Question about Jenn-Air JJW9330D Electric Single Oven
Jenn-aire jjw93330ddb wiring installation problem
I attempted to install my jenn-aire jjw9330ddb wall oven and accidentally connected the neutral white wire to one leg of the hot. the oven came on briefly and then cut off. i could smell electrical burning. after disconnecting the wiring and discovering i had wired it wrong i wired it correctly but nothing happened. i checked for voltage to the terminal block in the oven and to the circuit board and i had correct voltage. i think i fried the circuit board. what do you suggest.
  • 2 more comments
  • jhjr May 30, 2008
    thanks maanita, but can the safety fuse be replaced and if so will this fix my problem
  • jhjr May 30, 2008
    where is the safety fuse located & how do i determine if it is defective. if it is then how do i replace it
  • jhjr May 30, 2008
    thanks ginko for your solution for my problem, but i have a wall oven (jenn-aire jjw9330ddb) and not a microwave. i did use my multimeter to check power and i did have power to the board. your advice however is helpful in that whether microwave or wall oven, both i believe would have same problem after my blunder
  • jhjr May 30, 2008
    thanks maanita, i will test the fuse which is located on top of the oven.
  • Jenn-Air Master
  • 19,396 Answers
To start you should get a Multimeter and check if there is still power in the cables coming to the oven. The wires may have blown after the short, in this case there won't even be power coming to the oven.
Regarding fuses, (microwaves have more than one fuse), there should be one or more fuses on the power board, where electric cables connect to. This is the one you have to check, this should be a traditional cylindric fuse held only by his slot. If you do not find it, it may be soldered to the boars, in this case consider replacing the board.
Your problem is not necessarily the fuse, it can be for example a blown capacitor, get a Multimeter and start testing power board, or call a technician.
Here is a complete microwave general repair guide.
Check also:
Microwave Oven Repair Guide - Replace your microwave's fuse
Microwave Oven Repair Guide - My microwave isn't working
Here you find diagrams for jenn air microwave, your model is not in list, but many the ones illustrated have same control
Posted on May 30, 2008
  • 1 more comment
  • Ginko
    Ginko May 30, 2008
    Do not get confused, if the problem had been caused by a short , changing thermal fuse is not going to help.
    The fuse you have to check probably it is not the thermal fuse, microwave's thermal fuse blows when oven overheats.
    If your problem had been caused by a short you need to check the power board inside the oven, that is where power wires connect to.
    You should also check if there is power coming into the wires to connect to the oven, as the short may have blown them.
    I suggest calling a repairman if you are not very experienced servicing microwave ovens.
    Regards
  • Ginko
    Ginko May 30, 2008
    Electric (not thermal) Fuse:
  • Ginko
    Ginko May 30, 2008
    Things do not change if oven is electrical, if you shorted the wires you have probably burnt the electronics (power board or control board) . Power board is more likely.
    If power board does not have a removable fuse like the one above then you will have one (or more) fuses soldered to the board, you need to test them. Shape and size of this kind of fuses may be different.
    Generally you start using the tester from the place where you caused the short ( I assume power board).
    You may need to order the Service manual from Jenn Air to do this job.
    To know if a fuse is working, you just test it for continuity.
  • 655 Answers
Hmm its sounds ur cuirkit board had fired. you should take a it to service centre.
Posted on May 29, 2008
  • Iqbal Husain
    Iqbal Husain May 31, 2008
    The fuse can't fix your problem in your case. Because you have made wrong connection and it will bypass the usual circuit, so it might not be effected to your fuse. I think your borad has been burnt and you should have to take a tour of service centre.
    Thanks and Good Luck
    Iqbal
    Genius:
  • 1,142 Answers
You need to check the safety fuse first
  • 3 more comments
  • Maanita Chadha
    Maanita Chadha May 29, 2008
    It may have shorted the electronic control.
  • Maanita Chadha
    I would recommend that you contact one of our authorized service
    providers to come out and see for sure what went wrong, and determine
    what will be needed to correct this issue!
  • Maanita Chadha
    you can download the manual directly at http://www.jennair.com,
    just enter in the model number on the main page, and it will direct you
    to all of the literature, you can contact A&E Factory Service directly at (800)
    771-3029 to arrange for an technician to come out.
  • Maanita Chadha
    Maanita Chadha May 30, 2008
    the fuse looks something like
  • Maanita Chadha
    check this pic.
Jenn air oven will not heat you push bake and it says 100 but never heats up
One side of your 240 volt connection is disconnected, most likely in the plug wire connection. The neutral and one leg of your 240 is working thereby your display still works since it runs of 120 volts. Happened to me I had one wire come loose from stress on the plug
Sep 19, 2010 | Jenn-Air JJW8530C Expressions Collection...
I'm looking for a Jenn Air wall oven W136 schematic, is there one available?
Jenn-Air is now a division of Whirlpool so you might want to check with their closest service company and ask if there is a wiring diagram pasted inside a panel of the unit. This is common practice on many appliances.
May 17, 2010 | Jenn-Air 27 in. Electric Single Wall Oven...
Replacing heat elements in oven
To replace oven heat element follow the steps below carefully
Turn off the power to the oven at the breaker box.
  • Step 2 Take out the screws holding the element bracket in place. These will be on the back wall of the oven, or sometimes on the top.
  • Step 3 Pull the element toward you a little bit until you see the wires behind it.
  • Step 4 Unscrew the leads and take the bad element out.
  • Step 5 Hold the new element up while you attach the wires to it. Don't stretch the wires any more than you have to.
  • Step 6 Line up the element while tucking the wires back in. Be sure not to pinch the wires between the bracket and the back wall.
  • Step 7 Fasten the brackets, making sure they're tight.
  • Step 8 Restore power to the appliance.
  • basically to install the elements , place it in the same position as the old one. Connect it the same way the old one was connected, using the same screws to hold it in place. Just about all the other components of an electric range or oven
  • Jan 03, 2010 | Jenn-Air Ovens
    I have a jenn-air wall oven it has a red wire a black wire a white wire and a copper wire but coming out of my wall is only a red/black and copper what dose the white wire go to please help thank you
    IF you nhave a 3 wire feed fronm the house for your range, you connect the red and black for the power and then use the copper wire from the wall to connect to the white and copper wires from the range. All new construction must have a 4 wire feed to a range and dryer.
    Oct 26, 2009 | Jenn-Air 30 in. Pro-Style Electric Single...
    I HAVE A W136C Jenn-Air wall oven and would like a wiring connection diagram. Icant figure where to connect the orange wire
    Look for schmatic behind control panel, open oven door and remove 4 screws that hold upper face panel down, panel should slide up 1/2' or so and lift off.
    Sep 14, 2009 | Jenn-Air 27 in. Electric Single Wall Oven...
    How do you get a Jenn air oven out of the wall???
    The JennAir website should have the installation manual for download. Go there, type on your model number, and it should come up.
    Sometimes these ovens just get "stuck" in place, and take some easy levering to break free, or to help you find other fasteners.
    Jan 15, 2009 | Jenn-Air 30 in. Pro-Style Electric Single...
    Wiring diagram
    This model of cook top needs the 4 wire install because it has both 220v and 110v circuits. The forth wire is a neutral that operates the 110v circuit. You can move the ground of the 3 wire outlet to neutral, but ONLY! if the ground wire is insulated. What this will do is give you both your 220v and 110v circuits. The problem with that is your cook top will not be grounded. The best solution is to locate a neutral wire and tap into it, this will give you your 4 wire circuit. Your missing a neutral in a 3 wire outlet.
    More Asst.
    eboukater@gmail.com
    Sep 24, 2008 | Jenn-Air JJW8530C Expressions Collection...
    Jenn air oven stuck closed after attempt to activate self-cleaning
    The lock motor may have failed. Most often, bending a coat hanger into a hook and sliding from the right side as you move the door to the right,will allow you to release the lock and open the door.
    Jun 09, 2008 | Jenn-Air JJW8130D Electric Single Oven
    Jenn-Air Gas Range SEG196 NO CLOCK/DISPLAY
    THE ONLY SOLUTION FOR THE BAD DISPLAY IS TO REPLACE THE CLOCK. I HAVE A JENN AIR OVEN TODAY AS A WORK ORDER TO REPLACE THE CLOCK FOR A FAILED DISPLAY.
    FOR THE JGW8130DDB WITH NO POWER ANYWHERE, IT SOUNDS LIKE YOU HAVE A SUPPLY PROBLEM. MAKE SURE THE WIRING IS HOOKED UP WITH THE RED AND WHITE WIRES RECEIVING 240 VOLTS AND THE WHITE WIRE ATTACHED TO NEUTRAL / GROUND.IF THE OVEN HAS A BARE COPPER WIRE AND THE HOUSEHOLD WIRING ONLY HAS THREE WIRES, COMBINE THE WHITE WIRE AND THE COPPER WIRE TOGETHER AND ATTACH TO THE HOUSEHOLD NEUTRAL / GROUND .
    UNLESS YOU ARE SURE ABOUT THE HOOKUP IN THE BREAKER/FUSE BOX, DO NOT GO SIMPLY BY THE COLOR OF THE WIRES.
    Apr 10, 2008 | Jenn-Air JGW8130A Electric Single Oven
    Jenn Aire double wall oven
    Get a long thin flat blade screwdriver. Gently pull the probe with one hand and press on the back side of the probe connector with the screwdriver until you feel no slack in the wires. Don't pull too hard! Rotate the blade of the screwdriver until the connector lines up with the opening and puill it through. Works for installing the new one too.
    Jan 08, 2008 | Jenn-Air JJW8530C Expressions Collection...
    Jenn-Air JJW9330D Electric Single Oven Logo
    188 people viewed this question
    Top Jenn-Air Ovens Experts
    Dan Webster
    Dan Webster
    Oloyede Monsuru
    Craig Butler
    Craig Butler
    Are you a Jenn-Air Oven Expert? Answer questions, earn points and help others
