Question about Toshiba 56HM195 56" Projection HDTV
FAN NOISE? It seems to be a loud fan noise, but not sure. The sound volume was set on "mute" (no sound) and the noise is still heard. When we "unplug" the TV on and off a couple of times, the buzzing noise disappears. Cannot hear it! Do you think the fan needs to be replaced? If so, is it easy to do?
  • 1 more comment
  • Steve May 31, 2008
    When the TV is "off", we don't hear the fan running.
    Unfortunately, no warranty.
    It's 2 1/2 years old.
    We unplug the TV 2-3 times waiting a few minutes each time. It's a pain doing it, but it works.
    It works great all night, with NO fan noise.
    You have a point.
    I am not sure if it is the color wheel or fan noise.
    Unplugging the TV 2-3 times seems to work
    I am very reluctant to fix the problem myself.
  • 4,234 Answers
Apparently the ballast fan is a fairly common failure part. You should be able to replace it yourself. It is part number 23587527 at a cost of $36.95 and can be obtained from tritronicsinc.com
Good luck.
Dan
Posted on Jun 01, 2008
    Genius:
  • 1,665 Answers
If the set is working many years perhaps fan shaft sleeves are worn. In this case i think it is better to replace it instead to attempt fixing it.It can continue operate without problem except the produced noise.
Posted on May 31, 2008
    Genius:
  • 1,030 Answers
There is a possibility that this noise could be what is called a color wheel. a color wheel is much mor difficutl to replace than a fan does it have a whinning noise when yo9u turn it on
    Genius:
  • 3,587 Answers
Sounds like the unit is running hot, making the fan run constantly....there is most likely something else involved..you have a warranty on this unit?
  • 1 more comment
  • Patrick Michaels
    Patrick Michaels May 31, 2008
    well..it's cooler at night, no doubt, so I'm not surprised it's better then. You do have a potential issue here with some part of your internal workings starting to fail, and running hot, hence the fan issue.
    Do you feel inclined to try to do this one yourself, or are you in the market for a repair person(check the repair listings here at Fixya).
  • Patrick Michaels
    wellSteve, what's it going to be? Surgery or sit back and watch an expert do it? My recommend..don't mess with this one.
    and thankya for using fixya
  • Patrick Michaels
    Thanks Steve..did you findya an expert with our repair search engine?
Loud noise under refrigerator
it's a condenser fan, it's located on the bottom ,,at the back of the frig
unplug it first from the wall, & vaccum under neath bottom & around the fan,,then you need to see if the fan came loose from the shaft & if so tighten & also make sure nothing is caught in the fan...
Aug 01, 2010 | Whirlpool ES5FHAXS Side by Side...
Our toshiba 42" DLP makes an incredibly loud fan noise sometimes. Sounds like it will blow up. Can this be fixed without costing a fortune or do we just need a new set
Hello.
I can Honestly say this is little information. and i will try to you to a web site that i think it will help you and probably you can fix it by your self.
http://www.fixyourdlp.com/forum/viewtopic.php?f=10&t=1254&p=4208#p4208
This is what i think is the problem.
id the sound is to loud i think its the Color Wheel maybe its broken or louse you need to check and see that you color wheel is not making the loud sound!
Good Luck on fixing your TV
Mar 10, 2010 | Toshiba 56HMX195 52" HDTV DLP Projection...
Fan of VAIO CS-118E makes loud sounds
That is definitely a problem from the fan. What you can do is to call sony and check if they still cover Fan replacement for this specific mode.
Oct 15, 2009 | Sony VAIO VGN-CS118E/P NoteBook
PS3 Loud Fan Noise
It sounds like it needs to be cleaned, just blow some compressed air into the fan area, unless you can actually get it opened, then that would be better.
Hope this helps!
Aug 25, 2009 | Sony Playstation 3 (PS3) Console
Loud Noise from HP Pavillion dv9500
it could be a worn speaker wire shorting out
Jul 01, 2009 | Computers & Internet
Sound problem in compaq presario c700 notebook
Go into the device manager and make sure the drivers are truly installed. Also make sure you can put the volume icon in taskbar where your time is located cause this will definitely tell you that the right drivers were installed.
Make sure if you have a volume knob on your laptop that its turned up as well. Also make sure the sound isn't muted in windows and turn it up in the volume control. If it still doesn't work then it could be a motherboard issue
Jan 30, 2009 | Compaq Presario Notebook
Dvd10 optoma projector makes a loud noise
Hi, I'm not sure if it's the same problem I had..
I had it on picture mute, for maybe 15 mins, which may not have been a good idea. While it was muted, it made a sparking sound, and then a very loud grinding noise. When turned off, the lound noise stops, and the fan continues as usual for about a minute. As soon as it's turned back on, the grinding noise is back. But the logo seemed to display ok.
I took it in for repairs, and they said they needed to replace the color wheel to fix the problem.
optoma dv10 mode
Sep 26, 2008 | Optoma H30 Multimedia Projector
PRIMA 32" TV
if you know how to solder, try to solder the system ic an the sound ic but be careful of short circuit.
Jul 11, 2008 | Prima CV2011 TV
Loud buzzing noise from inside Jenn Air 2389G fridge
i don't know jennair specifically being from england.
however, there is often a fan inside the back panel and the noise you heard was the fan hitting ice. the reason now not heard and fridge not working may be that the ice has built up so much the fan is jammed
Jun 25, 2008 | Jenn-Air JCB2388G Side by Side...
Loud Buzzing noise
Sounds like the fan is hitting some ice build-up. If you can access the area of the fan motor you can try a hair dryer to defrost the ice out of it.
Apr 15, 2008 | Frigidaire FRS23R4A Side by Side...
Toshiba 56HM195 56" Projection HDTV Logo
278 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
