Question about Nintendo 64 Console
My n64 red screen
I have an n64 and i inserted a new expansion pak and i turned on my counsil and all i got was a red screen... so i plugged back in my stock one and all i get is this red screen... what can i do to fix it?
kadin
  • spiritkitten Feb 01, 2009
    I already tried blowing into just about every plug-in on the system, and it still gives me this weird dark red screen. I haven't tried using any damp cu-tips though. Mine is missing the cartridge that goes in front by the power and reset buttons. Is that important? That's something that I think plays a part in this somehow. Also, I haven't used it in a really long time because I thought it didn't work, and before that, I couldn't find a game I had that I wanted to play. Please I really like my N64 and I don't want to get a new one if I can fix it. Thanks for your time!
  • killercod45 Feb 04, 2009
    mine does the same thing
    Problem Solver:
  • 21 Answers
I had the same problem with my NES only my screen was Pink. I just get a very light damp cu tip and cleaned the trids on the cardriges or the expansion pack, maybe have dust in the insertion where the trids fit in, or on the trids. you could also blow air into the insertion port.
Posted on Jun 01, 2008
N64 powers up but no sound or video
Nintendo 64 - Blank Screen Troubleshooting
Quick Tip:
If your system is connected using AV cables and you cannot see the game on your screen, it is likely all you need to find is the input select on your TV or VCR. Link here for help.
Make sure your system is hooked up correctly. This is the number one reason for a blank screen. To ensure all hookup connections are firm and correct, remove the AV cables and reinsert them with a slight twisting motion (this will help fully seat the connections). For more information about connecting the system, check the following hookup steps:
Audio/Video Cable to a TV
Audio/Video Cable to a VCR
Make sure you are using all licensed accessories with your system. Unlicensed products are not fully compatible with Nintendo systems and may not work correctly.
Make sure the system has power. If you don't see the red power light when you turn your system on, go to the No Power Light instructions.
Slide the Power Switch on the Control Deck to the OFF position. Remove the Game Pak and re-load it, pressing firmly to ensure it is locked in place. Slide the Power Switch on the Control Deck to the ON position. (Inserting the game with the Power ON will result in a blank screen.)
Check under the Memory Expansion door (on the top of the Control Deck) to verify that the Jumper Pak or Expansion Pak is still inserted. If one is not inserted, slide the Power Switch to the OFF position, insert the Jumper Pak or Expansion Pak and slide the Power Switch to the ON position. Simply pressing reset will not solve the problem. You must turn the power off and then back on.
If the above steps do not resolve the problem you are experiencing, there may be a problem in one of your hookup cables and not your system. Try purchasing a new connection cable (how to buy replacement parts). You can also try borrowing the cable from a friend to see if it solves your problem before purchasing a new item.
If this does not resolve the problem you are experiencing with your system, your system may need to be replaced. For more information on what options are available, please click here.
Jan 04, 2013 | Nintendo 64 Console
I have all the wires hooked up right, yellow to yellow, red to red and white to white..the N64 powers up just fine, I have it on the AV setting, but I still can't get any video or audio. it's...
  1. Make sure you are using all licensed accessories with your system. Unlicensed products are not fully compatible with Nintendo systems and may not work correctly.
  2. Make sure the system has power. If you don't see the red power light when you turn your system on, go to the No Power Light instructions.
  3. Slide the Power Switch on the Control Deck to the OFF position. Remove the Game Pak and re-load it, pressing firmly to ensure it is locked in place. Slide the Power Switch on the Control Deck to the ON position. (Inserting the game with the Power ON will result in a blank screen.)
  4. Check under the Memory Expansion door (on the top of the Control Deck) to verify that the Jumper Pak or Expansion Pak is still inserted. If one is not inserted, slide the Power Switch to the OFF position, insert the Jumper Pak or Expansion Pak and slide the Power Switch to the ON position. Simply pressing reset will not solve the problem. You must turn the power off and then back on.
If this does not resolve the problem you are experiencing with your system, your system may need to be replaced. For more information on what options are available, please click here. It might be broken like it sounds like a power supply issue or and a laser assembly failure then.
Sep 03, 2011 | Nintendo 64 Console
What does an expansion pack for the n64 do? what is its purpose? and are they interchangeable?
I will refer you to a page on Wikipedia that explains it -- but the simple explanation is that the Nintendo 64 Expansion Pack increases the RAM on the N64 from 4MB to 8MB. There were a few games with improved graphics and game play that REQUIRED the expansion pack.
Yes you can remove the Expansion Pak from one N64 and put it into another. However, your N64 will NOT work without either the Expansion Pak or the Jumper Pak in that slot. The original memory card that came in there was called the Jumper Pak which was 4MB. The Expansion Pak was 8MB.
http://en.wikipedia.org/wiki/Nintendo_64_accessories#Expansion_Pak
Jun 16, 2011 | Nintendo 64 Console
Ok so when i turn on my N64 the power light comes on but the screen stays black (Blue for some tvs).I unplugged everything cleaned it with a Q-tip made sure there was no cuts in the wires.I then plugged...
Feb 08, 2011 | Nintendo 64 Console
Nintendo 64 will not turn on
Take everything out. Chords, games, and jumper/expansion pak.
Turn it on for 10 seconds.
Turn it off.
Blow into the game cartridge and the cartridge slot.
Plug everything back in except for power.
Turn on for 10 seconds.
Turn off.
Plug power in.
It should work now.
Jul 15, 2009 | Nintendo 64 Console
N64 red light turns on but no sound or video onscreen
Quick Tip: If your system is connected using AV cables and you cannot see the game on your screen, it is likely all you need to find is the input select on your TV or VCR. Link here for help.
  1. Make sure your system is hooked up correctly. This is the number one reason for a blank screen. To ensure all hookup connections are firm and correct, remove the AV cables and reinsert them with a slight twisting motion (this will help fully seat the connections). For more information about connecting the system, check the following hookup steps:
  2. Make sure you are using all licensed accessories with your system. Unlicensed products are not fully compatible with Nintendo systems and may not work correctly.
  3. Make sure the system has power. If you don't see the red power light when you turn your system on, go to the No Power Lightinstructions.
  4. Slide the Power Switch on the Control Deck to the OFF position. Remove the Game Pak and re-load it, pressing firmly to ensure it is locked in place. Slide the Power Switch on the Control Deck to the ON position. (Inserting the game with the Power ON will result in a blank screen.)
  5. Check under the Memory Expansion door (on the top of the Control Deck) to verify that the Jumper Pak or Expansion Pak is still inserted. If one is not inserted, slide the Power Switch to the OFF position, insert the Jumper Pak or Expansion Pak and slide the Power Switch to the ON position. Simply pressing reset will not solve the problem. You must turn the power off and then back on.
May 31, 2009 | Nintendo 64 Console
My Nintendo 64 won't work after inserting a RAM expansion.
Use an official expansion pack, for ensured quality.
Dec 25, 2008 | Nintendo 64 Console
N64 and expansion pak whoas!
If your husband plugged it in without turning it off, the jumper pak, or the control deck itself is more than likely fried. Check and see if the control deck will work with the memory pak, instead of the jumper pak inside it. If not, the control deck is fried, and you'll need to buy another N64.
Nov 05, 2008 | Nintendo 64 Console
N64 expansion pak
are you using a third party expansion pak? if not take it out of the system for a bit, is there anything inside the expansion bay?
Jun 18, 2008 | Nintendo 64 Console
Nintendo 64 expansion pak
Barb3: The Jumper Pack (JP) is a bypass for the expansion cartridge. You were supposed to turn off the equipment remove the JP and then use the expansion cartridge. Your N64 Ram it's probably gone for good. Is either replace the RAM, which is hard to find or replace the N64. Sorry for that.... SithPitt
Jul 03, 2007 | Nintendo 64 Console
Nintendo 64 Console Logo
356 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
