Question about Intermatic Inc. EJ500C Digital Wall Switch Timer - Self-Adjusting Feature
I have an Intermatic timer in my garage that controls outdour switch for holiday lighting. The timer is functioning except I cant get it to go to the off position. It is giving me a error code of no0p. I changed the battery and have tried resetting it as well. Any ideal what the issue is?
If the display will not show after replacing battery, try resetting and then reprogramming timer.
If the display will not show after reset, then timer has gone bad.
Link to Intermatic timers
Link to your manual
Troubleshooting steps do not show specific problem you mention
The advantage of Intermatic battery-powered timers is simply hooking up two wires. Plus the DST feature.
Aube T1034 hooks up to 2 wires without needing batteries.
Posted on Oct 08, 2010
I have porch lights that are controlled by a switch in front entryway and also from garage. (3-way) I want to put a timer in entryway and by-pass the garage so lights come on from only one location.
10-24-12
Identify which of 2 switches has the Hot or Power wire.
Hot wire will be connected to dark screw on one of the switches.
If Hot wire is in garage box, then follow this Step 1-2-3 diagram for ST01C timer:
http://waterheatertimer.org/images/GE-15312-3-way-circuit-6-60.jpg
If Hot or power wire is in entryway box, then you have a '3-way no neutral,' so cap off 3 wires going to other switch. ..
http://waterheatertimer.org/How-to-wire-switches.html#3-way-a
And then wire ST01C timer as single pole no neutral.
http://waterheatertimer.org/images/ST01C-single-pole-284.jpg
Oct 23, 2012 | Intermatic Inc. ST01C Digital In-Wall...
I have intermatic model ET70115c timer would like programing example so i can program our buildings lights, on, off 7days a week sametime .no holidays.I must be doing something wrong ,need example to...
I recommend calling Intermatic.
http://www.intermatic.com/customer%20service.aspx
815-675-7000
Timer prompts user through the set-up and programming.
The manual does not show exact steps.
Example programming on page 17 of manual does not show how to set timer for 'fixed' 24-hour operation, with specific on-off set times
http://waterheatertimer.org/pdf/Intermatic-et70115c.pdf
Sep 19, 2011 | Intermatic ET70115C Electronic Energy...
My EJ35IC timer seems to be preprogrammed, and i cannot erase it. can you help? thank you
There is no repair for defective timer.
Unknown if this is new timer, or timer that worked before and stopped working.
Add a comment any time.
Try resetting timer using instructions from manual: Move control lever to OFF-CLEAR position for about 20 seconds. Red indicator light will go off, and all previous programming will be cleared.
Then move control lever to ON position and red indicator will start flashing. Reprogram timer.
If functionality is not restored, then timer might be defective.
http://waterheatertimer.org/pdf/Intermatic-ej351c.pdf
Timer has 1 year limited warranty fro Intermatic:
Resources:
http://waterheatertimer.org/Intermatic-timers-and-manuals.html
Add a comment for more help
Take a moment and rate answer for accuracy:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 18, 2011 | Intermatic Programmable 24 Wall Switch...
My intermatic ej351c timer is not working properly. lights only stay on a few seconds - a few minutes before shutting off, even when button is pushed to override program. is there a battery that needs to...
Timer has non-replaceable capacitor battery for 15 minute carryover during power outage.
Timer can be affected by radio and TV receivers. Unplug those devices and check if function is restored.
Reset timer and program again.
If timer function is not restored after reset, then buy new timer.
Timer has 1-year limited warranty, and is rated for incandescent only, up to 150Watts.
Aug 12, 2011 | Intermatic Programmable 24 Wall Switch...
I just purchased a home that has an Intermatic T103 installed in the garage, how can I figure out want it's connected too?
T-103 is 120Volt timer that can be used to control 120Volt and/or 240Volt loads, for example pools and spas and outdoor lights.
Look at the yellow dial and see if it has trippers attached to dial.
If no trippers are on the dial, then the timer function is off.
Next look at dial and see if it rotates as time passes.
If dial does not rotate, then either the clock motor is bad or electricity to timer is off or timer is not connected to power.
Test across terminals A and 1 for 120Volts will tell if timer is getting power.
Last, move manual override back and forth and see if anything turns on and off.
Open following links for more information:
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html#T103
http://waterheatertimer.org/How-to-troubleshoot-Intermatic-timer.html
Jun 12, 2011 | Intermatic T103 Indoor 120-Volt 40-amp...
I have a intermatic ej351 in my garage to turn the outside coach lights on and off. I made the mistake of putting some 10 year bulbs in the coach lights and now the red light on the timer just flashes...
I answer questions for free.
I specialize in timers and electrical devices
Below is the manual for the EJ351
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/ej351c%20-%20english.ashx
The red light is a good indicator of the EJ351 timer.
The manuals says that you can clear all programming by moving control lever to OFF-CLEAR position for 20 seconds.
After programs are cleared, the red light will turn off.
Then move control lever to ON position, and then red indicator light will start flashing.
So the problem may be that the timer programs were accidentally cleared.
Use the instruction manual to re-program your timer.
Add a comment if you need more assistance, and I will help.
Nov 02, 2010 | Intermatic Timer E1020, Single pole/single...
Intermatic Inc. EJ500C Digital Wall Switch Timer - Self-Adjusting Feature Logo
385 people viewed this question
Top Intermatic Hardware & Accessories Experts
Gene Haynes
Jay Finke
Jay Finke
Steve
Are you an Intermatic Hardware and Accessory Expert? Answer questions, earn points and help others
