Question about Toshiba 50HP66 50 in. Plasma Television
There is a thin (One Pixel Wide) Line appearing in the middle of my Screen running vertically from top to bottom. What can I do? Could this be a power issue (Power Conditiong unit maybe needed?), I recently moved to an older house, don't know if its the power or prehaps I damaged it in the move?
  • 1 more comment
  • swensodts Oct 08, 2010
    Sounds to be a Viable option for me to undertake. I appreciate the response. Just a few quick questions before I proceed however. Is there any chance it is the entire panel? Also, should these problems be obvious to me i.e. will I be able to see them with the naked eye or should I test with my MultiMeter? Lastly, in regards to the capacitors, how do I discharge the energy from them or safely disconnect them without surge? If that is the problem. Where would you suggest I buy replacement parts if needed also? Radio Shack?
    If this works, you are awesome man!!!! Thanks So Much.
    Your the man
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. From what you have described it seems to be an issue with Y board however, Z and the logic board should also be checked. These boards are located on the right side of the unit and to check them you'll have to open the back of the unit. Once you have opened the back also check for any blown/bulged capacitors. All this is only recommended if you have electrical expertise & know how to solder/re-solder components as these units contain high voltages even when in off position.Please accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Oct 08, 2010
  • Rylee Smith
    Rylee Smith Oct 08, 2010
    There is slight chance that it might be the board
    completely however, you'll have to check it. Yes you can see bulged/swollen
    capacitors with the naked eye, in case if you don't see any then test the connectors
    with voltmeter going from power supply to the boards.
    You can leave it unplugged to
    discharge energy and you can buy the parts from radioshack or from this link.
    Thanks
    Rylee
    There is slight chance that it might be the board completely however, you'll have to check it. Yes you can see bulged/swollen capacitors with the naked eye, in case if you don't see any then test the connectors with voltmeter going from power supply to the boards. You can leave it unplugged to discharge energy and you can buy the parts from radioshack or from this link. Please accept the solution if the issue is resolved or post a comment for further assistance.
    Thanks
    Rylee
Thin red line running from top to bottom of screen
What is this thin red line that is on my screen whenever my ...
https://answers.yahoo.com/question/index?qid...
Sep 23, 2010 - There is a very thin red line going from the top of my computer screento the bottom, ... If it's a single-pixel-wide red line from top to bottom it's a failure in ....have thin red lines running down the screen??some are thicker than ...
Thin Vertical Red Line [Solved] - Acer - Displays - Tom's Hardware
www.tomshardware.com > Forum > Displays
Tom's Hardware Guide
Jul 12, 2013 - 5 posts - ‎2 authors
hi all i am having a Thin Vertical Red Line on my Acer LED moniter ... the screen is having a part fail(cable or the screen/control board it self.).
Why is there a straight vertical line going from top to bottom on ...
forums.androidcentral.com > ... > Samsung Galaxy S6 edge
Apr 15, 2015 - 7 posts - ‎4 authors
Just bought the Samsung Galaxy s6 edge yesterday. After I charged the cellphone for the first time and turned it back on there was this straight.
Jan 26, 2016 | Samsung UN60ES6100 60-inch LED TV
How do I remove three vertical colored lines from my Television. One vertical line is green another is red and the final one is blue.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
May 24, 2015 | Panasonic Viera Tc-p50u50 Hd Plasma Full...
My lcd television has developed a thin vertical line. It is on all the channels and comes and goes. We tried diconnecting and then reconnecting the satellite cable without change
Hello; If this line goes fully from top to bottom, You have a bad LCD panel. These lines can come and go. The fact that the line is thin , or one pixel wide, proves a bad LCD panel. If the line goes only part way down or up the screen, You likely have a cracked LCD panel ( never covered by warranty ) The LCD panel will cost more than the set sold for ! John
Jan 22, 2011 | Emerson LC320EM9 32 in. LCD HDTV
There is a thin blue vertical line, top to bottom that appears on the right hand side of the monitor,
it is a dead line much like a dead pixel the screen will need to be replaced
May 08, 2010 | Computers & Internet
Black vertical line appears on plasma tv screen
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Jun 03, 2017 | Philips 42PF7320A 42 in. Plasma HDTV
Vertical red line through screen
This is a problem within the screen, probably the connection from the internal ribbon connector to the display. Unfortunatly the only way to repair this is to have the screen replaced.
Dec 26, 2009 | LG 42LC2D 42 in. LCD HDTV
I HAVE GOOD AUDIO BUT A THIN LINE IN THE MIDDLE OF THE SCREEN THAT HAS VIDEO. ALSO THE SCREEN IS BLACK ON THE TOP AND BOTTOM WITH THE THIN LINE OF VIDEO IN THE MIDDLE.
Have you vertical deflection circuit checked for bad Vertical IC, and or Bad vertical Capacitors in the vert output section for the deflection board. Also have Vertical output Pump up Capacitor replaced, also have B+ voltage check coming from flyback transformer, for any open fusible resistors
Oct 12, 2009 | JVC AV-20120 TV
Green line
sharp is very aware of the panel and main video processor problems.They should give you no problems on the repair.It sounds most likely you have a main video processor problem.
Mar 13, 2008 | Televison & Video
Vertical, pencil-thin blue line appears after 10 minutes of viewing (any source)
I would suspect a connection breaking down as the set heats up. A shop will probably have to put the set in a stand to hold it while they check for loose connections or defective components inside. Not a DIY job by any means. If this line went completely through the picture either vertically or horizontally and stayed there then this would have indicated a failure in the Panel itself. A thin Line any where on the screen consisting of one pixel in width is a Panel Failure according to Hitachi.
Jan 01, 2007 | Hitachi 55HDT51 55 in. HD-Ready Plasma...
Toshiba 50HP66 50 in. Plasma Television Logo
587 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
