Question about Husqvarna Designer I
Need bobbins - Husqvarna Designer I
  • 201 Answers
Bobbins are freely available in a variety of places. If you don't have a sewing specialty shop handy, there's always the internet. eBay is a good place to start. Also you could Google search for "bobbins (your brand and model of machine)" you should find some without any trouble. I live in Australia and have bought bobbins from the USA at very cheap prices and the postage costs were extremely small.
Posted on Oct 15, 2010
I have the 9500 Memory craft sewing on tricot and the bottom side looks beautiful...top side is horrible...
Generally, when sewing machine issues appear on the top of the fabric, it is an indication of a problem with the bobbin/bobbin thread. Issues on the bottom of the fabric are generally top-thread related. AVOID using old or bargain bin thread. Try changing bobbins. Is it the correct bobbin? Make sure the thread is wound smoothly on the bobbin and no threads protrude outside the bobbin edge. Check that the bobbin is installed turning the correct direction and the bobbin case is threaded correctly. Also, the bobbin tension may need to be adjusted (probably a last option before having it serviced). If adjusting the bobbin tension, be sure to mark the tension screw setting BEFORE changing anything and then adjust only in 1/8-1/4 turn increments. A slight possibility is that the bobbin case is old and needs to be replaced.
Oct 17, 2017 | Sewing Machines
Pfaff quilting machine bobbin stuck
Is there is a wad of thread that is holding the bobbin captive? If so, you'll need to use small scissors and tweezers to snip away and pull out the threads. Patience!
If the bobbin is actually stuck in the bobbin case, it could be because it is the incorrect bobbin for the machine or the bobbin was over-filled with thread. You may just need to use force to remove the bobbin. It may damage the bobbin and, possibly, the bobbin case. They are both replaceable. Or you can pick up an additional bobbin case and bobbin and try the new ones in your machine.
Mar 10, 2017 | PfaFF Sewing Machines
What bobbins to order? I need more!
Shop for sewing machine bobbins... on Google
Plastic Bobbins for Kenmore S...
$3.99
Sears Singer Transparent P...
$8.99
Google Trusted StoreOverstock.... Brother SA156 Top Load Bob...
$5.10
Walmart Sewing Machine Bobb...
$3.89
Sears Parts D... Janome Style J Plastic Bobbin...
$6.00
Sew Vac Direct Search Results
    Bobbin Style Information for Sewing Machines - The Thread ...
    www.thethreadexchange.com/.../merchant.mvc?...sewing-machine-bobbi...
    We have bobbin style information for over 1600 sewing machine makes and models. Please start by selecting a sewing machine make from this list.
    Sewing Bobbins : SewingMachinesPlus.com
Dec 08, 2015 | Sewing Machines
What to do to fix the bobbin thread from jamming up everytime
There are a couple of reasons that can cause this.
a. Raise the pressure foot. As you load the top thread give small tugs to check for snags. They must be stopped.
b. Once the top threading is done on top lower the pressure foot. Now, give a tug on the thread. Is the tension really hard or just average? You may need to lower the tension to stop the jamming of the bobbin thread.
c. Clean the bobbin area. Check the bobbin tension and adjust as you need to.
d. Put a drop of oil on the race. (Thing the bobbin case sits on)
e. As the bobbin hook (sharp thing) is rotating does the bobbin case move back and forth a lot. You may need to adjust the bar that is next to the bobbin case so it can't rotate. Usually you will need to move it forward.
SEE INSTRUCTIONS HOW TO ADJUST THE BOBBIN. TENSION OF UPPER AND LOWER THREAD MUST BE RIGHT.
Nov 28, 2015 | Sewing Machines
Cleaned out lint from bobbin area and bobbin thread is still bunching
Try these suggestions
1. Change the needle--use a needle that's for the fabric being sewed
2. Rethread the machine--top --make sure to use every thread guide
3. try a different bobbin--make sure bobbin is inserted correctly into the bobbin case
& make sure the bobbin is turned the correct way in the bobbin case
4. make sure the thread has not come off the thread take up lever
5. Clean under the needle plate & in the bobbin area for lint or threads
6. Check to make sure the bobbin is not warped or damaged
7. Make sure the bobbin case is correctly in the machine,, if it's a top loading bobbin you may need to have the bobbin case checked to see if it's damaged or see if the hook and hook race has a problem
8. Also could be a timing problem, and the machine would need to be checked.
Jan 29, 2014 | Janome Sewing Machines
Singer curvy
Three possible causes: 1.Bobbin not push fully down the bobbin winder spindle
2.Need to push bobbin winder spindle to the left before you can wind the bobbin
3.The bobbin winder spindle rubber ring has worn out. This will need a local technician to fix it.
Aug 16, 2013 | Sewing Machines
Bobbin bunching on elna 3230
try changing the needle
rethread the machine top and bobbin
make sure the bobbin is inserted correctly into the bobbin case
and that the bobbin case is inserted correctly in the machine
it's also possible that the bobbin case needs to be replaced
also check the bobbin it could be warped
it's also possible that the timing needs to be checked on the
machine
Nov 22, 2012 | Sewing Machines
My elna sewing machine bobbin won't spin on top to wind thread around. The fly wheel spins though...I've been putting thread on the bobbins by hand.
If the fly wheel is going around then the clutch isn't disengaged to wind the bobbin, you need to pull out the flywheel on your model to disengage the clutch for bobbin winding.
Take thread from thread spool across to bobbin winder thread guide, then back to bobbin and thread the tail through the hole on top of the bobbin. Place bobbin onto spindle on top of machine and then push it against the stop to engage the bobbin winding motor. HOld the thread tail up and start winding slowly until the bobbin core has been covered including the starting point. Stop and trim off the thread tail with scissors. COntinue winding bobbin and give the thread a nudge if needed to wind evening top middle and bottom of the bobbin. A good smooth wind is important. Also don't wind at full speed and keep an eye on the thread reel that the thread is coming off, you don't want it bouncing around as this will **** the thread and stretch then relax it affecting your bobbin wind.
Obviously if you know this and the bobbin winding mechanisim is just not working, then it will need a service/replacement by an Elna repair person.
Aug 01, 2011 | Elna 2007 Mechanical Sewing Machine
The upper thread is too loose and the bobbin thread is taken up too much
It is the upper thread which pulls the bobbin thread up. If the bobbin thread is taken up to much, one solution is to loosen the upper thread -- but the upper thread is too loose. Therefore, the same problem needs to be combated from the bobbin side.
The thread from the bobbin should slide through a wedge. On that wedge should be a screw. It needs tightened. The bobbin thread should be tight as follows:
A fully loaded bobbin should tangle by the thread without falling. While dangling the bobbin by the thread, bounce the bobbin (yo-yo style). An easy tug should cause the bobbin to release an inch or two of thread and then the bobbin should stop falling on its own.
Once the bobbin tensioner is correct, you should be able to tighten the upper tensioner.
Jun 02, 2011 | Singer 5050 Mechanical Sewing Machine
I need instructions threading the bobbin on Kenmore sewing machi
I believe it is a seperate bobbin case, hold the open part of the bobbin case towards you with the finger at the top, hold the bobbin case by the latch, drop the bobbin in so it turns anti clockwise and pull the thread through the slot about 6 inches, keep hold of the latch, and pop the bobbin case in
Mar 22, 2010 | Sewing Machines
Sewing Machines Logo
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Wayne Fellows
Wayne Fellows
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
