Question about Brother BRTPT65 PT-65 Label Maker Printer
How do you change the print orientation on the hand-held home hobby model?
How can I find a new Bamix old model spice blender/chopper
Bar mix products made millions for world wide sales
kitchen aids that change design so often
they cant support a large parts division
(R&D is geared to sell the next better barmix product )
if you cannot find a new old part
or super ceeded shaft from the next model up
or used drive shaft for sale online
look for a complete used bar mix spice blender/chopper
some people collect barmix units for a hobby or collection
and sell double ups
when you say old model
if the shaft is plastic ....... its .unfix able
its a heat molded construction process
Vintage Bamix M122 2-Speed Hand Held Food Blender Mixer-Chopper
Sep 16, 2016 | Bamix Blenders
S4m quick books
change the default orientation setting in printer properties.
May 10, 2013 | Zebra S4M Thermal Label Printer
2011 equinox rear wiper replacement
I just replaced mine. Lift the rear wiper up as far as it will go. which is not very far. Place your fingers on each end of the wiper and pull down. The blade is held in place by a clip. Gentle pressure will downward toward the window will cause it to disconnect. An extra pair of hands to hold the plastic cover up helps. Note the orientation of the blade when you disconnect it. The replacement blade may have a clip on it which may need to be removed. Place the replacement blade in the same orientation as the one that was removed and clip back in place.
Sep 16, 2012 | 2011 Chevrolet Equinox
How do i change scren orientation?
Hi there. The Kindle does not have the option to change the screen orientation. It is meant to be held upright like a book. Alex
Jul 13, 2011 | Amazon Kindle Wireless Reading Device
Canon ir3045n - when printing the paper orientation has switched to landscape. How do we change it back to portrait?
Hello Donna,
To change the orientation of the printer from landscape to portrait follow these simple steps;
- open any document and go to print from the file menu
- when the printers settings window opens click 'properties'
- In the next up coming windows you can see menus like 'main, page setup, effects' profiles
maintenance etc.
- click 'page setup'
- There you can see 'page size' and 'orientation'
- change the 'orientation' from landscape to portrait
- click ok and print
Done : )
please rate if this solution was helpful for you, thanks you!
Jun 23, 2011 | Office Equipment & Supplies
I have an "old" p
When labels print i get back ground i do not want
Mar 04, 2011 | Brother BRTPT65 PT-65 Label Maker Printer
Ink will not print
www.ptouchdirect.com/ptouch/umpt65.html
this is a web page with the manual should help
Dec 09, 2008 | Brother BRTPT65 PT-65 Label Maker Printer
Print orientation
If you are printing from the included software, it has options for labels with vertical printing. If printing from a third party program, you can go to the dirver settings and change the printing orientation.
Oct 30, 2008 | Dymo LabelWriter 400 Thermal Printer
Problem printing
The toner cartridge roller may be defective or there are outside light going inside the printer, causing the bands.
Mar 05, 2008 | HP LaserJet 1018 Printer
Brother BRTPT65 PT-65 Label Maker Printer Logo
43 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
