Question about Universal Remote Control Safe-T-Talk Universal Hands Free System Headset
Hello, My actual car has installed an Universal Hands Free System model PHC-100. It has a RJ-45 connector an I would like How I must connect my mobile phone to use it. Someone has the conexions diagram to try it. Thank you.
  • jagarcia233 Oct 08, 2010
    Someone has the conexions diagram to try it???
Your company has just moved to a new office building. The server has a fiber optic network adapter, but the building does not have fiber optic cables installed. How do you install a media converter?
100BaeFX to 100BaseTx media converter. ST to SC cable.
SCA connector goes to the RX port in media converter.
STA connector goes to the TX jack on network adapter.
SC male B to TX port on media converter.
ST male B connector to the RX jack on network adapter.
Connect media converter to network with Cat5e cable which uses RJ-45 connectors.
Jan 25, 2012 | Allied Telesyn Allied Telesis AT MC1004 -...
Processor: Intel Pentium D - 3.4GHz processor (Dual-Core) Memory: 2048MB RAM Hard Drive: 400GB Optical Drive: CDRW/DVD Rom drive (combo) Operating System: Microsoft Windows XP Professional SP3...
You have to have some sort of a modem to get online whether your using a smartphone through a usb or broadband modem through your rj-45 jack, Broadband modems also have the capability of using a usb cable to connect to the modem. Hope this helps. Not sure exactly what your asking. If I havent answered your question feel free to let me know!!!
Jun 13, 2011 | Dell OPTIPLEX 745 PC Desktop
I want to connect a CAT5e Ethernet cable (with or without a RJ45 connector) from a DSL router to an older computer that only has a RJ11 input. This will be used for DSL internet service only -- no...
The only "outputs" from a DSL-router are:
* RJ-11 telephone-jack, only if the router also supports voice-over-IP,
* RJ-45 Ethernet port (always present)
You need to purchase an internal network-card, to create an RJ-45 port on the computer, and then use the CAT-5e cable to make the connection.
Feb 20, 2011 | Computers & Internet
How di I terminate the QVS Cat6 RJ 45 plugs?
terminating a RJ 45 plug means to put a RJ 45 plug on the end of a suitable cable. This is done by making up a si\uitable cable and skinning the tips of the cable and inserting them in the right order to the plug and then using a special RJ 45 crimper mashing a plastic plug down on the wires. You can purchase such an arrangement from an electronics supplier.
Jan 06, 2011 | QVS 100pcs CAT6 RJ45 50u Crimp Connectors...
I have the tew-652brp. What is the RJ-45 cable is that the one that came with the kit.
RJ-45 actually refers to the "telephone" type connector on the end of the cord, but it's just the Ethernet Cable that comes with the kit (better than the USB) Hope it helped.
Nov 04, 2010 | Computers & Internet
T636400000 does it have an ethernet card built in the unit?
You are probably looking at a RJ-11, used for telephone (dial up - modem). You are trying to put a RJ-45 connector in it.
The RJ-45 should have 8 wires while the RJ-11 may have as many as 6 connectors.
Thank you for your voluntary work with this organization.
Note: If you were to plug a RJ-11 into a RJ-45 port and if it happened that you plugged the other end of the phone cord (RJ-11) into a phone jack --- and the phone were to ring ... you would be pumping 60 volts into your computer. Be very careful with these connections. You would then need butter and jelly for your toast, which is what your computer would be.
Ok - recap: Both look very similar ...
Ethernet = 8 conductors - RJ-45
Telephone = up to 6 wires (may be 2 or 4 also) - RJ-11. NOT interchangable.
So how will you connect? If the laptop is not builltin wireless, you can get a PCMIA card for the slot on the side that will allow wireless or ethernet. Get the card at your computer store. ... Or ... use the built in modem for dialup., You would of course need a dialup account somewhere.
Thanks for your question at FixYa.com
Please vote.
Feb 17, 2010 | NEC Versa VXi PC Notebook
I have a Lifestyle 35 and want to replace head unit with a 5.1 receiver. The Bose subwoofer model LSPS uses a network type cable connector on the sub side and a male din plug on the head unit side of...
The entire 5.1 amplification system, in the Bose Lifestyle 35, is actually part of the Bose Acoustimass (subwoofer) module. The RJ-45 (network type) connector passes a low-voltage signal from the console to the Acoustimass module. If you were to hack the connection, and plug the speaker outputs of a 5.1 receiver to the RJ-45 socket on the Acoustimass module, you would blow the amplifier.
If you are really itching to replace the Bose Lifestyle 35 console with a regular 5.1 receiver, I strongly suggest you sell your Bose system, and purchase a Bose speaker system, such as the Acoustimass 10 Home Theater Speaker System, which is made for use with a standard 5.1 surround sound receiver.
Dec 26, 2009 | Bose Lifestyle 28 System
Uplinking Using Gig Copper
hello, use the plugin modules for the rj 45 connection port to uplink it.
Aug 04, 2009 | Computers & Internet
Modem
Technical Specifications AAL and ATM Support
VCI 0-65535 address range
VPI 0-255 address range
AAL5 support
Bridging
IEEE 802.1.d Transparent Learning Bridge (dynamic learning of up to 255 addresses)
Spanning Tree support
Certifications
FCC Part 15, Class B
CE certification
Connectors
DSL interface: RJ-11 or RJ-45 (Europe)
Ethernet interface: RJ-45
USB Type B interface (5200, 5500 series)
Diagnostic LEDs
Power, DSL, Activity, Ethernet status; USB status (5200, 5500 series)
Management
Intuitive, Web-based GUI management access
SNMP support
Comprehensive hardware diagnostics
Media Interface
RJ-11 or RJ-45 (European) DSL WAN connection
10/100Base-T RJ-45 Ethernet LAN connection
USB Type B LAN connection (5200, 5500 series)
Power
12V power supply included, 700ma max. 5400/5500 - 12 VDC, 1000ma max.
Routing
DHCP server/DHCP client
Network Address Port Translation (NAPT)
Network Address Translation (NAT)
Packet filtering
RFC 2364 Point-to-Point Protocol over ATM PVCs (PPPoA)
RFC 2516 Point-to-Point Protocol over Ethernet (PPPoE)
RFC 2684 (formerly 1483) Bridged Ethernet and routed encapsulation Routing
Standards Compliance
IEEE 802.3
USB 1.1 T1.413 issue 2 G.992.1 (G.DMT) G.992.2 (G.Lite)
Oct 15, 2008 | Siemens SpeedStream Modem (4100) (SS4100)
Cat5e
Some testers do not test ALL the wires. Some will only test pair 1 and 2. You may want to use a DVM (Digital Voltmeter) set on the ohms function and check continuity on each of the eight wires from RJ-45 to RJ-45 connector or use a cable tester that will check all the wires. If you use a DVM check 1 to 1, 2 to 2 etc. for continuity. Good will read 0 ohms, open will read infinity or OL on some meters. 90% of all cable problems are poorly crimped or broken wires at the RJ-45 connector. It is difficult to be sure which end has the bad connection so you may need to change BOTH RJ-45 connectors. Do one, then check the cable, if it doesn't work, do the other one. It is a 50-50 shot. I prefer and encourage the rewiring color code using the EIA 568A standard. Starting at pin 1 the color code would be orange-white, orange, green-white, blue, blue-white, green, brown-white, brown. You don't have to do it that way, but you must make sure that the same color wire is on the same pin on each connector. If all else fails, you can go to you neighborhood computer shop for help in installing connectors. It takes a lot of practice to do it right. Hope this helps
Nov 30, 2005 | Honeywell Multimedia, Cat5e X2, RG6/U...
Radio Communications Logo
201 people viewed this question
Top Universal Remote Control Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you an Universal Remote Control Radio Communication Expert? Answer questions, earn points and help others
