Question about Toyotomi TADT38J Air Conditioner
I have the toyotomi TAD-T38J portable air conditioner. It shuts off after 2 minutes after I turn it on with the remote. I have turned the timer off and it still does the same thing. I have tried turning it on with the emergency on/off switch on the front panel of the unit, and it still shuts off after 2 minutes. The screen light around the emergency on/off switch on the front flashes in blue when this happens. (Not the small led light). I have checked the water tank, and it is empty, and I have cleaned the air filter also. I spoke with the service guy from toyotomi, and he said to turn the unit on with the remote, then turn it off, unplug the unit, take the batteries out of the remote and leave them out so the remote does not work, and turn it back on using the on/off switch on the front. This still does not work. Can someone please help me??
  • marlena2023 Oct 08, 2010
    Yes, they said I would have to ship it to Conneticut.....I'm in Texas and that it would be about 6 weeks before I get it back. It ran out of warranty a few months ago. Do you think an appliance repair shop could help with this? I've called a few places in town and they don't even know what I'm talking about when it comes to portable ac's......only window units.
    I bought it with a debit card......so I'm sol for the extended warranty. My zip code is 78414. i really appreciate all of your help!! Thank you!
    President:
  • 2,777 Answers
That means you have some fairly major hardware failure inside the machine. The control board is my suspicion for sure, it definitely sounds like that is having electrical failure.. Have you called back the Toyotomi service person / people after you confirmed that their suggestion made no difference? This unit is definitely going to need in person service.
Thanks
Tim
Posted on Oct 08, 2010
  • Tim Grayson
    Tim Grayson Oct 08, 2010
    Hmm I can check, but your best bet is honestly to have it sent away. These units are very specialized and more delicate internally than what the people in your area probably know about. What is your zip code and I can check? Agh that's too bad it just ran out of warranty :(, I hate it when that happens. If you happened to purchase the unit with a major credit card (not
    a debit card) there is a good chance it may still be under the free
    extended warranty most credit cards place on electronics. Please
    contact your credit card company to inquire if they do this, and they
    will be able to file the claim and get you a refund for the machine. Just something to keep in mind.
    Thanks
    TIm
  • Tim Grayson
    Agh, you were correct originally, only AC Delco and other major brand new places anywhere near you for hundreds of miles :(. I'm so sorry about that.
    Tim
How do I drain water from a toyotomi portable ac unit
1. put it on higher position near water drainage, window...etc
2. make hole in water tank
3. put tube in hole and lead tube in drainage or outside (hole in frame of window recommended for long term use). Fix tube with glue
4. take care that water tank is higher than end of the tube
5. done
Jul 06, 2014 | Toyotomi TAD-T40LW 14000 BTU Portable Air...
Portable A/C unit will not stay cooling
Install pressure taps, read the pressure & you will find it is probably low on refrigerant. Find & fix leak...charge as needed.
Nov 27, 2013 | Toyotomi TAD-30F Portable Air Conditioner
Panasonic air conditioner with seral nr. A75C2616
Have you checked your remote
control if you have accidentally set the
timer off to turn off one hour after
turning it on? Seems like the problem because the
timer LED is lighting up means that the
unit has shut off via the timer. Verify the remote if there is a timer
setting on it. If you would not
recognize it, try to remove the battery
for about 5 minutes, return the
battery, then just press the on and off
switch and put it in cooling mode and observe if it did correct the problem.
Jul 15, 2013 | Heating & Cooling
My Toyotomi TAD-30F 'tank full' light keeps coming on despite my emptying the tank daily.
Check and see if the light is activated by a float switch. If it is it may be sticking. Your owners manual may have a clue.
Jul 11, 2012 | Toyotomi TAD-30F Portable Air Conditioner
I need to replace the fan on my TAD-30F. Where
http://www.toyotomiusa.com/products/AccessoriesTAD.mv
hope this helps
Jul 22, 2009 | Toyotomi TAD-30F Portable Air Conditioner
DPAC 13009 portable air conditioning problem
Remove your remote control on the unit, follow the manual step by step. First, do the emergency on/off button, then operate the air conditioning using the remote control, follow the procedure of your manual.You may notice a clicking sound of your remote control. The yellow/green color of your emegency on/off button will turn to blue. Do not put it back your remote control on the unit because he may sense the temperature of the vent, and your air conditioning will not stay on, it will shut off every five minutes. Your problem is solve.
Regards,
Cesar
May 24, 2009 | Danby DPAC12031 Air Conditioner
Smells like gas
anytime you smell gas turn off the gas at source quickly.
Dec 22, 2008 | Toyotomi TID-1800HP Air Conditioner
Light on plug doesn't come on
try opening it up to see if there's a fuse inside.
Aug 18, 2007 | Toyotomi TAD-30F Portable Air Conditioner
Toyotomi TADT38J Air Conditioner Logo
135 people viewed this question
Top Toyotomi Heating & Cooling Experts
hmca
Level 1 Expert
Andrew Taylor
Andrew Taylor
Tom Chichester
Are you a Toyotomi Heating and Cooling Expert? Answer questions, earn points and help others
