Question about HP LaserJet 3050 All-In-One Printer
Low memory We are getting the low memory message on the printer...what do we need to do?
Posted on Jun 16, 2008
I have a fax in memory how can I retrieve it
Usually, faxes are temporarily sent to the printer's memory when one of the cartridges' ink level is not substantial for printing. You are advised to replace the cartridge/s, *without navigating away from the message "fax sent to memory", by opening the printer cover and replacing the low-ink cartridge/s. After the new cartridge/s is installed, close the printer cover and press OK button to let printer print the fax stored in the memory.
* Make sure not to navigate away from the "fax sent to memory" message. You will lose the fax-in-memory data once you turn off the printer or navigate away from the message.
Oct 31, 2011 | Lexmark X6570 InkJet Printer
I have an old HP laserjet 3330 that has just started to give me the message when i ask it to print a PDF that its memory is low. can you please help.
Hello and assalam aliekum
Mr. Mahmood
This is a problem with physical low memory you need to add more memory on your printer's formatter board. But at the same time try to erase the old stored fax under Fax settings in the printer. As they hold much of the memory and they need to be flushed out.
Try inshallah it shall be done.
Do rate my solution.
Saleem Ahmed
Jun 29, 2011 | Office Equipment & Supplies
Lexmark X5650 says faxes in memory. Already went to another mode. How do I get faxes out of memory?
Once you navigate away from the fax mode when a fax message goes into memory, you will lose the message. If this happens again, try not to navigate away from the fax mode. The "fax in memory" message usually pops up when the printer's not able to continue printing the fax due to a very low ink level. Just open the printer (w/o navigating away from the fax mode) > replace the ink cartridges > close the cover > print the fax.
May 28, 2011 | Lexmark X5650 All-in-One InkJet Printer
I am getting "memory is low/ insufficient memory" in my hp laserjet M2727 printer. what should I do?
The internal memory is full try a nvram.
1. Turn the printer off
2. Hold down the right arrow and the cancel button
3. Reboot the printer while holding the buttons and hold until permanent storage is displayed. Let go of the buttons and wait for the ready message on the display.
This reset will clear all of your saved settings and contacts, if networked print out a configuration report after resetting the printer to view the ip address (IPV4). If the IP address has changed you will need to update the print driver's port tab and update the port.
Al
May 21, 2010 | HP LaserJet 3050 All-In-One Printer
Trying to send a fax, getting a MEMORY IS LOW message. Dispaly goes on to say PRESS OK, and when we do, the send is canceled. Doesn't matter if we are faxing one page or multiple pages.
trying to send a fax, getting a MEMORY IS LOW message. Dispaly goes on to say PRESS OK, and when we do, the send is canceled.
Apr 27, 2010 | HP LaserJet M1522nf Multifunction Printer...
Getting a "low memory" message on a Optra S 1255
Go to the menu settings page and print out your settings and see how much memory you have installed.
Next, low memory messages usually point to a data flow control problem or a very busy document.
Create a very simple page of text and send it to the printer. Do you get the same error message?
If you do, then you may need to replace the memory simms because of component failure. It could also be the motherboard.
You may want to consider having the unit serviced.
Don
Mar 02, 2010 | Lexmark Optra S 1255 Laser Printer
We keep getting a memory is low message. How can
You cannot clear about the memory. When it says that, it's referring to the random access memory (RAM) Long explanation short, your computer doesn't have enough RAM. You can purchase a stick of ram from http://newegg.com for about 30-50 dollars.
You need to know what type of ram you have, so ask someone you know that's good with PCs, or get CPU-Z and check yourself.
Dec 16, 2009 | HP LaserJet 2840 All-In-One Printer
DC PROGRAM NOT VALID
Usually with this error the program checksum for the printer controller is corrupt or the data controller memory is corrupted.
You can try redownloading the program into the printer or it's possible it also has bad Flash Memory.
Jul 15, 2009 | Printronix Line Matrix P5005B Printer
HP LaserJet 3050 All-In-One Printer Logo
961 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
