Where can I get a driver for Nexxtech 2608263 USB to Parallel Converter Cable for windows 7 ( or Windows Vista driver which may work on Windows 7)
3 Suggested Answers
TheSelkie
  • 734 Answers
SOURCE: Where can I get a
HI there,
Nexxtech products are manufactured by ORBYX Electronics and I've never encountered such a Byzantine Maze of misses trying to find these people for you, and could not. If there's a www address on your disc or a customer support # in any of your docs you can contact them and they'll email you a link to the driver.
In the meantime, 9.5 times out of 10, Vista Drivers will run on Windows 7 with 100% compatibility.
Regards,
Marcus
Posted on Sep 13, 2010
nadereleraki
  • 433 Answers
SOURCE: Need windows 7 driver for
upgrade windows 7 http://www.microsoft.com/windows/compatibility/windows-7/en-us/default.aspx
best regards
Posted on Mar 29, 2011
I have an old serial printer that works fine, I can not connect it to my new computer via a parallel to usb cable convertor on windows 7!
Hi craig931, First try downloading the latest driver of your printer and your usb converter compatible for windows 7. Second Checked your device manager if your printer and usb to parallel driver properly installed, it should be there. If not yet installed try using different usb port one at a time until the cable have been detected. Third if you see already the printer port force to change it to USB001 or Com1, then try to print. regards,
Sep 26, 2011 | Office Equipment & Supplies
Windows Update can't find Drivers for HP PSC 500 because it's connected thru parallel-to-usb converter. Any ideas? Thanks. Mark
This printer comes with a USB connection, why not use that instead of a parallel to usb converter? All you need is a USB A to B cable. You would have better luck then using a parallel convert, then download the driver for you device from here.
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?os=2093&lc=en&cc=us&dlc=en&sw_lang=&product=58710#N191
Chris
Jul 01, 2011 | HP Hewlett-Packard PSC 500 Scanner
I want to purchase the nexxtech usb 56k modem for linux windows vista and windows 7 my problem is my linux doesnt have a cd rom for me to use the disk is there a way i can download the drivers off the...
If there are even Linux drivers for this product, it is likely that they are already included with the distro and thus you do not need to download anything.
Mar 26, 2011 | Nexxtech 56K USB External Modem
I have nexxtech portable kit with a hard drive in it, it worked on windows xp, but winds 7 doesn't reconize it How do I fix this
Try your NexxTech on some other computer, to verify that it still works.
Try some other USB port on your computer.
Try some other USB device into the same USB port that you are trying to use for your NexxTech, to make sure that your computer's USB ports are working correctly.
Check that Windows 7 has loaded the device-drivers for your USB 2.0 ports on your computer's motherboard.
May 14, 2010 | NexxTech Portable Hi-Speed USB 2.0 Kit...
I bought some years ago a USB to Serial Port Cable Nexxtech. It work fine with Windows XP. But I buy a new computer and Windows7 can not read driver from the disc. What can I do?
You should look for new driver on the internet. driver for windows 7 or maybe vista, it might work. Windows XP needs different driver then windows 7.
Good luck
Mar 22, 2010 | Computers & Internet
I want driver for windows 7
It seems that Toshiba's latest driver for this device supports only Windows XP and Vista 32-bit.
Here are the links:
1. Scan/Print Driver, Win 2000/XP v2.30
2. Scan/Print Driver for Vista 32 bit
3. Button Manager for Vista 32 bit
Manufacturers usually drop support for older devices after some time. Specially for printers and scanners the support is even more limited; most of them (if not all of them) offer warranty of one year.
Your best shot is to try the Vista drivers. For printing you shouldn't have problems. When you install the printer Windows have generic drivers for supported (current/older) devices. This driver should work for printing.
For scanning you can try something like VueScan which is compatible with Windows 7. Toshiba devices are not in their list of compatible scanners, but you can never know...
Note that VueScan only works with SCSI, USB and Firewire connections, most wireless Canon and HP scanners (on Windows and Mac OS X only) and doesn't work with parallel-port connections.
This can be solved with a parallel to USB cable converter (be sure to check whether you need male or female parallel to male or female USB converter).
I hope this answers your request.
Nakis
Feb 16, 2010 | Toshiba e-STUDIO 120 Laser Printer
Problem printing from Dell Inspiron 1720 with Vista Home Premium to Epson Stylus Colour 1160 using Nikkai USB to Parallel Convertor. Cable supposed to be plug and play. Any pointers?
You pretty much said it when you mentioned "Other than buying the cable in the first place" I have never successfully used a USB to parallel converter cable on any system. My suggestion, asisde from getting a true USB printer, is a parallel port card
http://www.newegg.com/Product/Product.aspx?Item=N82E16839328010&nm_mc=OTC-Froogle&cm_mmc=OTC-Froogle-_-PC+Cards/PCMCIA+Add-on+Cards-_-Syba-_-39328010
May 16, 2009 | Dell Computers & Internet
Nexxtech 3.5" Hard Drive Enclosure (NHDE35)
I'm not saying this will solve all problems, but it solved it for me. I am running Vista and got this to work following someone's instructions from another forum.
The slot in the enclosure that you plug the hard drive into has one set of holes fewer than the hard drive has pins. This means you can plug the hard drive in two ways "left" and "right" if you will. I had to plug my hard drive in so that the unused pins were farthest from the power cable that plugs into the hard drive.
Incidentally this made the screw holes line up better, too.
Oct 01, 2007 | NexxTech Portable Hi-Speed USB 2.0 Kit...
Open Questions:
Televison & Video Logo
521 people viewed this question
Top Televison & Video Experts
Electro Med Services...
