Question about Kenmore 16919 Built-in Dishwasher
Getting White residue on dishes and glasses and all things. The heating element also becomes coated with this substance. The water input is clear and has no problems. What should i be looking for to solve this issue?
    Brigadier General:
  • 3,513 Answers
Residue on your dishes can be caused by inadequate drainage of the machine. Most new machines are pumping the gray water through 6+ feet of hose to an air gap,(that chrome thing next to your faucet) and then on in to a disposal or right into the sink drain plumbing. The problem is occurring when the pump finishes and then all of the gray water remaining in the 6 feet of hose flows back into the machine!!! So in a nut shell you are never getting all of the dirty water with its associated food particles(which tend to collect in the bottom of the machine due to this feature of gravity ) The ONLY way to fix this problem and get your dish machine to drain everything all of the time is to re-route the drain connection to a point lower than the pump in the bottom of the machine.
Also the problem can be caused for hard water and there is a new product out called the dishwasher filtration system. it actually filters the water going into your dishwasher and leaves your dishes spot free. after the first load i was amazed that the white film was gone and my dishes were sparkling. you can get it at www.dishwasherfilter.com
Also its possible you have a low water fill problem or maybe a water temperature problem. The water should be at least 120 to 130 degrees Fahrenheit to start with. Gel soaps can cause a lot of problems with scum and leaving a white residue, mostly when there is not enough water in the dishwasher. After it fills there should be water almost up to the heating element.
Please accept the solution if it's helpful. Do get back to us for any further query.
Thanks for contacting fixya.com
Posted on Oct 08, 2010
GE Dishwasher Model GSD580K-20 Dishes,glasses, silverware coated with chalky white substance on surface. Cannot remove by rinsing only
Hi, I have an older dishwasher also and recently mywife also complained about it not cleaning right... so me being the man I amtried in vain to clean the things... Bought new spray arms online and installedthem in minutes...now the thing works like new... However I have also foundthat if the heating element goes bad then that also can mess things up bad...So I would buy new spray arms, and also check out the heating element to makesure it is working... Here is a tip that will help you with the onlinebuying...
Dishwasher SprayArms not Spinning
How to Buy ApplianceParts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The HeatingElement not Working
DishwasherMaintenance DishwasherResidue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
Aug 01, 2011 | GE Dishwashers
Dishes not getting clean... AND white powder residue. Tried all of the clean rinse additives, vinegar rinse, and CLR rinse... then I noticed that the white coating on the heating element is wearing off...
heatman101
Apr 30, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
My dishes are not getting clean. There is dirt and residue on glasses and other dishes. I have checked and nothing seems to be clogged, but I'm not sure I checked everything. The inside edges have a build...
heatman101
Apr 27, 2011 | KitchenAid 24 in. KUDM01TJ - Multiple...
Food is being left on dishes, not cleaning well. Residue on glasses and pans(white) You can feel a grainy residue on cups and bowls
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher
Spray Arms not Spinning
How to Buy
Appliance Parts Online
Heating Element not Working
Dishwasher Maintenance
Dishwasher Residue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Feb 23, 2011 | KitchenAid Dishwashers
Using Cascade for 30 years. Starting Thanksgiving day all my dishes came out coated with a hard white scratchy coating and silverware was also coated and all things were very dull. Since then dishes have...
Dishwasher
How to Buy
heatman101
Jan 06, 2011 | Amana Dishwashers
I have washed and rewashed my dishes with no soap and my glasses have a horrible white film and any of my plastics now have white film almost as if the soap is not rinsing off. I have resorted to hand...
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
heatman101
l'l
Sep 25, 2010 | Kenmore 24 in. 17482 / 17484 / 17489...
The dishwasher is not cleaning. It has left a residue all over the dishes especially colored plastic ware glasses. like it doesn't rinse but i have ran the extra rinse cycle and residue is still there. ...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
Check your heating element..
A bad heating element causes many problems in dishwashers…
Dishwasher Problems The Heating Element not Working
heatman101
Asker's Testimonial " explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Sep 08, 2010 | GE Tritonr XL GSD6260JCC Dishwasher
Dishes are coated in a chalky substance.
heatman101
Sep 07, 2010 | Miele G892SC SS Dishwasher
My Maytag Quiet Series 100 is leaving a white residue on dishes and glasses. The problem seems to be getting worse. I have used multiple dishwasher cleaning solutions, with no resolution to the problem. ...
<span style="FONT-FAMILY: 'Trebuchet MS'; FONT-SIZE: 10pt; mso-ansi-language: EN" lang="EN">Hi,<br />Check your heating element.. </span><br /> <span style="FONT-FAMILY: 'Trebuchet MS'; FONT-SIZE: 10pt; mso-ansi-language: EN" lang="EN">A bad heating element causes many problems in dishwashers&hellip;<br /><br />Dishwasher Problems The Heating Element not Working<br /><a href="http://www.fixya.com/support/r4589033-dishwasher_problems_heating_element_not" target="_blank">http://www.fixya.com/support/r4589033-dishwasher_problems_heating_element_not</a><br /><br />Dishwasher Maintenance<br /><a href="http://www.fixya.com/support/r4319937-dishwasher_maintenance" target="_blank">http://www.fixya.com/support/r4319937-dishwasher_maintenance</a><br /><br />heatman101 <br /><br />Asker's Testimonial " expanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes <br /><br style="mso-special-character: line-break" clear="all" /></span><br />
Aug 26, 2010 | Maytag 24 in. MDB5651A Built-in Dishwasher
Frigidaire built in dishwasher model PLD2855RFC1. Have to wash dishes pretty much spotless prior to using dishwaser. Glasses come out with what appears to be soap residue regardless if powder or liquid....
Dishwasher
How to Buy
heatman101
May 31, 2010 | Frigidaire PLD2855RFC Dishwasher
Open Questions:
See all Kenmore 16919 Built-in Dishwasher Questions
Kenmore 16919 Built-in Dishwasher Logo
71 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
