Question about Pioneer SD-P50A5-K 50" Rear Projection Television
I turn my TV off everything was ok..then I turned it back on but no picture sound only ,,,why ?
You might try do a hard reset. turn tv off unplug it hold power button on tv for bout 30 sec. then plug it back in. i had a similar problem and this worked for me.
Posted on Oct 12, 2010
No Picture now No Sound
main board faulty check tuner poss dry joints
Nov 22, 2012 | LG 37LC7D 37 in. LCD HDTV
Dynex 32" tv picture goes black
If there is still about ? 24. Volts coming from the Power Board when it goes dark, it will be the Inverter board that needs replacing. If not, it is the Power Board that needs replacing. The Voltages should be written next to the sockets & plugs on the Power Board.
Jun 02, 2010 | Dynex 32 in. LCD Flat-Panel HDTV
Kenmark 20" LCD TV Sound but no picture
My Kenmark Tv Switches its picture off if the PSU voltage drops. Audio is OK but picture does not return as PSU voltage goes back up. PSU's are about £10 online !2Volt 4A Might be worth a punt
May 04, 2009 | Zenith IQC50H95W 50" Rear Projection...
No picture when TV is turned on, sound is OK
try to look at its circuit board and look for cold solder or loose solders usually solders with crack,they might be the problem,i dont think its the flyback coz you have audio.try also look at its picture tube at the back tru the crt if the filament is ok or it may also have loose connections
Jan 13, 2009 | Samsung TXJ2554 TV
Picture on TV stuck on one picture
Ok fixed it. Just unplugged the box and plugged it back in and it works fine.
Apr 05, 2008 | Directv Plus DVR DTV Receiver / 100-Hours...
No picture, but power light is on
THE POWER SUPPLY OF YOUR TV WAS THE PROBLEM,YOU COLD SOLDER THE MAINBOARD OF YOUR TV,AND THE CRT SOCKET CONNECT TO THE TUBE IS ALSO COLDSOLDER,.
Mar 13, 2008 | RCA 27F530T 27" TV
Lines on tv
Set starts, horizontal and vertical deflection work, HT ok, crt heaters ok, but no sound or picture
I turned the G2 voltage up and noticed a white screen with flyback lines, frame ok. I detected two badly soldered double diode rectifiers in the secondary part of the power supply ! I checked all other joints, and everything was ok !! success
White horizontal line (no vertical deflection)
Check / replace R548, R549
Sound but no picture except for a couple of horizontal colour lines
Replaced the frame chip TDA8356, set now ok
Nov 23, 2007 | Mitsubishi WS-65511 65" Rear Projection...
SAMSUNG PICTURE FREEZE (LOOKS BLACK&WHITE)
I have the same problem... It turns B&W
I can still hear the sound... however I can still turn the tv off when that happens
Aug 28, 2007 | Samsung HLN617W 61" Rear Projection HDTV
Pioneer SD-P50A5-K 50" Rear Projection Television Logo
60 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
