Question about Eureka 109A Easy Clean 2IN1 Cordless Stick Vacuum
I keep my vacuum on the charger all the time and seems like does not work right after all. Stoops after 30seconds of vacuuming. I do not if this is batteries or something else. Please advise. thank you
  • 3 Answers
The problem is probably not the battery pack or charger. I had the same problem and it is in the electronic over current circuit that prevents a possible overheating of the battery pack. My unit will run for 10 - 15 seconds and then shuts off. The over current sensor is reset by moving the power switch to the "OFF" position. If you turn the vacuum back on it will run for a few more seconds before shutting off again. There is a small circuit board in the vacuum that contains the over current protection circuit. It uses an NXP Semiconductor HEF4001BP quad 2-input NOR gate. If you are good at soldering you might try replacing this chip. Otherwise, buy a new vacuum. The problem is not in the thermal circuit breaker located in the handle. I have bypassed the breaker and the problem still occurs.
Posted on Jul 04, 2012
SOURCE: Cordless vacuum WESTINGHOUSE WST1600A - problem with charger.
put fuse in
Posted on May 18, 2008
Take the battery apart and then replace the individual cells. I'm going to try using Nickel Metal batteries on mine. i'll let you know how it works out.
Posted on Nov 07, 2008
SOURCE: battery charger broken
CHARGER WONT WORK MEC B5265 CAN I BUY NEW ONE?
Posted on Aug 19, 2009
  • 22 Answers
SOURCE: I have a shark EURO-PRO RECHARGEABLE VACUUM I
Here is the link for your replacement charger and battery pack.
http://www.sharkclean.com/cgi-bin/livew/site.w?location=b2c/parts.w&frames=no&target=main&sponsor=000001
Posted on Sep 15, 2009
SOURCE: I have a oreck xl2 and while vacuuming the vacuum
sounds like a bad motor. if the light is on at the switch and the motor doesn't run, then it could definitely a motor problem, worn down or dirty carbon brushes. the motor on these machines are not the best built, they require cleaning of the commutator yearly.
Posted on Nov 20, 2009
Do you keep the Dyson DC44 plugged into charger all the time?
I don't keep mine plugged in, but that's because I haven't mounted the charger on the wall. I think rechargeable batteries are smart enough nowadays to allow for an appliance to be constantly plugged in.
Jul 10, 2014 | Dyson DC44 Animal Cordless Vacuum
Why does roomba keep docking?
It needs to recharge every time it docks.
I would suggest that you let Roomba run out of the room where it's charger is. Then force it to run until it dies out. Then put it back onto it's charger.. I suspect that it's developed a memory (short) for charging and you need to force it to totally drain down, then charge for a good while. This should force it to develop a "Longer" memory. Works for me anyway.
May 09, 2014 | iRobot Roomba 4210 Bagless Robotic Vacuum
Light says its charging but it wont turn on
Well first of all you may check that the charger (adapter) is working or not, you may use a volt meter to check it out or use another charger to make sure....... further you may follow the step below -
1. Remove the battery pack from Vacuum.
2. Hold down the power button for five seconds.
3. Reinstall the battery to reset the system.
4. Plug the Charger directly into vacuum.
5. Charge the battery untill the power light is solid green again and keep the vacuum on the charger for an additional 72 hours (3 days). Important: Do NOT interrupt this charging cycle.
If further you have the same problem it means it's time to change the old battery with new one.
Good Luck!!
Thanks for using FixYa!!
Sep 18, 2010 | Dirt Devil KONE Hand Vacuum MO213BLU...
Light goes on my kone but it won't work
Good Luck!!
May 19, 2010 | Dirt Devil KONE Hand Vacuum MO213BLU...
Electrolux Vacuum keeps turning off and light looks like bag with
Turn the knob on the top of the vacuum all the way to the right.I had the same problem and that fixed it.
Mar 10, 2009 | Electrolux Epic 6500 Vacuum
Roomba 560 do not charge in home base
Please help all the time says right wheel inspection
Feb 10, 2009 | Roomba Robotic Floor Bagless Vacuum
Black and Decker Hand Vacuum (CHV 9600); mike Mills
If it seems to be taking a charge, then the charger and the battries are ok and the problem is with the indicator light. So if it is working normally, I wouldn't worry about that light.
Jan 02, 2008 | Vacuums
Hoover Savvy
Does this happen at both Dirt Finder Sensitivity settings?
Sep 16, 2007 | Hoover U8171-900 / U8172-900 / U8173-900 /...
Eureka 109A Easy Clean 2IN1 Cordless Stick Vacuum Logo
111 people viewed this question
Top Eureka Vacuums Experts
JoeVacs
Alan Matzke
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
