Question about Cub Cadet Op's Manual Model Lt1042 Lt1045 Lt1046 Lt1050
I forgot how i took my drive belt off my mower n i cant put the new one on its a LT1045 built in 04/26/07
    Problem Solver:
  • 7 Answers
I just got on www.cubcadet.com, went to the residental lawn mower section, used the side bar on the left hand side of the screen and clicked on Operators Manuals. its going to bring up a different window; for the model type in: Lt1045- for the serial number, just type in any numbers. after it loads, click on the first operator manual selection you see. after it brings the .pdf file, it should be pg.25 it has the diagram of the belt routeing. i hope this helps, i would have sent u, or loaded it on here, but its copywrited, so, you have to get it on your own. like i said tho...i hope this information helps u. Good Luck :)
Posted on Nov 11, 2010
Yth2248 loses speed on slightest grade. new drive belt not helpful
Roy if it is the correct belt and fairly new, check your manual for belt adjustment, if it shows that there is no adjustment the pulleys may be worn out, on a lot of mowers the pulleys are ware items and changed more often to correct slipping issues. The other thing to check is the belt tensioner if equipped, it could be seized, weak or missing spring or it may even be adjustable by cable end being threaded or slotted bolt holes on tensioner arm.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Drive Pulley Replacement On Craftsman Lawn Tractor
Mower Engine Pulley Replacement Craftsman Riding Lawn Mower Repair Part...
Cub Cadet LT1045 Transmission Drive Belt Replacement
husqvarna LGT24k54 drive belt install
Apr 22, 2016 | Garden
Is there some sort of tension adjustment for the hydrostatic drive? The belt is not turning the drive but everything is hooked up. I found that the belt had come off of one of the pulleys earlier in the...
My GT 1052 has a spring loaded idler pulley to maintain traction on the belt. If the belt came off a pulley once, it's probably stretched or some of the internal cords have broken, allowing it to twist and come off the pulley. You should replace it immediately. One Note: Be SURE to get a belt with Kevlar - I used a lesser belt the first time, and it only lasted a short while. Considering the amount of effort to change the belt, it's better to buy the slightly more expensive one's with Kevlar as they last MUCH longer.
Sep 01, 2013 | Cub Cadet Op's Manual Model Lt1042 Lt1045...
I have a 2007 Cub Cadet Series 1000 Model LT1045 Does this model have a drive belt or is that belt just to run the fan on the tranismission.
hi there pauly46 here your model 2007 and before lt1045
take a look at this web site
http://www.partstree.com/parts/?lc=cub_cadet&mn=LT1045+Tractor+%282007+%26+before%29
this takes you stright to transmssion / belt drive system
http://www.partstree.com/parts/?lc=cub_cadet&mn=LT1045+Tractor+%282007+%26+before%29&dn=0125500003
this diagrams shows belts etc in the drive system , fan, trans etc
your answer is it does have a trans belt it is part number 954-0461
was pt number 754-0461
take a look at this site
cheers hope it helps
pauly 46
Diagram: LT1045+Tractor+%282007+%26+before%29 Drive System 1I136H & before CUB Cub Cadet 954-0461 (replaces 754-0461)
Apr 29, 2011 | Cub Cadet Op's Manual Model Lt1042 Lt1045...
Cub cadet model LT1045 belt coming off the pulley for cutting deck?
FINAL SOLUTION TO FIX THE BELT FROM COMING OFF LT1045 WHILE MOWING!
I also had this issue with my LT1045 belt. However, I just figured out how to finally fix / re-engineer my LT1045 Cub Cadet from having issues with the belt coming off of the deck while mowing.
Taking it back into a shop for repairs will not work, the belt will just come off again the first time you mow. I am making a YouTube Video to help others like me with this mower issue and will post a link here soon showing how to fix this design flaw.
It took me about an hour to fix but I've got it working now with no problems, minimum vibrations and belt is running cool now! I've gone for 2 months with no problems now. Check back soon for the link!! I expect I will have the video tutorial finished within a week!!
- Mike
If you for some reason you cant
Jun 05, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Lost manual. cant take the blades off and put on
use a block of wood in the discharge chute to keep the blades from turning, loosen them all before you take the blocked blade completly off
Mar 17, 2009 | Garden
Cub Cadet Op's Manual Model Lt1042 Lt1045 Lt1046 Lt1050 Logo
603 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
Matt Olenzek
Matt Olenzek
dannydoesita
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
