (+)GND (-)
Is the voltage 0 VDC?
Yes No
Between MCU PWB J407-B1 (+) GND (-)
Yes No
Check for broken wires or bad connections from Drum Motor J210-1 to MCU PWB J407-B1, and if there
are no problems, change the MCU PWB. (PL5.4).
Check for broken wires or bad connections from Drum Motor J210-1 to MCU PWB J407-Bq
Between Drum Motor J210-2 (+) GND (-)
Is the frequency between 1KHz and 1.3KHz?
Yes No
MCU PWB J407-B3 (+) GND (-)
Change Drum Motor. (PL1.1).
Dec 27, 2007 | Xerox Phaser 7700 Laser Printer
JVC Everio GZ-MG21 Camcorder Logo
91 people viewed this question
Top JVC Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
