Question about Janome Memory Craft 9000 Computerized Sewing Machine
I can't program a pattern and save it in memory. The screen starts with 69-116 of the decorative stiches, will not change to 29-68 I have realigned but that did'nt help
  • smith6616 Oct 09, 2010
    I have A New Home - JANOME MEMORY CRAFT 8000
  • smith6616 Oct 11, 2010
    I appreciate you help, I must have typed 9000 instead of 8000, To my knowledge there is no 9000 model. I hope you can tell me how to fix it. If it is the A Board, where can I get one?
    President:
  • 2,777 Answers
Please verify what make and model of sewer we are working with here?
Thanks
Tim
Posted on Oct 08, 2010
  • Tim Grayson
    Tim Grayson Oct 09, 2010
    I see, still checking it now.
    Tim
  • Tim Grayson
    Tim Grayson Oct 11, 2010
    Checking this out now, looks like you will need to contact Janome to get the part if it is available. Call them at 1-800-631-0183, I believe you want extension 774.
    Thanks
    Tim
Practising different stiches on my juki and I think ive programmed them in. so now when I choose a stich it does a couple then jumps to the next one and the next one and so on. how do I unprogramme
Sounds like you didn't effectively close/save one program before beginning a new program so the machine is running them all together in the series in which they were programmed.
Sep 30, 2017 | Juki Sewing Machines
The LCD Touch-Screen not working
Hi-
Chances are you need to reset the settings. check the guides as well for the correct setup.
Hope this helps
Sep 22, 2008 | Singer Quantum XL-1000 Computerized Sewing...
I have Janine 10000. And am buying a new computer. How do I transfer to new compy
Install the program on the new computer. Save the data, patterns and stuff you have saved onto a USB memory stick and not where the program saved it on the old computer. Drop the files into the same location on the new computer.
Jan 06, 2017 | Sewing Machines
I have a Singer S18, stitches perfect. Attempted to use Zig Zag stich and decorative stitches, These are not working, It will make a few stitches then keeps stitching in place. Any Suggestions? Thanks
You probably need to widen the stitch width before it will let you sew. Or change the pressed foot to accommodate the movement of the needle when making decorative stitches.
Nov 20, 2016 | Singer Sewing Machines
I have a Bernina 1230, that was a gift from my mother-in-law. I need help creating continuous decorative stitches and I don't understand the user guide directions.
What a Great Gift!!!
The manual is a bit confusing. From what I can gather, it looks like to program, press MEM, select the first stitch, press MEM, select the next stitch...end programming with MEM.
Press "pattern begin" to start and then "pattern end" to end.
If you are interested in joining a Bernina group who discusses all kinds of questions and tips about using older Bernina machines, look for a Yahoo Group called "BerninaThirtySomethings" The members are very helpful and some are Bernina technicians who know a lot about the machines.
Actually, you can also download the 1260 manual. It is very similar to your 1230 but may be easier to understand. Look at the memory instructions there (page 26...). It appears in order to perform multiples of a particular stitch, after selecting that stitch, press the MEM button that many times.
Mar 16, 2016 | Sewing Machines
I have forgotten how to work my Decorative stitches on my Bernina 930
select the 1-20? stich pattern on top of the unit, then select the pattern you want, select widest stich and turn the length adjuster to the length that best suits that stich, (it could be from almost zero to full length depending on the pattern)
Feb 07, 2013 | Sewing Machines
The bobbin thread is bunching on the under side of the fabric,. Decorative designs are close together, not like the pattern and when I use the more intricate decorative designs, they just sit in a quarter...
Make sure that you use the F foot when using decorative stitches.
The stitch balance my be off. Remove the accessory bin and you will see a large plastic screw with a + and a - and an arrow. Using a coin, turn the arrow to the center and test. Turn the arrow towards the + to stretch the pattern out.
If this doesn't work, it must me calibrated internally and requires an experience hand.
Jul 07, 2009 | Janome Memory Craft 9000 Computerized...
Yamata FY7568 only stiches ----------
Have you changed your needle? If you have a dull or bent needle it can cause the machine to not lock the stitches together and the result is a straight stitch on every pattern. Also, check your stitch width selector and make sure that it did not get accidently moved.
Feb 11, 2009 | Brother Sewing Machines
I have a quantum cxl. It will sew normal stiches but it will not sew the decorative stiches
The needle shaft sticks to the curved arm and won't come down because a piece of plastic, about an eighth of an inch thick had broken from age. It prevented the shaft from staying up on the needle arm. Open the cover, try to stitch decorative stitch and see what I mean. Purchase a package of 4-10 by 1/2 nut and bolt pack. Screw the nut all the way onto the bolt. Using needle-nosed plyers, Carefully bend the curved arm slightly, and place bolt into the hole on the top of the needle shaft. Nut will keep it in place. Lowering the needle shaft using wheel, carefully bend arm back in place. Try decorative stitch. It should work. It does for me.
Aug 03, 2008 | Singer Quantum XL-1000 Computerized Sewing...
Sewing machine
Suggest that it be serviced by an authorized Husqvarna Viking Dealer. You can find the nearest dealer by click on the "Dealer" link at http://www.husqvarnaviking.com
Good luck.
Jul 13, 2008 | Husqvarna Viking 1
Janome Memory Craft 9000 Computerized Sewing Machine Logo
24 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
