Question about Kenmore Kitchen Ranges
I have Model No. C970-657932 and the Oven light Bulb keeps blowing out.
My Neff oven keeps blowing bulbs, immediately a new bulb is fitted it blows like a fuse.
Maybe your First bulb in the oven is a 220 volt bulb not a common 110 bulb? Good luck.. BCB...
Oct 23, 2016 | Neff Ovens
Oven light keeps blowing
get a hard duty oven bulb
May 20, 2015 | Kitchen Ranges
Why do oven lights keep blowing?
make sure the bulbs your using are rated for "appliance duty" if a plain normal house bulb is used the glass is too thin and heat ruins bulb in short time , also make sure heat resistant bulb cover "if there" is in place and not part ways off to one side or the other
May 18, 2015 | Kitchen Ranges
How do I change the bulb inside the cooker of the B5741 cooker
Oven Lighting
Warning: There is a danger of electric shock! Prior to changing
the oven light bulb:
  • Switch off the oven!
  • Disconnect from the electricity supply.
Place a cloth on the oven floor to protect the oven light and glass cover.
Replacing the oven light bulb/cleaning the glass cover
  1. Remove the glass cover by turning it anticlockwise and then clean it.
  2. If necessary:
Replace bulb with a 40 watt, 230 V, 300 °C heat-resistant
oven light bulb.
3. Refit the glass cover.
Dado
Apr 15, 2015 | AEG Ovens
Was removing a burned out bulb in my LG LMVM1935SB LG Microwave cooktop/oven. The bulb broke, and we had to finish getting the bulb out of the receptacle. The other light worked, but now apparently is...
When removing a bad bulb ALWAYS unplug the unit. If there is power going to the bulb and when you try to take the bad bulb out and the glass seperates from the bottom base the leads will short out and you will blow your main curcuit board. Then the entire board must be replaced. It will blow out a component on the board or blow a trace off of the back of the board. either way either baord repair or replacement will be needed. ALWAYS UNPLUG THE UNIT WHEN REPLACING A BULB!!!!
Sep 18, 2017 | LG LMVM2075 Microwave Oven
My light bulb keeps blowing i have replaced it twice with a 25watt and as soon as i switch it back on the bulb blows
Perhaps you have up to 240 V on the lamp socket and you are installing a 120V bulb. Check for wiring faults, especially an open neutral or ground connection in the oven. If the lamp socket neutral is connected to the neutral on a lower-resistance device on the other leg, but the wire connecting these two items is not connected to the power cord neutral, the voltage across the bulb will be more than it can handle. In this scenario, the other device (heating element, timer, or whatever) will probably not work or will work poorly after the bulb blows.
Nov 04, 2010 | Smeg SE210X/1 Stainless Steel Electric...
My oven light bulb keeps blowing on my Whirlpool oven.
becoz of some problem that might be your oven is on for long time
Apr 10, 2010 | Ovens
Replace oven light bulb? magic chef wall oven
for model 9815xub, the oven light consists of a light bulb cover(clear plastic, sometimes called lens) the light bulb receptacle( pressure mounted against the back wall of the oven ) and the light bulb, standard appliance bulb that screws into the receptacle, the same as the lens, it also screws into the receptacle, twist counter clockwise to remove both the lens and the bulb. as a reference try the following site:
www.partselect.com/ and type your model number in the window, then click on the oven cavity breakdown to view thwe assembly.
Jan 31, 2010 | Whirlpool RBS275PD Electric Single Oven
How do I change the light bulb in the oven
You can replace the light bulb(s) in your range/oven, though you may need to remove a glass covering or dome to reach it. Most interior oven lights use a universal 40 watt appliance bulb.
Apr 24, 2009 | Philips Ovens
Model JVM130G
what brand is this and did the light go on when the door was opened before you changed the bulb?
Jun 18, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Kitchen Ranges Logo
102 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Mike Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
