Question about GPS
My samsung bluetooth wep 490 has a blinking red light while on the charger. Do you know what is causing this and how can I fix it?
SOURCE: samsung bluetooth wep-210
After charging hold the front button under the samsung name down until the blue light flashes.
caster44
Posted on Jan 07, 2008
SOURCE: samsung bluetooth device pass key ?
Try 0000
Posted on Jul 27, 2008
SOURCE: can't power on
Same problem
Posted on Oct 24, 2008
  • 26 Answers
SOURCE: Steady Red Light
From the sounds of this.. It's all due to bad keying of the polarized charging plug. The solid red light PROBABLY means you're battery is pretty darn dead. It'll need a new battery(not worth the cost imho. get a new jabra, and be happy once again) At a certain low voltage, the red light starts blinking. when it drops below the preset threshold, it will shut off completely. If it sits too long at this discharged rate, the battry WILL self-terminate. If the voltage drops below a certain level, it's ruined. Also note, most Li-ion cells will only last a few years. 2-3 years of "full power" is usual. Mine's 2 years old(steady usage), and showing signs of it's age.
"My red light won't go off even though I charged it all night.
Also, a small piece of plastic came off the charge opening. I don't know if this is will pose a problem to the use of the Jabra BT150."
This is probably the most telling bit of information. It means you DID plug the charger in upside down. It will NEVER charge in that configuration, as it is supplying power to the completely wrong pins. If the battery was good to start with, it shouldn't hurt the headset, but never know. I have accidentily plugged it in backwards for a couple min before noticing, with no ill efect, but YMMV.
"Doesn't anyone from the Jabra manufacturer check this site?"
NO (especially not for discontinued products)
Posted on Jun 01, 2009
  • 108 Answers
SOURCE: samsung wep 200 bluetooth #
try this website:
website
http://www.alternativewireless.com/samsung/Samsung-WEP200G-quickstart.pdf
Posted on Jan 22, 2010
Help with samsung headset WEP 350
With that much charge time on it with no results, I'd suspect the battery is gone. You might try Samsung's website to see if a replacement battery is available.
Jan 27, 2016 | Samsung WEP-350 Bluetooth Headset
BLINKING RED LIGHT WHEN TRYING TO CHARGE UNIT
I fixed this problem by connect it on the charger,hold +and - keys together for 10 seconds,it started to charge and work well.
Jan 21, 2014 | Motorola Mobility H730 Bluetooth Headset
A forgot my passkey for bluetooth on my s3650
Default passwords for bluetooth devices are usually 0000 and 1234 and 4321.
Mar 08, 2011 | Samsung S3650 Corby blackwhite + WEP 490...
How to disable the GPRS of samsung corby thanks
Try pressing the call disconnect button twice in idle mode :)
Jul 20, 2010 | Samsung S3650 Corby blackwhite + WEP 490...
How to format samsung phones?i want to FORMATthis phone
You can't format it, all you can do is to reset it, this will wipe all customer settings and brig it to default ones.
Jul 11, 2010 | Samsung S3650 Corby blackwhite + WEP 490...
Pairing the Samsung WEP 210 headset to my Samsung Soul phone
Pairing Instructions
Pairing will create a unique and encrypted wireless link between two Bluetooth enabled devices, such as your Bluetooth phone and Bluetooth headset.
Ensure that the headset is off (see Turning the headset on/off).
Press and hold the Multi-Function button until the indicator light turns on in blue (approximately 8 seconds).
Set your Bluetooth phone to discover the headset by following your phone's guide. Typically, the steps involve going to a Setup, Connect, or Bluetooth menu on your phone and then selecting the option to discover Bluetooth devices.
Your phone will find the Samsung WEP210 headset and ask if you want to pair with it. Confirm this by pressing the Yes or OK key.
Enter a passkey or PIN, 0000 (4 zeros), then press the Yes or OK key.
Aug 21, 2017 | Samsung Bluetooth Headset WEP-210 B2700...
Samsung wep 150
I think i know why your bluetooth goes red then green. It is because your using a wrong charger like different make of the the charger or is it you never use it for a long time so is completely dead and you have to buy a new charger or bluetooth.
Nov 12, 2007 | Samsung WEP-150 Wireless Headset
GPS Logo
196 people viewed this question
Top GPS Experts
Are you a GPS Expert? Answer questions, earn points and help others
