How do I fix error code 49.4C02 on a HP 4700 color printer?
  • 570 Answers
This error code code comes because of outdated firm ware you just have to update the firm ware and solve the problem.
Update the firmware on the HP Color Laser Jet 4700 printer to version 20091125 46.120.4 or later. This new firmware resolves the issue.
Thanks.
Have a great day.
Posted on Oct 08, 2010
  • steeve ekoue Mar 18, 2011
    thank you very much that was really helpfull
Error code 59.90 on color laserjet 470
59.9 is SCANNER MOTOR ERROR.
It is a rather tough part to service.
The entire scanning assembly would have to be replaced.
see
HP Color LaserJet 4700 Series Printer Numerical Control Panel Error...
Nov 01, 2016 | HP LaserJet 4700 Printer
Error code 59.90 on color laserjet 4700
Transfer belt motor error, either a bad motor or a bad transfer belt.
I have a problem from hp laser colorjet 47OOn whith code error is 54.15
54.15 PRINTER ERRORDescription There is a problem with the Yellow CPR sensor.Action
  1. Turn the printer off, and turn it on again.
  2. Clean the color registration detection sensor above the black print cartridge if the error does not clear.
  3. If this message persists, contact HP.
Dec 27, 2012 | HP LaserJet 4700 Printer
Color Laserjet 5550dn code d'erreur 54.15
54.15 PRINTER ERROR Description There is a problem with the Yellow CPR sensor. Action
Jan 05, 2011 | HP LaserJet 4700 Printer
I have a 50.2 fuser erro on our Color Printer HP 4700
The 50.2 code on nearly all HP laser based machines including your 4700 means you have a fuser error. The fuser unit is the assembly that heats up and "fuses" the toner onto the paper. There are a few things you can try including, power cycle the printer and see whether the code resets or try reseating the Fuser Unit. Neither of these will resolve the issue in most cases. Most of the time fuser unit replacement is necessary.
Here is a link for you to see pricing and a picture for your fuser unit. You may want to just buy your own fuser and replace it if your are mechanically inclined. If not you can have a local printer repair shop replace it for you. At least they won't rip you off on the price of the fuser unit. Note that there may be some cheaper prices out there on this unit.
http://www.precisionroller.com/search.php?q=hp+4700+fuser
Good Luck and Thank You for using Fixya.
WheatlandServices
Dec 23, 2010 | HP Color LaserJet 4550hdn Printer
Thank you for contacting FixYa with your inquiry.
The HP4700 Printer The HP 4700 is a family of color LaserJet printers intended for use by work groups and small offices. The printer itself differs little from model to model with accessories including wireless printing options and various paper tray configurations.
Error Code 'Service Error 49.2' According to the user manual, 49.X error codes mean, "a critical firmware error has occurred." Firmware is Software that ties to specific hardware components. While occasionally this means hardwired programming, installed drivers often feed programming and instructions to modern devices.
Correcting the Error Firmware errors can often be corrected by turning the device off and on again. If this fails to correct the issue, reinstalling the driver software may correct the problem. If the problem persists, HP technical support should be contacted.
Hope this helps helps. Please keep us updated and remember to rate this answer.
TF
Dec 07, 2010 | HP LaserJet 4700 Printer
I Have Fault Codes on the Display.
Problem solve someone tried to print a PDF file which lodged the fault our It Dept deleted the print spool and Re-set the printer all ok.
Jan 14, 2010 | HP Color LaserJet 5550hdn Printer
I have error code 51 and 21 on the printer. I
21 is "Page too complex"
51 is "Beam detect error" or "laser error"
My question to you is, does this only happen when you are printing a page that is very graphics intensive, or does it happen with simple jobs too? It could be that you just don't have enough memory in the printer to handle some of these pages. Then again, you may have to replace the laser scanner. I advise you to call a tech out to take a look at it rather than trying to fix this on your own.
If it isn't happening too often I'd probably just **** it up and live with it if it were me. If it is getting in the way of business though you really ought to call a tech. A lot of times these things can be fixed for a lot less $ than you'd think.
Dec 22, 2009 | HP LaserJet 4700 Printer
49,4c02 error to continue turn off then on
I would try clearing your print que as it could be a corrupt print job and disconnecting your network cable and reboot the printer, make sure you have the latest firmware. hope this helps
Nov 24, 2009 | HP LaserJet 4700 Printer
Hp color laserjet 4700dn error code 59.30
turn off the printer. remove the duplex device from the printer. turn on the printer. enter the diagnostic menu. enter the menu for sensor and motors. select the fuser motor and let it run. if you can hear it its ok (its not such a noicy one ... you have to listen very good) - follow up the next steps:
turn off the printer. turn on the printer. enter the service menu - pin code is: 09470005. set to 0 all counters for mono print, color print and the counter after service. leave the menu.
turn off the printer, reinstall the duplax device. turn on the printer.
result: the error msg is gone. its just HP wants to sell theyr service contracts.
Feb 25, 2009 | HP LaserJet 4700 Printer
Computers & Internet Logo
1,743 people viewed this question
David Payne
David Payne
