My phillips 52" flatscreen makes a clicking sound by the on/off switch. Sometimes the TV will go off and come back on by itself, not due to a lost of signal.
On the lower right side of the psu, (clamped to a heatsink), i changed the 8.5v (L4940P85) voltage regulator and it worked. As a test to single out the fault i warmed this component with a fine blue flame, this would make also make the tv work perfectly.
If the TV menu displays your problem is most likely not the Tv , but is caused by the signal source:
Cable box or connections. Reboot everything test using other sources like a DVD player to isolate the problem.
I had a similar problem with my Phillips 42 in. LCD HD TV.
Here's the problem. The Power Supply Board. I opened my TV
up(warranty was up of course) and found several bad capacitors.
Phillips and several other companies were sold capacitors that although
were highly rated failed within 5 years because of a lack of
preservatives. All sorts of electronic equipment is now being effected
due to these defective capacitors.
Solutions?
1. Take it in and have it fixed
2. Open it up, check the board for faulty capacitors(bulged or leaking) Buy a new Power supply board and install it.
3. Remove PSB, remove faulty capacitors and replace with compatible new ones.
Solutions?
Power supply board it dead.Replaced the power supply board to get power back.Tries Shopjimmy.com,Ebay.com to buy a refurbish power supply board for replacement.
Most likely it has some bad capacitors in the power supply. Flat--panel sets are VERY hard on capacitors, due to the fact that the "rising heat' from the set "cooks" the caps and they fail VERY early.
Solutions?
