Question about Kenmore 73952 Gas Dryer
Kenmore 739121 not heating
I am getting a glow but no iginition. Where it the thermal fuse located on this unit? Other thoughts?
  • tdcreutz May 30, 2008
    I replaced both coils (solenoids?) Where is the gas solenoid? Thank you!
    Scholar:
  • 110 Answers
YOU HAVE A BAD GAS SOLENIOD
Posted on May 30, 2008
Drum turns but no heat
First look to see if the ignitor is coming on. Most common problem is the ignitor is weak or just bad.
When the power is applied to the ignitor it glows and builds up resistance to open the gas valve then it lights. If the ignitor is weak or bad it will not build up enough resistance for gas to come into the burner.
One sign of this would be a "woosh" sound when it trys to light. If the ignitor is coming on but not lighting it is most likely the ignitor is bad.
Should have a full glow. Also, if the ignitor looks whiteish in color this is a sign of it going bad. You can compare to the broil ignitor to be sure.
There are 50/50 chances of thermal fuse blowinf up which does not heat.Regarding the thermal fuse I would recommend to replace it one more time and not to use the Self clean any more until you will perform all checks and repairs according to the service pointer. The thermal fuse is located at the back of the oven..
You can check about the pica and description of it over HERE
And one more thing if used the broil method you also have to replace the broil heating element due to low resistance.
So finally i just want to say replace the broil element and the thermal fuse and your problem will be solved.
Goodluck,
Please don't forget to rate me as fixya..
Feb 08, 2008 | Kenmore 62602 Electric Dryer
Kenmore 110.72832101 Dryer won't heat
You will have to remove the back panel to access this part. Be sure that you unplug the machine before starting. Once the back panel has been taken off and placed aside the thermal switch will be located on the left lower side near the blower housing . It will be thin and long and located near the cycling thermostat that has for prongs on it. On certain machines, the thermal fuse is located in the front. To access this you must remove the kickplate, which can be done by pushing the clips, one on each side jsut above the top of the kickplate, in between the top and abottom portion. The part numbers are the same for either style dryer. To test this part you can either take the wires off it and tie them together then plug the machine back in and see if it heats, or you can use amultimeter and check to see if there is continuity, if there is its good, if not, bad. The thermal fuse will usually be white, and if located in the back, be thin and long with two wires on it, left and right. If in the bottom front, it will be front center on the exhaust duct. In some cases the ignitor or the gas coils will go bad. Here is a good process of elimination.
1)Verify that the thermal fuse is good. If you don't have a meter bypass it and turn the machine on. If heats, thermal fuse is bad, if not leave connected and continue
2)When the dryer starts and thermal fuse bypassed, the ignitor should start to get hot and glow, if your thermal fuse is in the back you are going to have to have to the top of the dryer up to see down inside near the front for the glow. You can do this by taking the lint trap out and removing the two screws and popping the top up. If the ignitor comes on more than likely the gas coils are bad and if it doesn't the ignitior is bad. (this is while the thermal fuse is bypassed so the ignitor has power to it regardle
May 29, 2012 | Kenmore Dryers
Kenmore dryer, natural gas, model 11076112501 won't heat
Most likely a thermal fuse or thermal cut out. Check to see if it ohms open....if it does it is bad. It is located on the exhaust vent. If the lint filter is on the top you have to remove the back panel to get access. If it is in the door then you need to remove the bottom panel or the whole front panel to get access. Google thermal fuse for a pic. Usually caused by blocked or pinched vent hose. If the thermal fuse is ok then check to see if the ignitor starts to glow. You should have a small peep hole on the front panel that you can remove the cover and watch it start to glow...if it starts but does not get super blindingly bright it could be bad ...(not just an orange glow but very bright white) If that all works it could be the valve solenoids are bad- very easy to change.
Oct 02, 2010 | Kenmore Dryers
Range won't heat up
it is a glow coil , thermocouples are on units with a free standing pilot that you have to light, if you have a range like this you may need a thermocouple if not a free standing pilot you have a electronic gas iginition system that uses a glow coil, you turn on over setting and oven glows orange then iginites if this is what you have you need new glow coil, easy to repalce
Feb 03, 2010 | Magic Chef 9122 Gas Single Oven
Our kenmore # 110-728220 turns but no heat. replaced ignitor still no heat
Check the following areas to combat this issue. the most common problem spot will be a blown Thermal fuse.
1. Gas valve coils
igniter glows, then shuts off without igniting gas - the problem is probably with defective coils (black, located on top of the gas valve). It is recommended to replace all coils (usually two or three) if found defective.
Note: Sometimes the whole gas valve may be defective, thus not letting the gas out. However, this problem is not common.
2. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
3. igniter
igniter may burn out or break. Replace the igniter if found defective.
Note: Igniters are very fragile and break easily. It is recommended to handle the igniter only touching the ceramic part of it (usually white in color).
4. Flame sensor (or radiant heat sensor)
Replace the sensor (located near the igniter) if found defective.
Oct 13, 2009 | Kenmore Dryers
Kenmore gas dryer wont heat up
1. Gas valve coils
Igniter glows, then shuts off without igniting gas - the problem is probably with defective coils (black, located on top of the gas valve). It is recommended to replace all coils (usually two or three) if found defective.
2. Thermal fuse
3. Igniter
Igniter may burn out or break. Replace the igniter if found defective.
Aug 11, 2009 | Kenmore 73952 Gas Dryer
THE DRYER STOPPED PRODUCEING HEAT.
Check the following to address the non heating issue
1. Gas valve coils
2. Thermal fuse
3. Igniter
Jun 01, 2009 | Kenmore 73952 Gas Dryer
Kenmore elite gas dry 6 years old - no heat
PUT YOUR DRYER ON AIR FLUFF AND TURN IT ON. THEN SELECT A HEAT SETTING. IF YOU HEAR A DISTINCTIVE CLICK WHEN YOU SELECT HEAT, THEN CHECK FOR A GLOWING IGNITOR. MOST KENMORE/WHIRLPOOL DRYERS HAVE A PEEP HOLE IN THE FRONT LEFT SIDE OF THE DRYER. REMOVE A PLASTIC COVER TO VIEW INSIDE.
IF THE IGNITOR GLOWS, AND THEN CLICKS OFF, YOU HAVE A BAD SOLENOID (COIL SETTING ON TOP OF THE VALVE). IF IT NEVER CLICKS OFF, YOU HAVE A BAD RADIANT SENSOR( LOCATED ON THE SIDE OF THE BURNER HOUSING). IF NO IGNITOR GLOWING, THE IGNITOR IS BAD.
IF WHEN YOU SELECT HEAT, THERE ISN'T ANY CLICK, THEN THE THERMAL FUSE LOCATED BEHIND THE BACK PANEL DOWN NEAR THE EXHAUST IS BAD. IT IS A SMALL WHITE ITEM WITH TWO THIN WIRES ATTACHED TO IT.
Apr 07, 2008 | Dryers
Kenmore 73952 Gas Dryer Logo
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
