Question about Indesit Dishwashers
I have an indesit ide1005. the dishwasher isnt draining properly and A03 keeps flashing???
  • 27 Answers
SOURCE: indesit dishwasher DV62
You have a blockage in your drain pump. Remove all filters and scoop out as much water as you can from the unit. Check in the bottom for any objects stuck there. Some models have a cover on the bottom inside the unit, which once removed, will expose the drain pump impeller. If yours does, remove the cover(usually 1 screw only) and free the drain pump impeller. NB: DO NOT REMOVE THE SCREWS WHICH HOLD THE BASE TUB IN PLACE! These are the screws on the edge of the white plastic "bowl" inside the unit. The drain pump cover will be INSIDE this bowl and will be quite small, no more than 5cm dia.... If this does not work, you will have to remove the drain pump from the bottom or front of the unit to get the blockage out. Oshie
Posted on Jun 26, 2007
  • 105 Answers
machine is flooded in base
means you have a leak in dishwasher
dismantle check feed pipe to top basked probable faulty feed pipe replace if so
Posted on Feb 24, 2008
  • 184 Answers
SOURCE: Indesit DE43UK dishwasher. Water only
INCREASE THE WATER TEMP AT THE HOUSE WATER HEATER SO YOU WILL HAVE 120 DEGREE WATER COMING INTO THE DISHWASHER. IF THE DISHWASHER IS NEXT TO THE SINK, PURGE THE HOT WATER LINE AT THE SINK UNTIL YOU ACTUALLY GET HOT WATER. THEN, START YOUR DISHWASHER.
Posted on Apr 03, 2008
Firstly, thanks Craig. Followed ur instructions.
However, my solution was happily easier although I completed Craigs solution without success.
Above the catch on the main body there is a "D" ring of wire which the catch engages. It is adjustable, backwards and forwards. It is held by a screw. My screw was loose so every time you closed the door the ring moved back stopping it engaging with the catch.
Hope this helps
Posted on Jul 17, 2008
  • 10 Answers
SOURCE: My Zanussi Dishwasher ZDF231 is not draining
Check the drain hose isn't kinked or blocked. Check the filter in the inside bottom of the isn't clogged.
Posted on Jul 27, 2009
My dishwasher shows error code A03 can u help me?
What is the make and model number of your dishwasher?
Oct 15, 2014 | Indesit Dishwashers
My dishwasher shows error cod A03
A03 - Short circuit on thermistor or Time-out drain- Check filter for blockages then book a dishwasher repair if the problem persists.
Also check that the nothing has managed to get through teh filters into teh drain pump and block it or that drain hose is not crushed and or blocked,
A05 code
Indesit Error Messages and Error Codes Indesit Dishwashers
  • F10 - Fill or empty time out. Check that the hoses are not kinked, that the taps are on or whether the drain pump or hose is blocked.
  • F11 - Heater timed out. The heater has not reached the required level. Book a service engineer.
  • F20 - Temperature under range. Book a service engineer. .
  • F21 - Temperature over range. Book a service engineer.
Fault codes for Indesit LCD Dishwasher Models
  • A01 - Float switch operated - Book a service engineer.
  • A02 - Open/Short circuit heater relay - Book a service engineer.
  • A03 - Short circuit on thermistor - Book a service engineer.
  • A04 - Unable to reach or sense temperature within 70 minutes - Book service engineer.
  • A05 - Pressure switch has not been reset - Book a service engineer.
  • A07 - Open/Short circuit wash motor triac - Book a service engineer.
  • A08 - Open/Short circuit auxiliary wash motor triac - Book a service engineer.
  • A09 - Open/Short circuit with main wash traic - Book a service engineer.
  • A10 - Open/Short circuit fill valve traic - Book a service engineer.
  • A11 - Half load valve traic or alternating motor action - Book a service engineer.
  • A12 - Open circuit heater rely - Book a service engineer.
  • A13 - Open/Short circuit dispenser traic - Book a service engineer.
  • A14 - Drain hose too low causing syphoning. Check drain hose and re-adjust.
  • H20 - Check tap and pressure of incoming water.
_uacct = "UA-1207243-4";urchinTracker();
Sep 14, 2008 | Indesit 24 in. DE73 Evolution...
Indesit evolution de73 dishwasher
01 = Acquastop operated due to leak / overfill - machine drains until empty + lmin.
A02 = Heater Relay open circuit/short circuit or Thermistor or Safety T/Stat o/c or s/c or Element machine fills to Level Switch & Wash Pump runs.
A03 = Thermistor open circuit /short circuit - machine drains until Level Switch resets +1minute
A04 = Unable to sense/reach temperature in 70mins. - machine drains until Level Switch resets + lminute
A05 = Level Switch not resetting in within 3' 20" of drain commencing - machine drains until Level Switch resets +1 minute
A06 = Not used see also H20 at end
A07 = Wash pump Triac closed/open circuit - check that Drain Pump is not disconnected or Aquastop operated
A08 = Auxiliary Wash Pump Triac closedlopen circuit - check Wash Motor operation- machine drains until Level switch resets+30"
A09 = Main Wash Pump Triac closed/open circuit - cheek Wash Motor operation- machine drains until Level Switch resets+30"
A10 = Fill Solenoid valve Triac closedlopen circuit - check valve/operation - machine drains until Level Switch resets+30"
A11 = 1/2 load Solenoid Valve Triac or alternating Wash Motor action - check Solenoid Valve operation & alternating Motor action, replace Module if required - machine drains until Level Switch resets +30"
A12 = Relay with open circuit - check Heater, replace Module if required - machine drains until Level Switch resets+30"
A 13 = Dispenser Triac incorrect operation closed/open circuit - Wash Cycle completes but with Dispenser Lid notfunctioning correctly
H20 = Static 'Fill Time exceeding 6 minutes - cheek for blockages/low pressure
Apr 07, 2008 | Indesit 24 in. DE73 Evolution...
Indesit DE43UK dishwasher. Water only gets lukewarm, intermittently gives Fault code A03 - "thermistor short circuit". Indesit says no such part as thermistor listed for this model. Indesit will...
Apr 03, 2008 | Dishwashers
Dishwashers Logo
29 people viewed this question
Top Indesit Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Eric Taylor
Are you an Indesit Dishwasher Expert? Answer questions, earn points and help others
