I purshed this tv used but when i plugged it up it didn't come on what can i do?
  • 55 Answers
Take it to a local TV Shop
Posted on Oct 08, 2010
How to open purshe boxter hood manually
hello there
for that reason(dead battery) Porsche made an Emergency operating cable.Send me an email and i will send the picture.The cable is located in your right front fender behind the black plastic lining..
proporsche@yahoo.com
proporsche
Aug 23, 2011 | Porsche Boxster Cars & Trucks
Can't access all the channels. I moved tv from one
You didn't say what model number, but check the setup menu to make sure it is set for cable (if you are using cable) and not AIR. Otherwise let me know the model number and what you are using for signal (cable, satellite, etc.)
Jul 04, 2011 | Sharp Televison & Video
I have a 42inch sharp aquos LCD tv and there is no power. The power button keeps blinking. There is no picture and sound. What is the fix to this problem.
Power problem are cause by many reasons, i.e Power supply circuit, Lamp driver circuit and most often the TV detects an error cause by power surges. To protect TV from further damage most LCD TV have protection circuit built internally. If this is the reason of your LCD TV not powering On, an error data must be reset back to zero.
To change data you will need to access the service mode and change the value of lamp error code to zero (0). Entering service mode requires a trained TV technician. Changing data can cause more problem to your television. If you are not qualified to service your television, please do not go to service menu codes. Moreover below are the process, pls do so at your own risk.
* Unplug the TV * Press and hold the {VOL -} + {CH+} buttons located on LCD TV unit (not in remote control) Note: If above didn't work, alternately use (VOL -) + (TV/AV input) buttons located on LCD TV unit (not in remote control) * While holding the above buttons, plug in the TV. * The TV will turn on with the "K" or "K123" appears om screen. * Use {CH+} {CH -} buttons to go and display the service menu. Note: If above didn't work, alternately use (VOL -) + (CH -) buttons. * Search for "LAMP ERROR menu" from the displayed service menu by using "up or Down cursor" from remote control, or alternatively use "CH - or CH+ to select "LAMP ERROR" * change it to zero (0) value, using {VOL+} or (VOL -) on remote control. * Turn the set off to exit the Service Menu.
Jul 03, 2011 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
TV dead other than green flashing light
The problem might be cause by lamp error, need to access the service mode to change the value of lamp error code to zero (0). Entering service mode requires a trained TV technician. Changing data can cause more problem to your television. If you are not qualified to service your television, please do not go to service menu codes. Moreover below are the process, pls do so at your own risk.
* Unplug the TV
Jul 03, 2011 | Sharp AQUOS LC-32D44U 32 in. LCD TV
I am trying to plug a play station 2 into the rca f19240 and do not see ports for the three colored prongs that I need to conect
Many of RCA's smaller sets didn't come with AV input jacks. They only had a connector for an antenna or cable wire. To use a device like a DVD player or game console with a TV like this, you need an RF modulator. This takes the audio and video signals (those three cables you can't plug in to the TV right now) and creates a signal that the TV can tune in on channel 3 or 4. Unless you replace the TV with one that has AV inputs, the modulator is your only solution.
Jun 21, 2011 | RCA F19240GY 19" TV
Connected to LG TV and getting "no signal" on
Verify that you're on the right input on the TV (Video 1, Video 2, Component 1, etc.).
Also verify you didn't plug it in the output jack behind the TV, you need to plug the cables in the Inpout jack.
Apr 19, 2011 | Sony PlayStation 2 (PS2) Console
I am trying to get my pictures downloaded onto my computer. I don't know what button I purshed, but...it wont let me get photos from camera to computer. It says "card not initialized" What do I need to...
Whatever you do, do not Initialize or format the card. Get a card reader and use it to download to your computer. Then, when the pics are safe, format the card in the camera.
Aug 17, 2010 | Fuji FinePix S5100 Digital Camera
My sharp LC-20AV4U tv did not turn on when i plugged it in
The fuse is blowning because most likely when you plugged it it, it took a power surge. And the power surge blow a proection diode. As long as you opened it up... in the power section you will see a bunch of diodes. Get a multi meter and check these diodes out. Besides the diodes... you will see a transformer.... if you are looking at the unit with the fuse to the left... then look to the right of the transformer... you will see a transistor on a metal heat sink... that could have blown also.. if that did... then you should also check the diodes just on the other side of the heatsink too.
Good luck
Dec 16, 2008 | Sharp LC-20AV4U Television
Printer easy share 5100
Contact Kodak for warranty service.
Jul 04, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Televison & Video Logo
12 people viewed this question
Top Televison & Video Experts
Electro Med Services...
