Question about Saniflo SaniPlus-Round SaniPlus Macerator Toilet with Round Bowl
I have a toilet with a push button flush mechanism (allowing half or full flush). The toilet has a macerator behind it. If you flush the toilet and the macerator jams, the push button stays stuck in and the water keeps coming, flooding the bathroom. This has happened twice so it is not a conincidence that the button sticks in when macerator blocks. What could be causing this and what is the solution?
This seems like a problem with your cistern and not your macerator - I have a similar set up and if your push button is stuck you need to check the mechanism in the cistern - also you should have an overflow that drains into your loo within the cistern so you should check this for blockages as well.
Posted on Oct 20, 2010
What's wrong with macerating toilet?
What is most likely the case is that the toilet is not properly vented by waste plumbing standards. Not all jurisdictions require macerating toilets to be vented, but by not doing so causes pressure in the drain lines as well as some suction which can pull water from sink traps, allowing odors and insects to get into the home.
Oct 23, 2015 | Home
Half flush does a full flush
It's not nessesarily a half flush just as little water as is possible for that toilet. The full flush has just a little more. It may be hard to tell the difference.
Nov 23, 2013 | Home
Saniflo float
check flushing mechanism at the bottom to ensure nothing blocks it and that it closes securely after flush.
Jul 24, 2013 | Home
Toilet wont flush
Here is a nice link for your saniflow maintenance.
http://www.plumbteamltd.co.uk/sanifloguide.html
This will may help.
Oct 22, 2012 | Saniflo Sanicompact 48 - One Piece Toilet...
Flush mechanism is stuck; unable to push buttons down to flush.
If it's electrical powered, you may have to spray alcohol in the buttons to free them, if urin or other contaminants have gotten behind them to make them stick to were there stuck.
Dec 27, 2010 | Caroma CARAVELLE270ADAW-EL Caravelle...
I have a Carlyle water saver toilet. The one that has two push buttons built into the toilet tank lid. It is a solid 1 piece toilet. My problem is every hour the toilet is flushing by itself. Had a...
Hello. Your lid has two buttons so you can do a half flush or a full flush. A water saving feature. Since the toilet is flushing by itself every hour or so, you must have a leaking flush valve. Replace the valve to solve that problem. Joe
Oct 12, 2010 | Toto Carlyle 1-piece Elongated Bowl Toilet
Weak dual flush does not empty the toilet bowl.
well, yes... but apart from providing you with a forum in which to vent your frustration I'm not sure how you think we might help. I have the same problem with a dual flush cistern, but in my case I know that the root of the problem lies in the fact that the soil pipe leading from the bowl has insufficient fall (because the previous owner of my house moved the toilet further from the down pipe). Maybe something like this is contributing to your problem too?
Jan 21, 2010 | Duravit 0910100005 Happy D Toilet Cistern ...
This was just installed. When it is flushed the
If there is a air emiten valve on vent ? Remove it than try to see if it works properly. If this works you will need pipe vent outside
Dec 21, 2009 | Saniflo SaniPlus-Round SaniPlus Macerator...
Kohler Toilet year old do not have flapper. It has stright pipe
This is how it is meant to work!
Short push of lever for small flush, push and hold lever for full flush.
Aug 16, 2009 | Kohler Toilet - One Piece with Ingenium...
My saniflo toilet wont flush
I think a small plastic item has dropped into my saniflo toilet it keeps maing a loud noise evey few minutes. hat should I do
Nov 15, 2008 | Saniflo SaniPlus-Round SaniPlus Macerator...
Saniflo SaniPlus-Round SaniPlus Macerator Toilet with Round Bowl Logo
1,885 people viewed this question
Top Saniflo Home Experts
Donni Steen
Paul Carew
Are you a Saniflo Home Expert? Answer questions, earn points and help others
