Question about Power Acoustik Car Audio & Video
I have a power acoustik ptid4007 that fell out of the recessed holder I have tried to reinstall it with no success. It does't appear to have any broken parts .When I bought mt 1999 toyota p.u. it was installed and worked fine.I would like to find out how to reinstall it. Thanks arthur ensign
    President:
  • 2,777 Answers
It should just pop into that holder, it's possible it is worn out. It's pretty tough to say how to do it without looking at it... Any way you could take a few pictures of the setup and send them this way? Just post them on the comment here to start with... using the PICTURES button at the bottom of the text box.
Thanks
Tim
Posted on Oct 08, 2010
The fuse and fuse holder fell out of my behringer euro power pmp2000 amp where can i get a new fuse holder
try googling the brand name to find the manufacturer, they'll have the fuse and holder. you can also try going to an electronics supply house, they'll be able to help you also.
Oct 08, 2010 | Audio Players & Recorders
I need a manual for a power acoustik ptid4007
i looked the manule for that is not posted on their home site sory but u may have to do without
Jul 08, 2010 | Power Acoustik PTID-4007 Car DVD Player
I HAVE A POWER ACOUSTIK PTID-8970NRBT MY PROBLEM MY SCREENSAVER
Here is what I received from Power Acoustik for screensaver and desktop saving from SD card. "You need to have the remote in hand. Insert a memory stick or SD card that has the images you want to use. When the image is displayed, press the pause button on the remote. Then touch the screen to bring up a set of icons on the bottom. If you do not see an icon with a hand, press the arrows that are in a circle until you do. Once you see the hand, press it one time. It will save the image onto the internal memory. You will find the image in the screen tab in settings, under all the stock images."
Mar 17, 2010 | Power Acoustik PADVD340TV In-Dash...
Power acoustik gothic OV2 800 manual
Could not get a manual for you but did get the follwing specs. Hope they help.
Power Acoustik Ov2-800 2-Channel Class A/B Gothic Series Amplifier (800-Watt)
POWER ACOUSTIK OV2-800 2-CHANNEL CLASS A/B GOTHIC SERIES AMPLIFIER
800-WATT 2-CHANNEL
4 ohm RMS: 150W X 2
2 ohm RMS: 180W X 2
Bridged mode MONO RMS: 360W
BRIDGED MAX: 800W
FULL MOSFET POWER SUPPLY
PWM CIRCUITRY
FULL SELECTABLE CROSSOVER
3-WAY PROTECTION CIRCUIT
TRI-MODE CAPABLE
VARIABLE LOW PASS 40 HZ - 120 HZ
VARIABLE HIGH PASS 150 HZ - 1.5 KHZ
VARIABLE 18 DB BASS BOOST @ 40 HZ
FREQ RESP: 10 HZ TO 30 KHZ
S/N RATIO: 98 DB
THD: 0.02%
2 ohm STABLE STEREO
SYSTEM DISTRESS INDICATOR
HIGH/LOW LEVEL INPUTS WITH FLOATING GROUND
4-GAUGE POWER/GROUND CONNECTION
PLATINUM RCA CONNECTORS
LINE OUTPUT WITH FLOATING GROUND
BLUE LED
CHROME TOP PLATE PANEL 2-CHANNEL CLASS A/B GOTHIC SERIES AMPLIFIER (800-WATT)
Aug 18, 2009 | Power Acoustik GOTHIC OV2-800 Car Audio...
Buick Regal cup holder problem
Yes absolutely you can my friend. and you are correct this will fit 1997 to 2004 actually!
Jul 10, 2009 | 1996 Buick Regal Olympic Gold
Boss C650 1000W amp melted fuses
CALL BOSE THEM SELF..OR A BOSE REPAIR SHOP THEY WILL GET THEM FOR YOU.......
THEN TAKE THE AMP APART DESOLDER THE HOLDERS AND REPLACE THEM YOU CAN GET A REAL CHEAP SOLDERING IRON AND SOLDER @ RADIO SHACK CALL A REPAIR PLACE.....FIX IT YOUR SELF SAVE YOUR SELF A LOT OF MONEY AS LONG YOU DID NOT BURN UP COMPONENTS TAKE A LOOK INSIDE FIRST BEFORE YOU BUY ANYTHING GOOD LUCK
Feb 04, 2009 | Power Acoustik LT-980/2 Car Audio...
Equalizer
Hi Sir
I Think You Should First Reinstall Your Car System And then you can try it again
if you are not successful in doing this then you should replace your car battery or check your battery terminals
thanks i hope it will help you
Jul 09, 2008 | Power Acoustik Car Audio & Video
WIRING
You need to order extra components in order to use the optional GPS function.. you can try checking circuit city or the Authorized Acoustik Suppliers for the products like the websites or you can check Ebay as someone might have the product
Nov 18, 2007 | Power Acoustik LT-980/2 Car Audio...
Power Acoustik
the amp shouldnt even lite up w/o the ground attached.
Jan 25, 2007 | Power Acoustik GOTHIC OV2-520 Car Audio...
Car Audio & Video Logo
46 people viewed this question
Top Power Acoustik Car Audio & Video Experts
Tygh Duval
Tygh Duval
Jose Velazquez
Jose Velazquez
Are you a Power Acoustik Car Audio and Video Expert? Answer questions, earn points and help others
