Question about Remington Titanium MicroScreen MS3-2700 Electric Shaver
Te battery will not hold a charge. - Remington Titanium MicroScreen MS3-2700 Electric Shaver
  • Remington Master
  • 1,602 Answers
Batteries in your shaver model were not designed for replacement. Disassembling the shaver will result in damage to the case as it is glued together.
shaveroutlet.com has a simple and inexpensive solution of replacing the 'lower unit'. See link below
http://shaveroutlet.com/shaver-replacement-parts/remington-ms32700-lower-unit-p-210.html
Posted on Oct 08, 2010
I keep have to jump my suburban off i have changed alternator and starter still have to jump it off whats te problem
did you test the battery to make sure it can hold a charge. If the alternator goes sometimes it takes the battery with it ( orthe battery can cause the alternator to go)
Apr 02, 2014 | 1999 Chevrolet S-10 Pickup
I don't know how to remove old batteries to install new batteries in Shoprider Scootie TE-787NA power scooter. I can't lift them up after I remove batteries cover. I can't find it in manual.
Not familiar with that make and model, but we often find that batteries just plain get stuck due to gunk on the battery pan. If you do not see a strap or hold down or anything, try wiggling them to see if that frees them up.
Mar 29, 2014 | Shoprider Scootie TE-787NA - Power Scooter...
I have a dv6500 and it work only whit te battery. the ac adapter dont charg the battery and the pc dont work and the charger its ok. maybe a fuse?? tks rgds
If thelaptop battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Aug 19, 2011 | HP Pavilion dv6000z Notebook
Hi I Have a Hilti TE 6A Old type recently bought new charger and battery is taking a charge and seems to be holding the charge but when i use the drill it keeps stopping but when i pull the trigger in...
I do not have any experience with this particular drill but I have a old drill and belt sander of my dad's that stopped working and since I was going to throw them away I decided to take them a part and took the switches apart and cleaned the contacts and now they are working just fine. JR
Oct 12, 2010 | Hilti Drills
I have a Fujufilm Finepix S5700 digital camera. Does not power up
hold power button down and remove battery at the same time once battery is out put battery into charger, if the light shows red then it needs to be charged if it shows green allow it to stay in the charger for 3 minutes then remove the battery and install in the camera pust the power button on hold for 5 seconds, if the camera comes on your ready to go, if not then you may have damaged the battery pack and will have to replace te battery. If you have a cable that plugs into the camera try using the powrord with battery plugged in, if it does not work then your battery is bad and you will have to purchase from fuji to get the right battery pack.
Jun 13, 2010 | Fuji FinePix S5700 Digital Camera
My sony vgn-tx17p won't boot. Te power light turns on and nothing shows up on te screen. Please help
  1. turn off the computer
  2. disconnect the ac adapter and remove the battery
  3. reseat the RAM/memory.
  4. without the battery or ac adapter, press and hold down the power button for 7-10secs
  5. reconnect the battery and ac adapter
  6. try turning it on
Feb 26, 2010 | Sony VAIO PCG-TR3AP1 Notebook
How long should u charge battery first time and can u over charge
this depends on the battery size, you normally should be ok after 3 hours or so
batteries get to max chargig capacity after about 3 full charges (+ fully drained)
Normally you cannot overcharge, but you can make your battery lazy if you never let it drain and always charge it during work it will get lazy.
So Try to drain your battery frequently, and do not work with te charger connected all the time
Dec 27, 2009 | Acer Computers & Internet
I CHARGED THE BATTERY. AFTER HITTING TE RED BUTTON
the wistle is run by three aaa batteries under the smoke stack on the front not the batterie that is under the seat, make sure that you have reconnected the battery properly to the vehicle
Nov 09, 2009 | Peg Perego IGED1084 Santa Fe Train
Remington Titanium MicroScreen MS3-2700 Electric Shaver Logo
309 people viewed this question
Top Remington Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Jerry Greenberg
Jerry Greenberg
SHARCNET-USA
SHARCNET-USA
Are you a Remington Health and Beauty Expert? Answer questions, earn points and help others
