Question about Hitachi ED-A100 LCD Projector
My cp a100 3lcd is projecting the image upside down. I must of pressed the wrong button on my remote control. What do I need to do to correct?
nfandres
  • 168 Answers
SOURCE: Reverse Image
find the menu for saving the settings, for sure there is a menu saving all your desired settings. good luck!
Posted on Feb 12, 2007
Marrie
  • 563 Answers
SOURCE: Upside down image!
Hi there
I just drew the users manual and you should do the following:
Go into the setup menu and choose mirror - then just scroll left or right on the mirror and your image will change as you do this.
Posted on Apr 01, 2008
  • 5 Answers
SOURCE: Data Projector projecting upside down
If you go onto your menu and click on "setup". Press orientation and select the right one for your projector. It allows you to choose whether your projector is on a table top or ceiling mounted etc.
Posted on Feb 19, 2009
I fixed it by finding a site that posted a solution without misleading and charging for the info.
Posted on Mar 22, 2009
  • 69 Answers
SOURCE: Hitachi projector image is upside down
you can chance it in the menu
Posted on Apr 21, 2010
My image is upside down after I mounted my projector to the ceiling
There are projection mode settings which will allow you to adjust the orientation of the image. Adjusting this setting will rotate the image so that it is not displayed upside down when attaching the projector to the ceiling.
To activate this setting:
  1. Press the Menu button on the projector.
  2. Using the Arrow buttons, select the Image icon on the left side.
  3. On the Image screen under the Projection label, select the icon that represents ceiling mounted projection. Note: You may see both front and rear ceiling mounted projection modes. You may choose which ever best suits your needs.
  4. Press Menu on the projector controls to exit the settings menu.
Nov 19, 2011 | Office Equipment & Supplies
Our LCD is ceiling suspended, upside down. When I was resetting the time for cleaning, I think I touched a button on the remote that turned the image on our screen upside down. I can't figure out how to...
1. Press the KEYSTONE button on the remote control. 2. Go down to Manual with the \/ or /\ button, then press > to select it. 3. Select V:INVERT, or H&V:INVERT, to flip the image.
Mar 04, 2011 | Hitachi CP-X260 LCD Projector
My RUNCO projector is projecting upside down and we cant seam to fix it. Any advice?
1. Press the menu button on the remote to bring up the on-screen menu. 2. Select the Setup Menu 3. Select Picture Orientation 4. Change the configuration so that the image and text appear correctly.
Feb 28, 2011 | Runco Reflection VX-1c Multimedia...
Red Hue
Go into the service menu and turn down the red push and red cut a few notches. Write down every value in the service menu and be careful to make sure you don't change anything else. Also, turn down the brightness a couple of clicks and the red glow will be gone.
Or, try this - Press Mute on the remote control twice, press Mute a third time and keep holding at the same time, press the Menu button on the TV front panel. If you do it correctly, you will see a small S on the screen. Congrats, you are in service mode. Press Menu on the remote to get to the adjustable settings. Be careful not to change anything without writting the original value down first. Also be careful of hitting other buttons on the remote. To reduce red push, Use the channel up down button until it says RCUT. Adjust the value using the volume button on the remote. I recommend setting RCUT to 80H, which is the preset value according to the service manual. To exit Service Mode, simply power off the TV. Good luck.
Jul 04, 2010 | Toshiba 51H84 51" Rear Projection...
Upside down screen image
Try pressing the Ctrl+Alt+Upward Arrow key
Regards
Apr 09, 2010 | Toshiba Satellite Pro A200-EZ2204X...
Why is image upside down? the image appears inverted on the board
You need to set up the image using the menu. Press menu button on the remote then use the arrows to go down the list until you come to "mirror". Now press the enter button on the remote several times to cycle the orientation of the image (on some remotes you may have to use the right arrow button instead of the enter button). The projector will remember this setting next time it is switched on. These options are there for people who use ceiling mountings that hold the projector upside down.
Jul 10, 2009 | Epson EMP-S3L LCD Projector
Upside down image
These projectors are designed to be mounted upside down. Think of a projector that is ceiling mounted in a classroom. Change this setting in Menu - Advanced Menu - Setup - Mirror.
Jun 09, 2009 | Hitachi CP-X445 LCD Projector
Upside down image
Mar 19, 2009 | Hitachi CP-X253 Projector
Image is upside down
Hit the menu/select button to bring up the menu either on the projector or on the projector remote then go down until advanced is highlighted then press the menu/select button then move down until Ceiling Project is highlighted and hit the menu/select button again to get the image right side up. If you have the manual for the projector this information can be found on page 34.
Dec 09, 2008 | InFocus LP 530 Multimedia Projector
CL-610 RUNCO PROJECTION SCREEN IS UPSIDE DOWN. Some one touched the remote control and I am at a loss to fix problem.
turn on your projector as usual, and using the remote, press the 'menu' button.
the menu will appear on the scree (albeit upside-down), and your looking for a setting like 'setup' or 'orientation'.
some runco's need a special code to get into some menus, but the orientation selection should be easy.
once you find the menu, there are usually 4 choices; front projection/floor mount, front projection/ceiling mount, rear projection/floor mount, and rear projection/ceiling mount.
the most common is 'front projection/ceiling mount'
Dec 08, 2008 | Televison & Video
Hitachi ED-A100 LCD Projector Logo
151 people viewed this question
Top Hitachi Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Hitachi Office Equipment and Supply Expert? Answer questions, earn points and help others
