Question about Standard Horizon CP155C GPS Receiver
My cp155c got moisture inside. I left it out in the sun for the moisture to evaporate and took the back off to check for moisture. I did not see any. When I plug in the unit I hear beeping and it will not power up
  • 4 Answers
Standard Horizon Factory Service
10900 Walker St
Cypress, CA 90630
Posted on Oct 11, 2010
How do I get water out of my coolpad phone without using rice or salt
possibly not able to
however if you get a sealable container big enough to place you unit in it and still have it off the bottom of the container there are silica gel ( same stuff that is in the small packets that come in new packaging in electronic equipment) products available from the hard ware shops that remove moisture from the air ( look for moisture remover products to put in ward robes, pantries etc)
over time that will suck the water out of the unit, especially if the container is left in the sun to assist with the moisture evaporation process
Salt will cause corrosion problems and rice may be slow
May 07, 2016 | Cell Phones
Is this normal for Miele dishwasher? - some water left below filter and not everything dry after cycle
Plastic items do not get dry because they do not get as hot as glassware. A lot of moisture inside is do to the evaporation of water on the dishes during the dry cycle. Some water remains in the dishwasher because it is impossible to pump all of it out. There is nothing wrong with your dishwasher.
Oct 31, 2015 | Miele Dishwashers
Water damage
If this was salt watercor contaminated water, then the only chance is to immediately remove the battery and rinse the Phone several times in clean pure water to remove the conductive salt / contaminated water. Then leave it to dry out in the sun or in a warm place for a few hours until all the residual moisture evaporates & drys out. With any luck the phone will turn on and work. If it was left with salt water or contaminated water for a long period before rinsing this may lead to permanent internal damage.
Nov 01, 2013 | Motorola Mobility MOTO W755 Cellular Phone
Water (vapor) under the crystal
Water condensation on the inside of your watch crystal means that moisture has entered your watch, most likely through the hole in which the setting crown/stem is fitted, or, possibly, through the door of your battery compartment. It's usually easier for water to enter a watch then to leave it again. Water inside a watch can quickly corrode delicate parts, causing erratic timekeeping and premature failure of the watch, so you'll want to get it out of your watch as quickly as possible.
Fortunately, it's not that difficult to get moisture out of a Swatch. Pull the crown out into the time setting position and remove the back battery hatch. Then, turn the watch face down and leave it in the sun for a few hours. If you're worried about dust and/or rain getting into your watch, leave it inside a parked car that's in the sun--that will actually speed up the drying process, as car interiors, with the windows closed, quickly heat up far beyond outside ambient temperatures (except in winter). If it's dark outside, you can accelerate the drying process by using a hair dryer set to low / medium heat and heating the crystal gently until the moisture has evaporated. You don't want to heat the crystal too much or else it may start to melt or crack.
Once the water is out of the watch, close up the battery compartment and update the time/date for your watch. You should be good to go, as long as you try to keep your watch dry when doing things like washing hands and the like. If you had been doing so, it's also time to stop wearing your watch when you shower, wash your car, or engage in other activities where the watch is exposed to a lot of water.
Jun 01, 2011 | Swatch Watches
I dropped my phone in the tolit and i took the battery and sd card. i dried it. all 3. then i used a blow drier. then put it in rice. will it work?
Yes it will work, since you have taken out a great quantity of water from it using the blow drier.
The steps to get it to work are:
  1. Remove the back cover,
  2. Then remove the sim card and the scan disc memory card,
  3. Then try to open it up by using a torx screw driver,
  4. then slide an object around the edges of the phone to remove the front cover,
  5. Then blow dry it for a while,
  6. Take note not to get the blower too close to the screen to avoid damages,
  7. Reassemble the phone back together and turn it on.
It will work perfectly fine. Since you have done most of the job, just carry out the rest and turn it on.
Take care and good luck
Dec 22, 2010 | Cell Phones
I need an operating manual for a Standard Horizon CP155c chartplotter
please call Standard Horizon Marine Support 800-767-2450 and they will email you the manual.
marinetech@vxstdusa. com
Sep 10, 2010 | Standard Horizon CP155C GPS Receiver
Got water damage and wont turn on
I dropped my phone in the toilet and surprisingly it still works. First I took the battery off and dried the phone and battery as much as I could. Then I took my blow dryer and a towel where I folded the towel in half and positioned the phone and the blow dryer under the towel and left it going for about an hour. The next day I took the phone and sat it in the sun until the inside moisture was gone. Then I charged it my phone has been working fine ever since and that was nearly two months ago.
Oct 05, 2009 | LG CHOCOLATE VX8500 Cellular Phone
Does the product a/c have a drain hole?
Air conditioners of your type have tiny passages that allow the water (if clean) to go to the back of the unit where a splash ring on the fan blade whips the water onto the hot condenser coil, eliminating the condensate outdoors and subcooling the refigerant in the condenser in doing so.
If you have water inside and its level or slight tilt back , then you need to clean it up or forget it!
Aug 25, 2009 | Fedders A6U10W7A Thru-Wall/Window Air...
How to repair my mobile phone screen at home Nokia E61i . No Display on screen may be due to moisture or water getting inside and even the screen is flikring
Well leave ur phone in sun after removing ur battery and sim. Leave it there for 2 hrs. check if still moisture is there. if yes use a hair dryer. and then whn u sure there no more water in there out back ur battery
Aug 11, 2009 | Nokia Cell Phones
GPS Logo
108 people viewed this question
Top Standard Horizon GPS Experts
Steve
Steve
Mister Danger
Are you a Standard Horizon GPS Expert? Answer questions, earn points and help others
