Question about Nokia 3110 Cellular Phone
My usb cable connection is not working,usb wire is not detecting,ithink it is loose or spoiled what to do
  • Nokia Master
  • 4,737 Answers
If you are sure that it's not working anymore, you better get a new one. But if you aren't sure, you can try the same cable on another computer with your mobile and find out the problem. This cable is very commonly used and you can find it on most electronic stores or online stores like ebay.. etc... it's called "Mini B plug (Mini USB)". It's used with many digital cameras, card readers and other electronic devices like mp3 players, mobiles, etc..etc..
If you need further help, let me know.
Good luck.
Thanks for using FixYa.
Posted on Oct 08, 2010
The usb cable not detected with the computor
try checking the cable from top to bottom find if there might be a loose or broken wire caused by spark or try replacing any other usb cable similar to the one with your device.
Sep 10, 2012 | HP LaserJet P2055d Printer
My pc and laptop not detect my Maxtor OneTouch III Mini External 100GB USB 2.0 Hard Drive R01E100 what can i do please help me soon as possible
Good Day Anantsharma8!
If your PC and Laptop can not detect your external hard drive, I do suggest you check its usb cable. A substitute cable will confirm if your current usb cable is faulty or has an open wire.
Most common reason why the external hard drive is not recognize by PC or Laptop is due to loose connection of the hard disk inside the connectors of the enclosure.
Anantsharma8, if you have a small precision screw, I recommend you open the enclosure of the external hard drive. Remove the front face where usb and power plug connects, then slide it out to expose the hard disk also. You will see two connectors. These are the ones that always loosen. Please disconnect both the connectors and then connect it again properly. Put the hard disk back, close the enclosure and try to connect again with your PC or laptop via usb cable.
Good Luck! I hope that it will soon recognize your external hard drive.
Jun 10, 2011 | Maxtor OneTouch III Mini Edition R01E100...
I connect the USB 3.0 portable hard drive for Iomega its not working in my computer but i connect another computer its working tell me solution
If your computer or laptop has a problem detecting a USBhard drive or a USB device, and another computer can detect it, then theproblem could be a RF interference problem. Try using an USB cable that is a shielded USB cable (ie. AnUSB cable that has a clear plastic covering and you can see a metallic weavewhich covers the wires) OR a USB cable that has a Ferrite core attached to theUSB cable (the ferrite core is a cylindrical object approximately 30mm long X15mm diameter and it is attached to the USB cable near the connector).
May 23, 2011 | Iomega eGo 1TB USB 3.0 Portable - Ruby Red...
Seagate external hard disk is not getting detected in windows 7 previously it was detecting. i tried to change usb cable, tried on different system but nothing worked. i want to take backup of data also....
This is my suggestion for you to possibly recover the back up file in your external hard disk.
Remove the enclosure cover of the external hard disk. Detach the hard disk from the ide connection.
Change the jumper setting of the hard disk to slave. See the sticker in the hard disk to see how to set up the jumper to slave. Connect the hard disk to the ide cable inside your pc. If your computer is equipped with sata cable, just find some ide cable and connect it the the ide slot in your motherboard.
Restart your system and you will find your hard disk as drive (d:) in your system. If this was successful then problem can be cause by loose terminal solder in the usb/ide connector of the enclosure, or possible voltage drop of the power supply of the enclosure. USB driver issue or problem with the usb slot in your computer can also cause this issue.
Jan 26, 2011 | Seagate FreeAgent Go 320 GB USB 20 Hard...
I have motorola mobile v3-i, i m connect the mobile for my computer but sorry to say my mobile not proper work in my computer
hi :) if u connect your phone with computer as cable. make sure the cable no pro,that maybe the phone usb port dirty or spoil. u need make a clean or change new.
Jul 06, 2010 | Motorola Mobility RAZR V3i Cellular Phone
MSI K8MM-V - Usb on the front case work like usb1 and not usb2.
May be problem on front USB port in CPU.Connection are very loose,so ti can detect.
Change or replace cassing.
Feb 08, 2010 | MSI K8MM-V Motherboard
Get message USB not connected when trying to scan
Right mouse click on my computer then click on hard were click ondevice manager, then click on port there may be yellow sign in usb port keepiung cd install it. 2/ if not work change usb cable to check ithink ucan solve your problem. 3 if not solve or u have desk top computer change usb card which we keep on on mother board slot. as amodeam and other card thank
Jun 19, 2009 | HP Photosmart C4280 Aio Printer
Computer can't detect my psp
If you know someone who has a USB data cable for PSP, please borrow and test it with your PSP. USB cables has 4 wires, 2 for power (+5V and GRD) and 2 for data (+ and -). With PSP, the power and data wires are separated and has different input on the PSP, if 1 of the data wires is damaged, it will look like the cable is ok but it couldn't transmit and receive data properly. In your case, I think your PSP is can transmit but couldn't receive a reply from your PC.
Let me know if the borrowed PSP USB cable don't work.
Apr 07, 2009 | Sony PlayStation Portable (PSP) Slim...
My hp photosmart 3300 can not be connect with divice
check whether its detected by the pc when you connect the usb wire to the pc and the printer.if not detecting then it could be the problem of the wire or usb drivers or the usb socket in your cpu is loose fit it tightly.
Oct 01, 2008 | HP Office Equipment & Supplies
Usb ports not picking up memory stick
Is it just Memory Stick, or everything that you plug into USB?
Try following:
  1. plug in other USB device into ports
  2. if it does not detect any USB device on any port on your computer
  3. if both front and back USB do not work it may be taht USB is turned off in BIOS, or USB driver is corupted
  4. If you have front USBs and they just do not work there is wire connecting them to the motherboard since it may be loose, if connection is OK than they are dead.
  5. If just back USB do not work than they are dead>
Jan 30, 2008 | Computers & Internet
Nokia 3110 Cellular Phone Logo
67 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
