Question about Sony PCS-1 (PCS1) Video Conference
The pcs-r1 remote commander works in one location but not in another
My yamaha r1 randomly idle jumps and then dies
Hi, Justin and the usual suspects are:
1. Idle circuit and transfer ports clogged.
2. Air fuel mixture adjustment too lean.
3. Pilot jet clogged.
4. Faulty accelerator pump.
5. Float level too low.
6. Float bowl contaminated old fuel, water, dirt, rust, etc.
7. Float bowl vent or overflow tube clogged.
8. Fuel flow to carburetor restricted.
9. Intake manifold leak.
10. The gas cap is not venting properly or fuel tank venting system blocked.
11. Vacuum line from intake manifold to petcock broken, cracked, or not attached, carburetor vent line plugged.
12. Needle and seat stuck closed in the float bowl.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have nice a day.
http://www.r1-forum.com/forums/105-07-08-r1-mechanical-help/346779-bike-has-been-dying-randomly-while-coming-down-idle.html
2007 2008 Yamaha R1 Stalling Problem Fix How to
https://r1videos.files.wordpress.com/2011/04/2002-2003-yamaha-r1-service-manual.pdf
OEM parts for Yamaha
http://mybikemanuals.com/yamaha/yamaha-yz-owners-manuals
May 16, 2012 | Yamaha YZF-R1 Motorcycles
Tip
Which BGP show command for internal prefix count?
Question:
I have two WS-C3560V2-48TS-S routers (R1 and R2); R1 has the full BGP table and some local connections to. They are all being advertise to it's iBGP neighour R2. I can't find a command that I can run on R2 that will show the number of prefixes learnt from R1 that are internal to the local AS only. It just says 425~k which is all the Internet routes and the local ones.
What command can I use for this?
Answer:
the local AS originated networks has AS path attribute empty.
So you could define an ip as-path acl matching an empty string
ip as-path access-list 1 permit ^$
then you can invoke the as-path access-list as a filter action on show ip bgp on R2
show ip bgp filter-list 1
see
BGP command reference
http://www.cisco.com/en/US/docs/ios-xml/ios/iproute_bgp/command/bgp-s1.html#GUID-2618748E-42ED-495A-875C-D398A02D79F9
At this point it is enough to count the lines in show ip bgp filter-list 1 output to count the routes that are originated in the local AS at R1 WS-C3560X-24P-L Price and received on R2 and installed on R2.
Original comes from http://switch.blogcindario.com/
on Sep 03, 2013 | Computers & Internet
2005 r1 ICM location
Hi, Anonymous for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
http://www.r1-forum.com/forums/4-mechanical-help/134584-05-ecu-location.html
2005 r1 ICM location Google Search
2004 2005 Yamaha YZF R1 Service Manual R1 Moto Data Project
Feb 13, 2012 | 2005 Yamaha YZF-R1
Cisco 2514 does not switch on straight away. It powers on about 1min after switch depressed. it also loses the correct date and time if switched off.
if you issue the command show version
At the bottom written in bold you should the config register settings these nee to be as shown at the bottom of this page
R1#show version
Cisco Internetwork Operating System Software
IOS (tm) 2500 Software (C2500-JS-L), Version 12.1(3), RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2000 by cisco Systems, Inc.
Compiled Thu 06-Jul-00 10:02 by cmong
Image text-base: 0x0306F914, data-base: 0x00001000
ROM: System Bootstrap, Version 11.0(10c), SOFTWARE
BOOTFLASH: 3000 Bootstrap Software (IGS-BOOT-R), Version 11.0(10c), RELEASE SOFT
WARE (fc1)
R1 uptime is 1 day, 5 hours, 39 minutes
System returned to ROM by power-on
System image file is "flash:c2500-js-l.121-3"
cisco 2500 (68030) processor (revision N) with 14336K/2048K bytes of memory.
Processor board ID 11844920, with hardware revision 00000001
Bridging software.
X.25 software, Version 3.0.0.
SuperLAT software (copyright 1990 by Meridian Technology Corp).
TN3270 Emulation software.
Basic Rate ISDN software, Version 1.1.
1 Ethernet/IEEE 802.3 interface(s)
2 Serial network interface(s)
1 ISDN Basic Rate interface(s)
32K bytes of non-volatile configuration memory.
16384K bytes of processor board System flash (Read ONLY)
Configuration register is 0x2102
if yours differs the use the these commands to correct it
R1>en
R1#conf t
Enter configuration commands, one per line. End with CNTL/Z.
R1(config)#config 0x2102
R1(config)#^Z
R1#
Hope this helps
Mar 15, 2011 | Cisco 2514 Refurbished Router (CSCO2514)
Whats a phoenix failsafe code
Phoenix FailSafe is a theft-deterrence product and service that provides the ability to protect, track, and manage lost or stolen mobile computing devices and the data on those devices. PC owners can remotely retrieve and erase the content stored on their mobile PCs and remotely disable the device if necessary.
With FailSafe, PC owners can often tell the location of their monitored PCs and they have the ability to "kill" their PCs with an SMS (text message) to protect their digital data subject to the restrictions mentioned above.
Jan 07, 2010 | Samsung NC10-14GW Notebook
My remote control to RDR GX3 Sony DVD recorder does not function. When put on TV it works but does not work on DVD setting
Please change command mode on dvd recorder remote as it has 3 modes, dvd-1, dvd-2 and dvd-3. command mode switch is located at bottom part of remote.
DVD Recorder default command mode is DVD-3
Jan 30, 2009 | Sony RDR-GX3 DVD Recorder
Sony PCS-1 dont remember admin password
1. Access the Setup menu as follows:
Press and hold the MENU button on the remote commander.
2. Select Dial using the �� button on the remote commander.
3. Access the Service menu as follows:
Press 7 then 2 on the remote commander (without pressing the
PUSH ENTER button).
The Service menu appears. (See Figure 1.)
NOTE: To cancel Service mode and return to the Setup menu,
select Cancel using the arrow buttons, and press RETURN
Clear setup and FINISH
Bye Zamani Ali
azamani@iooc.co.ir
Nov 24, 2008 | Sony PCS-1 (PCS1) Video Conference
The Norton symbol on my toolbar has a red circle and a white cross. When I try to open Norton I get a blank page.
The short answer is that your computer is infected with spyware that actually infects Norton itself, so that it cannot remove it. it is Fixable but its complicated and I'm unsure how much you know about computers. It might even be easier to reformat.
but if you do the following it will fix it.
(Disclaimer: if you are not comfortable with the following please get a professional or don't attempt. The easiest way is to reformat)
also i personally use the following sites on a daily basis and stand by them 100%
Get the Pocket Killbox from here:
http://bleepingcomputer.com/files/spyware/KillBox.zip
Unzip the file to your desktop.
Go offline until this is completed (you may wish to print these instructions).
Boot into Safe Mode and do a search for these files:
guninst.exe
popup_bl.dll
systr.dll
svrhost.exe
Delete any found, and then do a search for param32.dll
Run Pocket Killbox and paste the full file path of param32.dll in the box and click on Delete on Reboot. Click on the button with the red circle and an X in the middle; you will get a message saying File will be deleted on next reboot, Process and Reboot now? Click Yes to reboot. (Note: the 'file path' will be something like C:WINDOWSSystem32param32.dll)
Delete any unwanted icons from your desktop.
Empty your Recycle Bin.
Go to AddRemove Programs in your Control Panel and remove ADVANCED SEARCHBAR, if found.
Scan with hijackthis (download it here), and have it fix the following entries:
R1 - HKCUSoftwareMicrosoftInternet ExplorerMain,Search Bar = about:NavigationFailure
R1 - HKCUSoftwareMicrosoftInternet ExplorerMain,Search Page = about:NavigationFailure
R0 - HKCUSoftwareMicrosoftInternet ExplorerMain,Start Page = http://www.newgenlook.info/ad/ad0278/
R1 - HKLMSoftwareMicrosoftInternet ExplorerMain,Search Bar = about:NavigationFailure
R1 - HKLMSoftwareMicrosoftInternet ExplorerMain,Search Page = about:NavigationFailure
R1 - HKCUSoftwareMicrosoftInternet ExplorerSearch,SearchAssistant = about:NavigationFailure
R0 - HKLMSoftwareMicrosoftInternet ExplorerSearch,SearchAssistant = about:NavigationFailure
R1 - HKCUSoftwareMicrosoftInternet ExplorerMain,HomeOldSP = about:blank
R1 - HKLMSoftwareMicrosoftInternet ExplorerMain,HomeOldSP = about:blank
R3 - URLSearchHook: (no name) - {C7EDAB2E-D7F9-11D8-BA48-C79B0C409D70} - (no file)
O1 - Hosts: 69.50.166.11 www.google.co.uk
O1 - Hosts: 69.50.166.11 google.co.uk
O1 - Hosts: 69.50.166.11 www.google.ca
O1 - Hosts: 69.50.166.11 google.ca
O1 - Hosts: 69.50.166.11 www.google.es
O1 - Hosts: 69.50.166.11 google.es
O1 - Hosts: 69.50.166.11 www.google.de
O1 - Hosts: 69.50.166.11 google.de
O1 - Hosts: 69.50.166.11 www.google.fr
O1 - Hosts: 69.50.166.11 google.fr
O1 - Hosts: 69.50.166.12 www.go.com
O1 - Hosts: 69.50.166.12 go.com
O1 - Hosts: 69.50.166.13 astalavista.com
O1 - Hosts: 69.50.166.13 www.astalavista.com
O1 - Hosts: 69.50.166.13 astalavista.box.sk
O1 - Hosts: 69.50.166.13 cracks.am
O1 - Hosts: 69.50.166.13 www.cracks.am
O9 - Extra button: Advanced Searchbar - {43F02779-6D88-4958-8AD3-83C12D86ADC7} - C:PROGRAM FILESADVANCED SEARCHBARTOOLBAR.DLL
O9 - Extra 'Tools' menuitem: Advanced Searchbar -{43F02779-6D88-4958-8AD3-83C12D86ADC7} - C:PROGRAM FILESADVANCEDSEARCHBARTOOLBAR.DLL
O18 - Filter: text/html - {E27A20A0-BE61-11D9-9E02-0008C7E6B749} - C:WINDOWSSYSTEMHIJENCA.DLL
O18 - Filter: text/plain - {E27A20A0-BE61-11D9-9E02-0008C7E6B749} - C:WINDOWSSYSTEMHIJENCA.DLL
Be sure all windows are closed, other then hijackthis, before hitting Fix checked.
A few more things need to go.
1. Open a DOS box by typing "command" (omit the quotes) in the "Run.." option under your Start button menu.
- At the command prompt in the DOS window, type the following command:
regsvr32 /u C:WINDOWSSYSTEMHIJENCA.DLL
Close the DOS window after the command command completes
2. Run HijackThis again and have it fix:
R3 - Default URLSearchHook is missing
O2 - BHO: ToolHelper - {CDEEC43D-3572-4E95-A2A5-F519D29F00C0} - C:PROGRA~1ADVANC~1TOOLBAR.DLL (file missing)
O2 - BHO: (no name) - {4948A8E1-BE50-11D9-9E02-000855D4C36C} - C:WINDOWSSYSTEMHIJENCA.DLL
O18 - Filter: text/html - {7CDBC5E3-BE71-11D9-9E02-00084A455E60} - C:WINDOWSSYSTEMHIJENCA.DLL
O18 - Filter: text/plain - {7CDBC5E3-BE71-11D9-9E02-00084A455E60} - C:WINDOWSSYSTEMHIJENCA.DLL
3. Search your system for the C:WINDOWSSYSTEMHIJENCA.DLL file and delete it if it still exists.
Sorry but this particular virus/spyware has no real quick fix and it has many many names.
Nov 12, 2008 | Computers & Internet
URC-9910 remote: The RF part for this remote stopped working.
I have the same remote as yours and occasionally the RF remote is not working due the interference signal from outside or next door at certain hours.
My suggestions:
(1) To relocate the receiver and reposition the anntena for better reception of the RF signal from the remote unit.
(2) Replaced the battery.
Hope these help!
Aug 04, 2008 | One For All URC-9910 LCD Remote Control
PCS-1
Reset password sony pcs-1
PUSH ENTER button).
select Cancel using the arrow buttons, and press RETURN.
Jan 18, 2008 | Sony PCS-1 (PCS1) Video Conference
Sony PCS-1 (PCS1) Video Conference Logo
126 people viewed this question
Top Sony Computers & Internet Experts
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
