Question about Pantech PG-3600 Cellular Phone
Replacement Screen for Pantech C810
I have a pantech duo red (c810) phone and the screen has shorted out due to water damage. The phone still works, but it seems that teh screen is dead. I would like to find a place to get the screen replaced..... My zip code is 72034. Thanks..
  • iufaninark Jun 07, 2008
    Anyone with water damage should chck out "thecellspecialists". They clean up water damage for $50 and send your phone back to you. They also give you a 30 day a warranty on their work. My phone is on the way back after being in thei shop for less than two days.
    Brought to you by Golden Pager & Cellular Inc
    1515 E Fletcher Ave
    Suite D
    Tampa FL 33612
    Tel: (813) 866-5700
    Fax: (813) 866-3819
    cellrepair@tampabay.rr.com
    thecellspecialists@tampabay.rr.com
    President:
  • 1,871 Answers
Try this :
This works on most mini electronic devices like cellular phones and degital cameras etc .
it sounds crazy .
Remove the back (or Cover ) of the phone( or Camera ), battery, and SIM if your phone ( or Device ) uses one , DIRECTLY
Then, with a q-tip (or something similar), dab the connection points (shiny, goldish) on the battery, SIM, and phone. This should aid in drying.
Finally, place all contents in a bag of uncooked rice (separately, do not put back together just yet). it sounds crazy , but it draws the moisture out.
It normally is working after just 7-8 hours, but I would wait 12 hours or even 24 hours before attempting to use (just to be sure).
beware the water damage, despite being dry now, will void any warranties. Also, the phone's hardware is now weakened and if you drop it, the green mother board and circuitry could shatter - so be more careful.
This does work on electronic devices aside from phones as well. Simply tailor it to your device. If you do not have a SIM (Verizon phones, cameras, all others), remove only the battery. If you have an iPhone/iPod or GPS and cannot remove the battery, simply make sure it is all the way off, then put it in the rice bag. All electronic devices react the same to the rice trick.
related link is here : http://www.youtube.com/watch?v=0-Otjgd48nY
rate if useful please !
Posted on Jan 17, 2010
    Sergeant:
    Habit-Forming:
  • Pantech Expert
  • 109 Answers
If you want to replace the phone LCD screen, I believe this site can help me. My iphone 6 plus lcd screen broken, I was in this site to replace the good. Apple iPhone 6 Plus LCD Screen
Posted on Jan 12, 2017
  • 4 Answers
I had the exact same problem. My son dropped his in the water - phone worked but the screen did not. I took it apart, dried it out, and it now works fine. I would suggest trying this first (if you are comfortable taking your phone apart) and seeing if it works before purchasing a screen. Soldering will be required if you decide to replace the screen, which can be purchased from http://www.rmslogisticslp.com. If you are not comfortable replacing the screen yourself (if it comes to that then you will need to find a shop - possibly RMS Logistics - have to ask).
Here are the steps I took. You will need a very tiny philips screw driver and someplace uncluttered that you can place the parts in an orderly fashion.
1. Take out the battery and the SIM card.
2. There is a cover around the camera lense that just snaps off. Remove this.
3. You will find 6 tiny screws (2 under the camera lense cover) that you will need to remove from the back of the phone. The back then unsnaps.
4. Carefully lift and unplug the circuit board.
5. First slider, there are 4 silver screws that hold this in place. Remove the 4 silver screws.
6. There are 4 screws in the corners of the piece, two of them covered. Remove the cover then the 4 screws.
7. You will see a circuit board and mic. The mic has sticky on it to hold it to the case. Carefully pry the mic from the case, taking care not to break the wires. Now lift the circuit board and carefully unplug it. Again, you will probably find sticky on the plug also.
7. There are 4 black screws holding the next slider in place - remove these screws.
8. Now you should see the LCD. There are 4 screws, two of them covered with a long sticky piece - remove them.
9. Check for moisture on all your parts and use a tshirt or a soft cloth to blot dry. It would not hurt to let it sit a bit to make sure it is dry.
10. Reassembly is just reverse of these steps.
If the phone does not work, then you may need to replace the LCD (although that may or may not be the problem - hard to say). If you decide to replace the LCD then you will have to follow steps 1 - 9 and when you get to the LCD, unsolder the speaker from the old LCD and solder it to the new LCD. Reassemble.
I hope this works for you.
Posted on Jul 28, 2009
  • Rory Derrick
    Rory Derrick Jul 28, 2009
    I had the exact same problem - my sons fell out of his shirt pocket into the water. However, I was able to take it apart and dry it out - it works fine. Here are some steps that I am just passing on that helped me out. If you are not comfortable taking the phone apart yourself then you may be able to find a store that services the phones for your provider. Also RMS Logistics sells parts and may be able to do the service. You'd have to ask.
    The URL ishttp://www.rmslogisticslp.com.
    This not a job for just anyone it will require some soldering on the circuit board. If you don't know how then it would be best to ship it off.
    The steps to take apart the phone.
    1. take the battery and Sim card out.
    2. remove the molding place that surrounds the camera lens. It just snaps in. At first it did not look like it come off but is does.
    3. remove 6 (six) tiny screws from the back of the phone.
    4. lift the circuit board and carefully unplug the board in the next section. place the circuit board to the side.
    5. Remove 4 silver screws, hold this piece to one of the sliders. - set this piece to the side.
    6. remove 4 screws for the corners of this piece. two of the screws have covers over them
    7. Ok this was a pain both getting it out and back in. you should see a circuit board and mic. The Mic is solder to the board and stuck to the piece below with stick-em. Carefully left the mic off do not break the wires - you just want it loose. Now lift the circuit board and carefully unplug the next circuit board. Set the circuit board and mic to the side
    7. Remove 4 black screws hold the next slider in place.
    8. Ok, you're down to the LCD piece. Again remove 4 screws in the corners. 2 of them have 1 long cover piece covering them.
    Here I just blotted all the pieces that were wet with a soft cloth (tshirt) and let it sit for a bit to dry out. I put it back together and it worked. If however yours does not work then you can go through steps 9 & 10.
    9. remove the LCD piece, unsolder the speaker.
    10. Solder the speaker just removed to the new LCD piece. and reverse the steps the reassemble.
    I hope this helps.
How do i unlock pantech c300?
If your phone purchased in USA on or after 26 January 2013, please contact your network/service provider and get their permission to unlock your phone with a help of third party online unlocking service provider.Using network unlock code is the best way to unlock your Cingular locked Pantech C300 mobile phone.If you need an unlock code visit Classicunlocking.com Here you can unlock your mobile phone within a day.
Apr 03, 2013 | Pantech C300 Cellular Phone
UNLOCK MY PANTECH CELL PHONE
You can unlock your Pantech cell phone using unlock code.But you need to mention the model ,Country and current network provider to get the unlock code. Visit Onlinegsmunlock.com and select your phone model and give the Country and current network name and get the unlock code.
Mar 28, 2013 | Pantech Cell Phones
A friend gave me a pantech c530 it needs to be unlock any help?
There can be many ways to Unlock your phone. As far as i know unlocking by codes is the simple and safe way. I will suggest the website Unlock-Zone.com which is doing good service and they were recommended highly in the cell phone forums.
I used them to unlock my cell phone. contacted them and within 30 mins i had my unlock code and my phone was unlocked.
Hope this helps.
Oct 04, 2011 | Pantech Slate Cell Phone
My pantech duo c810 will not discover my bluetooth Have done everything pantech and bluetooth manual says no luck Bluetooth H560
how do u trnasfer RINGTOONS. PICTURES FROM YOUR COMPUTER INTO YOUR PANTECH DUO C810?? I NEED HELP.
Jul 01, 2009 | Pantech C810 Pocket PC
Unlocking pantech duo C810.
If you want unlock code for your pantech duo C810, get it from Mobile-unloker.com. Here, they ask you to provide your country and the network provider to unlock your phone. I bought my unlock code from this website.
Mar 02, 2009 | Pantech Duo Smartphone
Pantech Duo C810 water damage
استفاده کن از برنج.موبایل باطری موبایل را در اورده وان را وسط برنج قرار بده
Oct 02, 2008 | Pantech PG-3600 Cellular Phone
How to unlock a pantech duo c810
I have the code to unlock the Pantech C810 Duo mobile phone. Bur I donot know how to use or enter the code in the phone . Please guide me how to us ethe code to unlock the phone
Jun 18, 2008 | Pantech PG-3600 Cellular Phone
Unlock pantech c3 rogers
can you help me unlock my pantech c3 cell phone. I dont have the master code.Pls. Thank you
May 28, 2008 | Pantech C3 Cellular Phone
Pantech PG-3600 Cellular Phone Logo
423 people viewed this question
Top Pantech Cell Phones Experts
Computer Repairing
Computer Repairing
Jax Planet
Jax Planet
Abdul Mannan
Abdul Mannan
Are you a Pantech Cell Phone Expert? Answer questions, earn points and help others
