Question about Fujitsu Siemens AMILO Pro V2010 Notebook
Shutting down My fujitsu Siemens Amilo notebook keeps shutting down, it seems like it is getting over heated and that one of the fans is not working
  • k-star May 30, 2008
    None of those things happen-the notebook just completely cuts out with no warnings or messages before or after.
  • 3 Answers
You have not mentioned much about the problem.
But it indicates a strong possibility of overheating.
Thats a safety feautre employed to prevent components getting burnt.
You may try going in bios and look for details.Some bios have information about recent failures.
also some motherboards beep next time its powered on.
also you might get a mesg on the screen just after you power on,saying that system shut down last time due to thermal heating.
hope all this helps
Posted on May 30, 2008
Where can you find the CMOS battery for Fujitsu Siemens Amilo PI3625
On the web!
Fuijitsu Siemens Amilo Xa 2528 CMOS Batterie - YouTube
? 6:39
www.youtube.com/watch?v=s8kKHChQ2sw
Oct 16, 2013 - Uploaded by MrHarsel Fuijitsu Siemens Amilo Xa 2528 CMOS Batterie ... Fujitsu-Siemens Amilo Pa 3553 - Disassembly and fan cleaning - Duration: 16:09. by ...
Sep 25, 2015 | Fujitsu Computers & Internet
Fujitsu Siemens amilo pro my lap top its some time very heat and shutting down
Try buying a cooler pad and puting under it? or geting a better processor van out in! I hope this helps!
Jun 02, 2011 | Computers & Internet
The computer runs for a few minutes than shuts down. it looks like the fan is not running. gets hot than shuts downs
basic solution would be to clean dust on fan just jumpstart it with a pencil end if this doesnt work replace the fan theyre not that expensive youre lucky your pc has a shutdown option before other parts are permenantly damaged,try lubricating the centre bearing of the fan also with a fine viscosity lubricant would be another option
Sep 10, 2010 | Fujitsu Siemens AMILO Xi 1546 Notebook
Laptop keeps shutting down for no reason leaving blank screen
If your laptop cuts the power off (shuts down) from time to time that may be overheating problem. Dust is blocking the air outlets on the fan and processor cannot be cooled down properly. Thermal protection shuts your laptop down when it reaches some certain temperature. Most likely you will hear your fan spinning full speed before the shut down and the bottom of the laptop is hot.
Best solution is to take it apart, remove the fan and the heatsink, clean them thoroughly, apply new thermal compound and assemble the laptop. Easy solution (though not the best one)is to buy compressed air can and blow it through the vents of the laptop. It will help for some time but occasionally it will start again.
Sep 06, 2009 | Fujitsu Siemens AMILO Pro V2000 Notebook
Amilo XI 1546 wont boot up
it seems that before shutdown system was updating pc (in all cases) windows update does this in silent mode so sometimes youre not to know.
boot up as normal...wiat a minute or so ...press and hold power button until pc shuts down completly(you can hear this) a light should be lit momenterily and then fade off.
you may now be able to reboot.
Oct 29, 2008 | Fujitsu Siemens AMILO Xi 1546 Notebook
Computor keeps shutting down
i think that you have a faulty fan do u still have a waranty for this i would contact the manufacture to find out
May 22, 2008 | Fujitsu Siemens AMILO Pro V2010 Notebook
Fujitsu-Siemens Monitor problem
MY LCD SIEMENS 15
I CONNET IT FROME POWER SPPLY (12 .V) IT WORKE BUT AFTER FEW MIANETS MONITOR ECIME WHIGHT WITH GROWPE LINES RED AND GOOWPE LINES BLUE COMEING AND GO QUKLY
Feb 24, 2008 | Mag Innovision LT776s 17" LCD Monitor
Fujitsu Siemens AMILO Pro V2020
check if the power botton ve not shifted on the board and confirm if the system was properly shut down,but if the problem continues try and repair the operating system.
Thx
Feb 21, 2008 | Fujitsu Siemens AMILO Pro V2010 Notebook
Sony PCG-F340 keeps shutting down
Old Sony laptops do this when the battery is dead, or the charging system is below required voltage. A battery with a dead cell (which this sounds like) can damage your external PSU and internal battery/power regulator circuit. Remove the battery (shut down and disconnect PSU first). You can run the laptop forever, without the battery, if you cannot find a battery replacement, or do not like the cost. Obviously, though, the laptop will not run at all without the AC/PSU connected when the battery is removed.
Feb 08, 2008 | Fujitsu Siemens AMILO Pro V2000 Notebook
Amilo pro 2030v faan
We did not find any results for Fujitsu > AMILO Pro V1000 (FAP:GBR-147150-H01 ) needing a fan for my laptop computer. Other searches you may want to try: Related searches Click on the Link above, Good Luck.........Please dont for get to Vote, Thank You.
Dec 15, 2007 | Fujitsu AMILO Pro V1000 Notebook
Fujitsu Siemens AMILO Pro V2010 Notebook Logo
371 people viewed this question
Top Fujitsu Siemens Computers & Internet Experts
Alun Cox
Are you a Fujitsu Siemens Computer and Internet Expert? Answer questions, earn points and help others
