Question about Viking VWH3010 Kitchen Hood
The filters on our viking hood keep falling out. Seems like when a little grease builds up on the ledge of the hood the filter comes crashing down on the stove. Anyone else having this issue? Better yet anyone have a solution as to how to keep these filters from falling out??
I'm having the same problem, and I'm fed up. One of these days the filter is going to fall into a boiling pot and potentially seriously injuring someone. I'm surprised this isn't a recall issue with these hoods. I've temporarily fixed it by applying exhaust muffler tape to the filter and hood where it rests ( on the area closest to the wall). This is a temporary fix, however. I do plan on taking this serious problem up with Viking. This is a serious design flaw that can be potentially very dangerous.
Posted on Nov 02, 2010
Can I wash the cooker hood carbon filter
No! The material is impregnated with minute carbon granules which will have absorbed all the grease and moisture coming from the cooker, like little pieces of coke (smokeless fuel!!). If the filter is a cartridge type, a search on Google for the model may help. Search under "cooker extractor spares". If it's a cloth type, there are numerous cheap shop choices for universal filter material that you just trim to fit.
Aug 22, 2014 | Kitchen Ranges
How do I get the filters out to clean them?
I am not familiar with you particular model Viking. However, filters are normally simple to remove. They either have a spring clip retainer (visable or hidden), slide in a track or have a small screw in one or the other or both sides.
Try sliding the filter side to side to see if the retainer spring is hidden. If the filter moves 1/4 inch or so, it should come out easily.
Thanks for your interest in FixYa.com
Feb 20, 2010 | Viking VIPR161 Kitchen Hood
Removing debris filters/cups at bottom of machine.
It does remove. I had a serious amount of lime build up that was making it difficult.
Jun 02, 2009 | Viking 24 in. Professional Series VUD040...
I am looking for a filter for the vwh3648ss?
Any Viking dealer/distributor should carry the filter. Just Google Viking and your area for a local supplier.
Bill B.
San Antonio
May 16, 2009 | Viking VWH3648 Kitchen Hood
Vents in the Viking hood fall out on their own
Remove the filters.
The slot that the filters sit in at the rear edge, can be removed, it is basically hooked into place.
When you remove it you will see that the sides are different, reinstall it with the smaller edge hooked thus leaving the larger edge to hold the filters in place.
I hope this is clear.
Dec 12, 2008 | Viking VWH3048 Kitchen Hood
Kitchen Hood
Hi absimp,
I'm Harvey the Master Plumber.
Your question is: You are having trouble cleaning your downdraft hood...you are able to remove filters and clean but there seems to be grease build on the hood as well....The smell is really bad but you can't get down in the hood to clean. Is there anyway to remove the hood in order to clean it better??
The short answer is; not really. But don't be dicouraged yet, you shouldn't have to . There is a brush on a long handle that looks like the kind of brush you would use to wash a glass. I wrap the brush part with a small cloth that is wet with cleaner and just use from above rinsing the cloth as nessessary. If you have trouble finding a brush long enough just go to a plumbing supply and buy a brush made for cleaning the soot out of a boiler. If they know your problem they weill be happy to help.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 26, 2008 | Frigidaire HV2736B Kitchen Hood
Viking hood Lights out
Part PE050033 no longer exists. It's now two parts: PE050141 for the light and PE050156 for the fan. You must first remove all of the small switches then pull off the front panel to tighten the small nuts that hold the new units in place.
Dec 09, 2007 | Viking VWH3048 Kitchen Hood
Dropped grease filter
JiXing Hardware & Mesh Products co.,ltd ,established in 2005, owns two factories in China mainland.
We can supply many kinds of aluminum cooker hood filters,grease filters,,hardware parts,wire shelf,wire and wire mesh.
Our products are sold all over the world , we can assure the good quality with competitive price.
Hope to establish a long-term business relationship with you.
contact info: info@mmfilters.com
TEL:0086-318-7803299
FAX:0086-318-7755255
Mar 08, 2007 | GE Profile JVB37H Kitchen Hood
DIPR160R
If I'm not mistaken, these are the same as the Dacor range vents. If thats the case, we have seen a LOT of bad control boards on these, but I can't say I've ever had one with quite the symptoms you are describing. You may just need to reset the filter timer, as that light comes on every 40 hours of use I belive. But I think you said you have already done that. If you have cleared the light per the instructions and it just keeps coming back on, then you probably do have a bad control board. That should be located on the lower right of the unit behind a small square acces hole, if its like the model I am familiar with. They arent too hard to change, just make a diagram of all the wires before you pull em off and make sure to turn of the power first. One more thing, if the filter light doesnt come on after you reset it, try taking the blower motor box of the front of the unit and checking the 3 prong connector between the fan and the vent and make sure it hasn't come undone or that one of the terminals hasnt backed out of the connector, causing a poor contact. Good Luck!
Oct 22, 2006 | Viking DIPR160R Stainless Steel Kitchen...
Viking VWH3010 Kitchen Hood Logo
258 people viewed this question
Top Viking Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Viking Kitchen Range Expert? Answer questions, earn points and help others
