Question about Westinghouse Washing Machines
Model#WWX645RBS0 Washer stoped in middel of cycle and now it only hums when I try to run it could it be the timer or ? thank you Ken
    Genius:
  • 1,224 Answers
If its the timer timer will not move past mark for a length of time reset timer and run threw cycle
if humming the motor has gotten seized up for some reason usually its the coupling that they put between motor and shaft it would look like this
Model#WWX645RBS0
these tend to break these are only 3 dollar parts causeing the hum in the washer
this is a water pump sometimes old socks and or clothing or material get stuck in this pump take apart look in side to see if clogged
if clogged with material get a long needle nose pliars and i mean long and pull materual out it will be tough 2 people one holding one pulling the material pull it threw the inlet direct back out the way it went in it wont come out the other outlet and remember theres always replacement pumps if theres something stuck inside there at good prices
what you described at the top had happened to me and i had to pull the pump found out one of my kids socks was in there i pulled it out with needle nose pliars put back together and washer worked since then
Posted on May 29, 2008
Washer stopes in middle if spin cycle and now when you turn it on it makes a humming sound like a bad electrical terminal
UNPULG IT FOR 10MIN.PULG IT BACK UP AND TRY IT IF NOT THE TIMER OR YOUR LID IS GONE.
Nov 12, 2012 | Washing Machines
MY KENMORE WASHER , MODEL # 20712 991 70 SERIES FILLS WITH WATER AND NEVER GOES IN THE AGITATE MODE , IT JUST CONTINUES TO FILL(it would run over if allowed), WHEN YOU MANUALLY MOVE THE TIMER TO THE SPIN...
The water level sensor hose may have come off. This would require some dis-assembly to repair. Get the correct model number please to get a diagram.
Aug 07, 2011 | Kenmore Washing Machines
Cycle stops motor hums whirlpool top load
bad points in timer or bad motor take the motor out and to a used washer shop and see if they will test it for you for a small fee if it tests ok get a timer
Dec 25, 2009 | Whirlpool Washing Machines
Washer agitates while filling and runs water when it should be spin cycle
filling and agitating at same time could be pressure sw / but if filling in spin / I would replace water valve . sounds like its stuck open . . when washer stopes does the water stop. ?? if not may be timer .. your is hard to diag . need to know brand and model # ,, mm
Dec 08, 2009 | Washing Machines
Kenmore TL Washer Just Hums
try to wash by 1/2 load the same cycle maybe the problem come from overload laundary
Jun 06, 2009 | Washing Machines
Machine stops at rinse cycle and hums
check the setting of the water temp for the rinse cycle. If one of your water supply valves is closed (HOT/COLD) the tub cannot fill with the proper water temp selected. The hum noise you are reporting is associated with the fill solenoid valve located in back of the machine.
Also, I have found the problem to be the screen located in the fill valve clogged with rust and water deposites. Disconnect both water lines and verify the water supply is not restricted.
Hope this helps..
If not, a more thural description of the problem may reveal more clues to assist in troubleshooting.
Thanks and good luck...
Apr 26, 2009 | General Electric Clothes Washer Timer -...
Bosch dishwasher timer freezing
There is a recall on the control board of many of these models, butyour problem is likely not related. It sounds like a plugged drain system or a possible bad drain pump. That's why you are hearing the pump running constantly. I have written a guide to help. It is here. Thanks!
Mar 24, 2009 | Bosch Nexxt 300 Series WFMC2201UC
Maytag Atlantis Washer, model MDG6200AWW
I just hooked up my washer and after filling it the motor hummed and smelt like it was starting to burn! Is this a fixable problem?
Jan 02, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Buzzing noise coming from timer control area
Is your water on ??if yes than you may have a bad timer.
May 04, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing Machines Logo
78 people viewed this question
Top Westinghouse Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Westinghouse Washing Machine Expert? Answer questions, earn points and help others
