Question about i-mate JasJam Smartphone
My jasjam's front key pad circuit is not working...i want to buy it...how can i do it?
  • 25 Answers
You could go to the shop and ask
Posted on Oct 08, 2010
My I-mate jasam fall down on the ground then I lost ringtone & sound on my i-mate jasjam. Phone still working ok. how can I fix that?
It is for sure that the RINGER has failed on the phone. Unless the phone is opened up this cannot be confirmed as it can be due to a circuit break/crack or the ringer failure. Sometimes a touch up soldering can help to solve this but attempt only if you are equipped.
Jul 23, 2011 | i-mate JasJam Smartphone
I-mate jasjam
i want make software to my i mate jasjam
May 11, 2009 | i-mate JasJam Smartphone
When switch on the jasjam mobile there is ablank screen , no display is comming up
You have obviously tried soft reset but have you tried hard reset?
Before you do hard reset you have to do a back up and remove the memory card. You will lose all the data on your Jasjam and the device is reverted to factory settings.
Hard reset is only useful for software related issues.
To do a hard reset
Push 2 SOFT keys and reset at the same time.
soft keys are the keys just under the screen
upper button of answer and end keys
and press reset hole
Apr 30, 2009 | i-mate JasJam Smartphone
Hai, can i upgrade windows 6.1 my imate jasjam mible it will work
yes it works it takes a lot of memory of the mobile but still it works ok.
Mar 09, 2009 | i-mate JasJam Smartphone
Hard reset for jasjam
Here is the procedure;
Hard reset: Press and hold the Left SOFT KEY and Right SOFT KEY, and at the same time, use the stylus to press the RESET button at the bottom of your device. You will be presented with a menu saying 'press R to reset, X to exit', if you press R Your device will be set back to factory default settings.
(The L/R soft keys are the "- -" keys just above the start and OK buttons)
Dec 15, 2008 | Apple iPhone 3G
Night Light
Your Control Key Pad is a circuit with each function and button a switch. The pad on your TV Remote, and Telephone is no different. The Key Pad is failing, It will only get worse. Determine if you can replace the Touch (Key) Pad. Not the Control Circuit, just the Touch Pad. Sometimes you can get it seperate. It connects by a Flex Cable to the Control Circuit.
Jan 28, 2008 | Frigidaire PLMV169DC Microwave Oven
Key Pad only works on some numbers. Others do not respond when pushed
Unplug the unit. Generally, remove the screws inside the door that hold on the faceplate. Inside, it will become rather obvious how to detach the keypad from the main circuit board. Note that some of the screws are longer than others. Carefully unplug the wire loom from the board. Note that these plugs have a small movable section. Flush to the board is lock...up is unlocked. Make sure when you push the loom in that the section is up...then push it down. By the way...before you buy a new part, unplug each connection related to the key panel and reinstall. It may just fix it.
Dec 19, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
NEED TO PRESS REALLY HARD TO INCREASE VOLUME. EVERYTHING ELSE WORKS FINE
as time goes buy more of the keys will fail to work, pressing hard on the keys may do some damage to the circuit board inside. you need to remove the batteries any and small screws you can see then pry the two haves apart remove any screws that hold the circuit board to the top half and remove the circuit board to expose the bottom of the key pad you will see a black conductor painted on the bottom of each key button, use a Q-tip dipped in alcohol to clean the black conductor on all the keys then do the same thing to the contact points on the circuit board then rub a pencil eraser over the same contact points on the cicuit board and reclean with alcohol again.
This should fix the problem but it will happen again, and at some point even this won't fix the problem and logitech won't let you buy a new key pad, and that is the point I am at now and for that reason I won't buy another remote from them, I expect more than four years out of this product good luck.
Nov 12, 2007 | Logitech Harmony 890 LCD Remote Control
Samsung- SGH-D820 key problem
Contact problem more common with any phone. Simply problem, somtimes you have to take a part the phone clean it, dry it to fix that.
You can buy a special cleanig solution for wather dammage from ebay if you realy want to fix this alone.
But if you hawe waranty, use ti!!!
Nov 11, 2007 | Samsung SGH-D820 Cellular Phone
I-mate jasjam frozen
Hi rossei. this is jamie. I have had this problem for long time but now I tried some else which really worked for me, I hope this works for you too. Well to make it short, disconnect your i-mate jasjam's battry and take your sim card out from your i-mate jasjam and leave it for about 10 to 20 minutes then reconnect every thing back together. There you are, thats fixed now. Its not really 100% solution for this however it works on mine but I do this procedure all the time to get it working, Good luck
Sep 24, 2007 | Apple iPhone 3G
i-mate JasJam Smartphone Logo
24 people viewed this question
Top i-mate Cell Phones Experts
Computer Repairing
Computer Repairing
castletech
castletech
Are you an i-mate Cell Phone Expert? Answer questions, earn points and help others
