Question about HP Pavilion dv1000 Notebook
In my system, while playing mp3 songs audio is not coming and error is coming like:Error ID = 0xC00D11BA, Condition ID = 0x00000000
    President:
  • 2,291 Answers
Open the Control panel 2. Open the "Sounds and Audio Devices" icon. 3. Verify the "Place volume icon in the taskbar" checkbox is checked. If this option is not available or is grayed out, skip to the next section of this document. 4. If you were able to check this box, click ok and close out of this window and the Control Panel. 5. Double-click the sound icon in the Systray and verify that all the sound volumes are mid-way or higher.
Check Windows services. Right Click My Computer and Manage. Choose Services and Application > Services. Choose "Windows Audio" and set to Automatic and Start. Now next you can do is If you open control panel & click device manager the window that opens will show a list of all installed hardware. Look for anything with an exclamation mark beside it, or to do with sound. If you see anything, right click it, check it isn't Disabled then select "Properties." The next window should have some tabs along the top, the one you are looking for is "Driver," you should now see an "Update driver" button. Check ur sound card information by doing this Click on start menu Click on Run Type dxdiag, enter Click on the sound tab There is button of test direct sound click on this check if there is sound Check ur registry. Check if the sound registry key is enabled or disabled. There could be an error in registry, run registry cleaner reg in out to scan for errors.
repairing windows Once you enter the setup and it loads the entire program, then you need to press the R key, which is for repairing the windows installation. This action will take you to the dos mode where further processing will be done. In the dos mode, system will ask you about installation place. Most of the people install their operating system in the C drive, which comes at number 1 option, so you need to press option 1. However, if you have so many partitions or you have installed the operating system then you need to choose the option according to your drive name. Here you need to enter your password as well, but if you have not set any password then you can simply press enter.
*Then there will be a c:\WINDOWS> command in a dos mode where you need to write, "Copy d:\i386\ntldr c:\windows. However, if you have different place of your installed operating system then you will write the address of that drive. This is the whole process and now you can eject the cd and can press exit to restart the system. Now this process will copy the correct NTLDR file from installation disk to your hard drive by making your system in the working condition.
Remember to fix your Windows registry with Reg In Out Registry Cleaner and PC Optimizer
Posted on Oct 12, 2010
Generally the cause of this kind of error varies from case to the next.
What kind of file are you trying to play? That's the first thing. WMP won't play everything. And if it is say, an .rm or .qt file, forget it.
The first thing I would do is reboot the system.
[1] There is a thing called chip creep where the contacts of a device get too hot and the cause the device to 'creep' out of it's slot.
[2] The driver files may be corrupted and need to be re-installed.
[3] Check Device Manager and see if the sound device is functioning properly at all. There could be a resource [IRQ] conflict-something that is rare nowadays but still does happen-in which case you need to change the IO address.
[4] You may have incompatible audio applications running or need a codec for the file you are trying to play; or the file may NOT in fact be a genuine audio file [DELETE IT IF IT ISN'T!].
Mar 21, 2011 | Microsoft Windows XP Professional for PC
Your sound card might be in use by another application.
0xC00D11BA: Cannot play the file
Windows Media Player cannot play the file because there is a problem with
your sound device, such as a sound card or sound controller. You may
encounter this error message for one of the following reasons:
Your sound device is in use by another program. Quit other programs that may
be using your sound device, and then try to play the file again.
Your sound device is not functioning properly. To troubleshoot the problem,
see the Sound Troubleshooter in Windows Help or refer to your sound device's
documentation.
You do not have a sound device installed on your computer. Install a sound
Apr 10, 2010 | Microsoft Windows XP Professional for PC
Sound problem
reinstall your sound card driver using the driver cd that came with the system. download Media Codecs. if same hing happened. you an download VLC player to play you video file instead of using media player.
Apr 04, 2010 | Computers & Internet
Error ID = 0xC00D11BA, Condition ID = 0x00000000 occurs when playing audio
http://www.tech-archive.net/Archive/Media/microsoft.public.windowsmedia.player/2008-08/msg00136.html
Nov 17, 2009 | Computers & Internet
My sound was not working with the hcl motherboard it is not functionig so i want the hcl motherboar sound driver. when i run wmp the the error Error ID = 0xC00D11BA, Condition ID = 0x00000000 is comming...
if you still have your motherboard cd, run it it will eradicate the problem.
or alternatively, find a Foxcom motherboard cd, it is suitable with most motherboards and it might install all the drivers necessary including the one for sound.
thank you
wonder
Sep 18, 2009 | Intel Computers & Internet
No sound
have u installed the correct driver for ur hardware..??
Jun 04, 2009 | Intel Microstar MS-6526 Pentium 4 ATX...
this should help steve.
Feb 27, 2009 | Computers & Internet
Problem in getting sound
Check does you sound driver is install OK!!! If not
(right-click My Computer -> Manage -> Device Manager) for unknown/improperly installed devices.
Visit you SOUND manufacturer’s website, and download drivers along with the installation instructions!!! After that it will work just fine!!!!
Jan 23, 2008 | Computers & Internet
HP Pavilion dv1000 Notebook Logo
56 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
