Question about LG Televison & Video
Turns on and off by itself getting more n more regular
  • 732 Answers
Jackieh25, You or electronics technician will need to explore fixing the units internal power supply. Problem not new one!! Lots of video clips at YOUTUBE that you should see!! Start with "LCD monitor disassembly" and "LCD monitor repair" then move up to "lcd tv repair" Just so you KNOW what you are letting yourself into. Same symptom affects both and cause may also be same!
12fixlouie
Posted on Oct 08, 2010
Why does my unit beep and turn on by itself with a 0.5 in the led
Sounds like it is made to react to humidity as well as temperature. Check to see if there is a setting for that, or perhaps it is supposed to come on to protect itself from moisture. Do you notice ice cold air coming out when it does that, or is it just regular ''air''. If just regular ''air'', and if it does also blow _cold_ when working at the temp you set it at, then I am probably right about humidity... which means this is normal.
May 19, 2015 | Frigidaire FAC105P1A Window Air...
In the middle of typing, my Smith Corona is now typing weird symbols. What did I do and how do I get it back to regular characters?
Remove the print wheel, look for broken or bent spokes. Turn it off and on it should reset itself.
DickyO
Oct 06, 2011 | Smith Corona Wordsmith 200 Typewriter
High beams only work on a toyota tacoma running lights work no fuse blown when i turn the inside switch from regular lights to high beam i hear the relay switch click
you should also hear a click when you go from off to regular low beam also. if not, the least expensive thing would be to replace the relay. w2hen that doesn't work, the switch itself is the most likely cause and needs to be replaced. the headlight switch gets a lot of use and the internal plastic parts just wear down over time.
May 14, 2011 | Toyota Tacoma Cars & Trucks
Turns off by itself
Try to change to a new battery. If it is still the same, that means your software has got problem or a chip has been spoiled. You will need to get it repaired.
May 03, 2010 | LG Shine KE970 Cellular Phone
I put on a regular load of laundry and the machine
Broken or clogged yes, as long as the timer and electronics are not an issue.
Apr 18, 2010 | Whirlpool LSR5132PQ Top Load Washer
I have a ford f150 1995 i just replace my feul pressure regular and my truck just died again check engine lite is on wont go off truck wont start please help!!!!!
first off cheak all of your fuses this to offen get over looked and will crank at all? second the light wont go off by itself you need a shop with a lotus tester or something of that nature to turn it off
Nov 19, 2009 | 1997 Ford F150 Regular Cab
Disney tv comes on and off by itself
if you can go to the website and check the support page to get a solution. you might want to check the menu if it has one and see if you have a sleep on it. you might have it set a few seconds. just like a regular tv.
Mar 30, 2009 | Disney Electronics Single Disc Boombox,...
TV TURNS OFF BY ITSELF
Sounds like the Startup Relay is dropping out, you will need to replace it.
Mar 28, 2009 | Sharp 32L-S400 32" TV
Daewoo DVR-06 turns itself off while playing back
I have the same machine. It was randomly turning itself off 3 or 4 times during a regular 2 hour movie. In the setup menu there is an option to reset all the settings to the default original factory settings. I did so, went through the entire setup process again and my machine has not turned itself off since. I liken it to "rebooting".
Stan Lauskey
Apr 29, 2007 | Daewoo DVR-06
Televison & Video Logo
81 people viewed this question
Computer Repairing
Computer Repairing
