Question about Philips HSB3280
How do you fix the wireless sub connect/disconnect problem?
Tip
ERROR CODES AND DESCRIPTION
2X Blink - Main Power Error
A 2X protection mode blink pattern can be activated due one of the
following defects.? Loss of REG12V (LVP)*
? Loss of -125V (Single Line)
? Excessive -125V Level (OVP)*
? Loss of Power-ON Signal
? Excessive PFC Voltage (OVP)
? Excessive PFC Temperature (OTP)*Low Voltage Protection (LVP)
*Over Voltage Protection (OVP)
For more check the following link. Use the search tab on the top right corner to find your product
www.electro-medical.blogspot.com
google.com/+AjinGopakumar
on Feb 15, 2015 | Sony Kdl-32ex720 - Series 32" Ex720 Bravia...
Internet keeps crashing
First, you will need to make sure your internet provider is not the problem, use a second computer on the same connection to be sure. If you are on wireless open the window on the wireless icon, click on repair and windows will fix the connection in most cases. If on ethernet direct connection to the modem sub another cable to make sure the link is solid.
Mar 04, 2012 | Acer Aspire 5742Z6682 Notebook
Flashing code s/w chk
It is just that main unit is looking for the "Wireless sub-woofer" and shows this message when it can't find the sub.
wireless connection between main unit and sub should be reset.
Mar 11, 2010 | Samsung HT-X810T Theater System
One sub works other doesn't
Disconnect the wire from the speaker and meter it out. check it for a dead short, the meter would read 1..... You can also check the action of the sub by pushing on the center lightly, moving the cone. If it's blown, it will not travel smoothly. If your meter reads ......1 then you've really done it and totally cooked the wire clean thru, thus no resistance. Hope this helps.
Sep 29, 2009 | Xtant A3001 Car Audio Amplifier
Here's my problem: I have 5.1 logitech speakers. The plug where the yellow jack goes into the subwoofer seems to be broken. No sound coming from this speaker (rear left). The problem isn't in the cable...
2 possibilities, either the connection coming out of the sub has gotten disconnected on the inside of sub or that channel is bad on your amplifier in the sub. The only way to know for sure is to open the sub up and ck.
Aug 02, 2009 | Logitech X-530 Computer Speakers
Need the Boston tvee sound bar repaired. Making popping and cracking noise when power is on.
Haven't fixed it yet. Going to find a electronics repair shop locally and have them repair it.
Thanks.
Apr 11, 2009 | Boston Acoustics TVee Model Two TV...
Philips HSB3280 Logo
35 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
