Question about PfaFF Sewing Machines
I lost my manual to my PFAFF Hobbylock 4870. Can someone point me to find one?
SOURCE: manual
I have an extra copy of the manula for the PFAFF 783 Hobbylock. It cost me $12 plus $2 postage when I bought
it 4 years ago. Write me if interested. TRKSOCREF@aol.com
Posted on Nov 28, 2007
SOURCE: Pfaff Hobbylock 776
The best I can say is to change all your threads to different colors and get light colored material. Start with tenstion for all set to N - normal and experiment from there. Change one thread's tension at a time, sew a long strip and check out both sides and adjust as needed. Remember to start with new serger needles and a oiled machine. I'm not an expert - I just have had a serger for 15 years.
Posted on Sep 26, 2008
  • 3 Answers
SOURCE: Pfaff hobbylock 794
The needles are changed by inserted the hex wrench into what looks to be holes on the front and left side where the needles go into the machine.I'm not sure what size the hex wrench is but it's pretty small. From the manual,
"Removing Needle: Unplug the machine. Turn the handwheel counterclockwise to raise the needle bar to its highest position. Loosen the needle clamp with the allen wrench and pull the needle out." and
"Inserting needle: When the neddle bar is at the highest position, insert a new needle in the needle holder, making sure that the groove of the needle faces you. Push the needle as far up as it will go and tighten the needle clamp screw." "Removing Needle: Unplug the machine. Turn the handwheel counterclockwise to raise the needle bar to its highest position. Loosen the needle clamp with the allen wrench and pull the needle out."
The machine takes DB x 1, or 1738 needles, and a size 14 needle is recommended.
Hope this helps!
Posted on Jan 13, 2009
  • 632 Answers
SOURCE: lost instruction manual
ebay
Posted on Jul 17, 2009
  • 3 Answers
SOURCE: I am looking for pfaff hobbylock 786 serger manual
ISBN 0-8019-8192-1(hc)? or ISBN 0-8019-8191-3(pb) by Naomi Baker & Tammy Young - "Know Your Pfaff Hobbylock" covers Pfaff Hobbylock: 797, 786, 784, 783 - Great book. This book is more helpful since it has detailed info pics in color- 182 pgs, @$3.00. Lists parts, projects, etc. The 786 manual has errors, 35 pgs. not detailed as the book above. Good luck! Fairlyart
Posted on Jul 19, 2009
Pfaff hobbylock 4842 serger - how to thread
here is a manual:
PFAFF hobbylock 4842 Instruction Manual
Be sure to ALWAYS RAISE the presser foot when threading the machine. Also, thread each thread in the ORDER specified or your machine will most likely never stitch correctly (usually, the upper looper first, lower looper next, and then the needles).
Jun 14, 2017 | PfaFF Sewing Machines
Pfaff serger hobbylock 4870 converter stuck on on
Have you tried gently wigging the hand wheel while attempting the change?
Aug 30, 2012 | Sewing Machines
Pfaff 795 hobbylock manual
There is eBay item 160737677765 with this manual I found for you.2_15_2012_2_36_56_pm.jpg
Feb 15, 2012 | Sewing Machines
I need a manual for a Pffaf Hobbylock 4870.
http://servicemanualrepairs.com/book/pfaff-hobbylock-4870-instruction-manual/
Jan 11, 2012 | Sewing Machines
Hobbylock 797 how to thread
The hobbylocks all thread in much the same fashion.  There is a diagram for a four thread hobbylock on this website.  It would be better if you found a Pfaff dealer to show you as it is quite complicated.
http://www.pfaffmachines.co.uk/overlock/pfaff-hobbylock-2-overlocker.htm
Once you have it threaded, always cut the old threads at the spool and knot new ones on and pull through.  You will have to thread the needles as the knots will not pass through but it does save an awful lot of frustration when needing new colours on the spools.
Mar 28, 2011 | PfaFF Sewing Machines
I am looking for pfaff hobbylock 786 serger manual do you know where I can get one?
Mar 12, 2009 | PfaFF Sewing Machines
Manual
Sep 22, 2007 | Sewing Machines
Sewing Machines Logo
418 people viewed this question
Top PfaFF Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
