Question about Kenwood KDC-322 CD Player
Im trying to hook subs up in my car and i dont knw which wire on the back of the cd player is the rem
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Kenwood Master
  • 2,226 Answers
It would be blue/white
Posted on Oct 08, 2010
Kenwood KDC-135 remote wire
should be a solid blue wire
Jul 24, 2009 | Kenwood KDC-135 CD Player
DXZ545MP rcas to sub amp
Blue white is remote to amp.... Grey and black are your RCA out to amp...
Jan 26, 2009 | Clarion DXZ545MP CD Player
YEs i have a Kenwood X592.And my subwoofers only beat when the tuner is on.when i place a cd or my jump drive in all it does is play the music.the subs dont work
you have the remote amplifier turn on wire hooked up wrong. The power antenna goes off when the radio does... so it will lose power when you put in a cd or go to aux.
install the blue wire labled AMP. or REM.
Problem solved.
Dec 24, 2008 | Car Audio & Video
Sony output problem
All i did was mess with the REM wire, and found out i had to hook the REM wire to the blue/white wire on the deck. Instead of the blue/white wire, i had it hooked up to the solid blue wire on the deck which was preventing my amp from playing on CD.
Nov 22, 2008 | Sony TA-E9000ES Amplifier
Music not playing from subs
Do this for the sub amp...
With your multimeter set to DC volts, the black meter lead on the ground terminal of the amp (not on the point where the ground wire connected to the vehicle) and the head unit on (so the amp will have remote voltage applied), touch the red lead alternately to the B+ and remote terminals of the amp. If the voltage is below ~11 volts, you need to check the wiring feeding whichever line is too low.
Jul 03, 2008 | Kenwood KAC-9152D Car Audio Amplifier
How do i hook up the r.c.a to the back of VM9312
try hooking up your rem wire I.E. blue/white wire to blue wire (not to power antenna) then check ground and power wire. never hook up power wire while car is on...you will blow amp
Mar 18, 2008 | Jensen VM9510 Car DVD Player
Amps wont stay on
try to look at the connection on the back of the cd player and make sure that the amp power wire is connected to the power wire on the wire harness on the back of the cd player and that should work but i only need one amp for a pair of 6by9s and subs try to bridge the speakers all to one amp that should cause it to sta on while in cd mode hope that helps
Dec 26, 2007 | Kenwood KDC-MP435U CD Player
No sub when listening to a cd
you're using the wrong remote output wire. You have it hooked to the power ANTenna wire (blue) which turns off when not using the tuner. You need to use the REM OUT wire (blue w/ white stripe).
Oct 14, 2007 | Sony CDX-M630 CD Player
Amp help
it might not be the amp that is not working it could be the sub or sub's. Try takeing a sub out of the box and look down the hole in the center of the magnet on the back of the sub and look and see if you can see any wire's or any thing that has come unwound in the sub and if you do see wire's then you have blown your sub. If you dont see any wires then you could completly disconect your amp for 20 to 25 minutes and then plug it back in and see if that fix's your problem. If none of this works then you can take your amp to an audio store and have them test the circut board in your amp.
Dec 22, 2006 | Sony Xplod XM-1652Z Car Audio Amplifier
Kenwood KDC-322 CD Player Logo
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Jeff Turcotte
Jeff Turcotte
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
