I do not have the correct code for the playsonic tv.I am using BB-TV154 8 in 1 TV remote control.Please could you advise me on my problem.Thank you.
  • 20 Answers
Try the last 3 or 4 digits of the TV's serial number. That worked for my ATD TV after all else failed.
Let us know if it worked or not, thanks.
Posted on Oct 08, 2010
Palsonic TV PDP4225HD Please advise code for use with universal remote control device. Thank you!
Have a look at the code list of your universal remote control manufacturers web site.
Apr 18, 2018 | Universal Remote Control Televison & Video
Signature sr 100 remote sanyo tv please help reprogram
can you please give more detail on your remote control ?
thank you,
dan
Thank you.
Dan
http://www.rylwy.com/
May 20, 2014 | Electronics
The television has somehow gone into child lock mode and we have no remote control. Please advise how this can be removed without using the remote or please could you supply an unlock code which can be...
Unlocking child mode lock it is very difficult and nearly impossible without the tv original remote and the secret password word.Tries tv unplug,replug the tv back like about 24 hrs later.That all u could do,some tvs will reset itself and erase the password.
May 07, 2011 | Televison & Video
Can't find a code for my ATT Uverse remote. Bought the set in China and brought it back to the US.
Hi! Welcome to FixYa!
You can program your AT&T U-Verse remote control using the Automatic Code Finder. This step cycles through all possible codes for the type of TV you are programming until the correct code has been found. Please follow the steps bellow.
  1. Make sure that the TV you want the AT&T U-verse remote control to control is ON.
  2. With your TV on, PRESS AND HOLD DOWN, the TV Mode Key on the remote control. The mode keys are located at the top of the U-verse remote control. While holding down the TV Mode Key, press and release the OK button. If done correctly the Mode Keys will blink twice. The remote is now ready to be programmed.
  • The next step is to enter the code for the automatic code finder feature. That code is 922. Enter the code 922 using the Remote Control's keypad. You have 10 seconds to enter this code before the remote times out. When 10 seconds have elapsed the Mode Keys will flash once. If this happens just start over.
  • Next steps is start the automatic code finder search. Make sure you aim your remote control at your TV. Then press and release the play button on the remote control. Now press the Fast Forward key multiple times until the TV turns off. Then press Enter to save the code. Your remote now has the correct code. If done successfully the Mode buttons will flash three times. Press the Power button again to turn on your TV.
  • When the code has been entered correctly, the appropriate Mode Key will flash three times. To check to see if this code works, press the Power button. If the TV or DVD does not turn off, then we need the correct 4-digit code of your TV.
Please refer to the image bellow.
Thank you for using FixYa! Keep me posted. :)
Mar 12, 2011 | Televison & Video
No code for playsonic tv
If you have a Brookstone remote control this will work for you.
Here you go. This will work with most all universal remote controls. If you don't have the code do the following:
Automatic Programming
With automatic programming, the remote control tests all the codes available on the Code List and assigns the correct code for the selected device. Although this method can be more time-consuming, it eliminates the need to look up codes and enter them manually.
1. Turn off the device with which you want to use the remote control, keep in mind when not trying to use this sequence with any other remote than a Brookstone you might have to have the unit on when doing this, then it will turn off when you have the right code. I would try the first option first.
2. Press and hold the corresponding button on the remote control
(TV, VCR, SAT, DVD, CAB or AUD) until POWER INDICATOR illuminates. It should take a couple of seconds for the light to remain solid. The remote control is in programming mode.
3. Press and release power button. The POWER INDICATOR flashes once and stays on indicating the unit is in Power Scan mode.
4. Press CHANNEL up or CHANNEL down repeatedly until the device turns on.
5. When the device turns on, press OK to store the code.
Note:
• To exit without storing the code, press BACK.
• The unit will search for the next code or the previous code if you press
CHANNEL up or CHANNEL down after the device turns on. (go slow you need to press OK when the TV turns on) if you mess up turn TV off and start over.
6. Press any other button. If the device responds, the remote control has been programmed. If the device does not respond, repeat steps 2-5.
Fill free to ask me questions about anything..........................
Hope this helps, let me know if I can help you with anything else. It would be very kind of you if this does work for you to please rate me or leave a short note. I would really appreciate it. Thank you for your time.
JimmyC
Oct 31, 2009 | Televison & Video
I want to tune a vcr to a playsonic tv. the vcr
I don't have the remote control with me, how can I do to put AV1, without remote? Its that possible?
Mar 14, 2009 | Televison & Video
Tv remote for 32 inch toshiba flat screen tv
tohhiba codes 062,064,085,229,231,385. for cable tv converters use 019.
Oct 22, 2008 | Toshiba 32AF42 32" TV
RadioShack Universal Remote (Cat. 15-2147) - to use with JVC TV
programming a device: make sure batteries are installed correctly. Turn device on(for ex., your TV). Press TV button next to Power button on your 15-2147...Press and hold the little P button until the red LED lite blinks twice...enter the first four-digit code for your device(in your case,JVC TV...first set of #s is '0463' ) note: the LED will blink once as each number is entered. If the number is correct the LED will blink 2x. Note if the LED doesn't blink twice after entering the 4 digit code, begin again with the next set of numbers. For JVC the codes are 0463 and 0053. Once your remote blinks twice after entering in your TV code, press the power button. This should turn off your TV. Just use like any other remote. Hope this helps you.
Oct 11, 2008 | Radio Shack (15-2147) Remote Control
Televison & Video Logo
164 people viewed this question
Top Televison & Video Experts
